У Вас должны быть такие функции
void segment(){
switch(segm){
case 0: digitalWrite(ID8,LOW);digitalWrite(ID4,LOW);digitalWrite(ID2,LOW);digitalWrite(ID1,LOW);break; // DEC 0 = 0b0000
case 1: digitalWrite(ID8,LOW);digitalWrite(ID4,LOW);digitalWrite(ID2,LOW);digitalWrite(ID1,HIGH);break; // DEC 1 = 0b0001
case 2: digitalWrite(ID8,LOW);digitalWrite(ID4,LOW);digitalWrite(ID2,HIGH);digitalWrite(ID1,LOW);break; // DEC 2 = 0b0010
case 3: digitalWrite(ID8,LOW);digitalWrite(ID4,LOW);digitalWrite(ID2,HIGH);digitalWrite(ID1,HIGH);break; // DEC 3 = 0b0011
case 4: digitalWrite(ID8,LOW);digitalWrite(ID4,HIGH);digitalWrite(ID2,LOW);digitalWrite(ID1,LOW);break; // DEC 4 = 0b0100
case 5: digitalWrite(ID8,LOW);digitalWrite(ID4,HIGH);digitalWrite(ID2,LOW);digitalWrite(ID1,HIGH);break; // DEC 5 = 0b0101
case 6: digitalWrite(ID8,LOW);digitalWrite(ID4,HIGH);digitalWrite(ID2,HIGH);digitalWrite(ID1,LOW);break; // DEC 6 = 0b0110
case 7: digitalWrite(ID8,LOW);digitalWrite(ID4,HIGH);digitalWrite(ID2,HIGH);digitalWrite(ID1,HIGH);break; // DEC 7 = 0b0111
case 8: digitalWrite(ID8,HIGH);digitalWrite(ID4,LOW);digitalWrite(ID2,LOW);digitalWrite(ID1,LOW);break; // DEC 8 = 0b1000
case 9: digitalWrite(ID8,HIGH);digitalWrite(ID4,LOW);digitalWrite(ID2,LOW);digitalWrite(ID1,HIGH);break; // DEC 9 = 0b1001
case 10:digitalWrite(ID8,HIGH);digitalWrite(ID4,HIGH);digitalWrite(ID2,HIGH);digitalWrite(ID1,HIGH);break; // Пусто = 0b1111
и
void anod(){
switch(an){
case 0: digitalWrite(IN1,HIGH);digitalWrite(IN2,LOW);digitalWrite(IN3,LOW);digitalWrite(IN4,LOW);digitalWrite(IN5,LOW);digitalWrite(IN6,LOW);break;
case 1: digitalWrite(IN1,LOW);digitalWrite(IN2,HIGH);digitalWrite(IN3,LOW);digitalWrite(IN4,LOW);digitalWrite(IN5,LOW);digitalWrite(IN6,LOW);break;
case 2: digitalWrite(IN1,LOW);digitalWrite(IN2,LOW);digitalWrite(IN3,HIGH);digitalWrite(IN4,LOW);digitalWrite(IN5,LOW);digitalWrite(IN6,LOW);break;
case 3: digitalWrite(IN1,LOW);digitalWrite(IN2,LOW);digitalWrite(IN3,LOW);digitalWrite(IN4,HIGH);digitalWrite(IN5,LOW);digitalWrite(IN6,LOW);break;
case 4: digitalWrite(IN1,LOW);digitalWrite(IN2,LOW);digitalWrite(IN3,LOW);digitalWrite(IN4,LOW);digitalWrite(IN5,HIGH);digitalWrite(IN6,LOW);break;
case 5: digitalWrite(IN1,LOW);digitalWrite(IN2,LOW);digitalWrite(IN3,LOW);digitalWrite(IN4,LOW);digitalWrite(IN5,LOW);digitalWrite(IN6,HIGH);break;
case 10:digitalWrite(IN1,LOW);digitalWrite(IN2,LOW);digitalWrite(IN3,LOW);digitalWrite(IN4,LOW);digitalWrite(IN5,LOW);digitalWrite(IN6,LOW);break;
в них должны быть строки
case 10
если нет , то надо добавить
