Тема: attiny13 + 7-и сегм. 4-х разр. инд. на MAX7219
Основная статья - http://rcl-radio.ru/?p=132443
тест
// MAX7219
#define DIN PB0
#define CLK PB1
#define CS  PB2
int ccc;
#include <avr/io.h>
#include <util/delay.h>
int main(void) {
   DDRB |=(1<<DIN)|(1<<CLK)|(1<<CS);
   PORTB |=(1<<DIN)|(1<<CLK)|(1<<CS);
   WriteBit16(0x0F, 0);// тест выкл.
   WriteBit16(0x0C, 1);// вкл. индик.
   WriteBit16(0x0A, 2);// яркость
   WriteBit16(0x09, 0xFF);// дешифраторы вкл.
   WriteBit16(0x0B, 3);// кол-во разрядов
while(1) {
  ccc++;
  WriteBit16(1, ccc/1000%10);
  WriteBit16(2, ccc/100%10 + 0xF0);// запятая
  WriteBit16(3, ccc/10%10);
  WriteBit16(4, ccc%10);
  _delay_ms(1000);
     PORTB &=~(1<<CLK);PORTB &=~(1<<CS);
     for(int i = 7; i >= 0; i--){
        if(((reg >> i) & 1) == 1){PORTB |=(1<<DIN);}
         else{PORTB &=~(1<<DIN);}
        PORTB |=(1<<CLK);PORTB &=~(1<<CLK);
        if(((data >> i) & 1) == 1){PORTB |=(1<<DIN);}
     PORTB |=(1<<CS);PORTB &=~(1<<CLK);PORTB &=~(1<<DIN);
Re: attiny13 + 7-и сегм. 4-х разр. инд. на MAX7219
attiny13+ds18b20 термометр
// MAX7219
#define DIN  PB0
#define CLK  PB1
#define CS   PB2
#define TEMP PB4
int ccc;
bool minus;
#include <avr/io.h>
int main(void) {
while(1) {
  int temp = read_temp();
  if(temp<0){minus=1;temp=-temp;}else{minus=0;}
  if(minus==0){WriteBit16(1, 15);}else{WriteBit16(1, 10);}
  WriteBit16(2, temp/100%10);
  WriteBit16(3, temp/10%10+0xf0);
  WriteBit16(4, temp%10);
  _delay_ms(3000);
//// DS18B20 //////////////////////////////////////
uint8_t therm_reset(){
    uint8_t i;
    PORTB &= ~(1 << TEMP);
    DDRB |= (1 << TEMP);
    _delay_us(480);
    DDRB &= ~(1 << TEMP);
    _delay_us(60);
    i=((PINB >> TEMP) & 1);
    _delay_us(420);
    return i;
void therm_write_bit(uint8_t bit){
    if(bit) DDRB &= ~(1 << TEMP);
    _delay_us(60);
uint8_t therm_read_bit(void){
    uint8_t bit=0;
    _delay_us(14);
    if(PINB & (1 << TEMP)) bit=1;
    _delay_us(45);
    return bit;
uint8_t therm_read_byte(void){
    uint8_t i=8, n=0;
    while(i--){n>>=1;n|=(therm_read_bit()<<7);}
    return n;
void therm_write_byte(uint8_t byte){
    uint8_t i=8;
    while(i--){therm_write_bit(byte&1);byte >>= 1;
int read_temp(){
    uint8_t temperature[2];
    int temper;
    therm_reset();
    therm_write_byte(0xCC);
    therm_write_byte(0x44);
    while(!therm_read_bit());
    therm_reset();
    therm_write_byte(0xBE);
    temperature[0]=therm_read_byte();
    temperature[1]=therm_read_byte();
    therm_reset();
    return temper = (temperature[1] << 8 | temperature[0])*10/16;
3
attiny13+ds3231 - простые часы
// MAX7219
#define DIN  PB0
#define CLK  PB1
#define CS   PB2
#define SDA  PB3
#define SCL  PB4
#include <avr/io.h>
int dp;
int main(void) {
  // set_time(24,3,8,15,9,55,0);// год 00-99, ДН 1-7 (1=ВС), месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
while(1) {
  byte min =  (ds_read(1) & 0x0F) + (((ds_read(1) & 0x70) >> 4) * 10);
  byte hour = ((ds_read(2) & 0x0F) + ((ds_read(2) & 0x70) >> 4) * 10);
  WriteBit16(1, hour/10%10);
 if(dp==0){ WriteBit16(2, hour%10+0xf0);}else{WriteBit16(2, hour%10);}
  WriteBit16(3, min/10%10);
  WriteBit16(4, min%10);
  _delay_ms(500);
  dp++;
  if(dp>1){dp=0;}
bool i2c_read_bit() {
    bool i2c_bit = 1;
    DDRB &= ~(1 << SDA);
    _delay_us(10);
    DDRB &= ~(1 << SCL);
    if((PINB >> SDA) & 1) i2c_bit=0;
    _delay_us(10);
    DDRB |= (1 << SCL);
    return i2c_bit;
    return i2c_read_bit();
byte i2c_read_byte(byte a){
    byte i, data=0;
    i2c_write_bit(a);return data;
void i2c_write_bit(byte b){
    _delay_us(5);
    if(b){DDRB |= (1 << SDA);}else{DDRB &= ~(1 << SDA);}
    _delay_us(5);
    _delay_us(10);
    DDRB |= (1 << SCL);
void i2c_start(){
     _delay_us(10);
     DDRB &= ~(1 << SDA); DDRB &= ~(1 << SCL);
     _delay_us(10);
     DDRB |= (1 << SDA);  PORTB &= ~(1 << SDA);
     _delay_us(10);
     DDRB |= (1 << SCL);  PORTB &= ~(1 << SCL);
     _delay_us(10);
void i2c_stop()  {
     DDRB |= (1 << SDA);
     _delay_us(10);
     _delay_us(10);
byte ds_read(byte reg){
     byte data = 0;
     i2c_start();
     i2c_write_byte(0b11010000);
     i2c_write_byte(reg);
     i2c_start();
     i2c_write_byte(0b11010001);
     data = i2c_read_byte(0);
     i2c_stop();
     return data;
     i2c_start();
     i2c_write_byte(data);
     i2c_stop();
    if(second < 255){ds_write(0x00,(second/10<<4)+second%10);}
    if(minute < 255){ds_write(0x01,(minute/10<<4)+minute%10);}
    if(hours < 255){ds_write(0x02,(hours/10<<4)+hours%10);}
    if(days < 255){ds_write(0x03,days);}
    if(datas < 255){ds_write(0x04,(datas/10<<4)+datas%10);}
    if(monts < 255){ds_write(0x05,(monts/10<<4)+monts%10);}
    if(years < 255)ds_write(0x06,(years/10<<4)+years%10);
4
attiny13+ds3231+температура-простые часы
// MAX7219
#define DIN  PB0
#define CLK  PB1
#define CS   PB2
#define SDA  PB3
#define SCL  PB4
#include <avr/io.h>
int dp;
int main(void) {
while(1) {
  byte sec =  (ds_read(0) & 0x0F) + (((ds_read(0) & 0x70) >> 4) * 10);
  int temper = (ds_read(0x11)*100 + ((ds_read(0x12) & 0b11000000) >> 6)*25)/10 ;
 if(sec<50){
 else{
  WriteBit16(1, 15);
  WriteBit16(2, temper/100%10);
  WriteBit16(3, temper/10%10+0xf0);
  WriteBit16(4, temper%10);
  _delay_ms(500);
  dp++;
  if(dp>1){dp=0;}
    bool i2c_bit = 1;
    _delay_us(10);
    _delay_us(10);
    DDRB |= (1 << SCL);
    return i2c_bit;
    byte i, data=0;
    _delay_us(5);
    _delay_us(5);
    _delay_us(10);
    DDRB |= (1 << SCL);
void i2c_start(){
     _delay_us(10);
     _delay_us(10);
     _delay_us(10);
     _delay_us(10);
void i2c_stop()  {
     DDRB |= (1 << SDA);
     _delay_us(10);
     _delay_us(10);
     byte data = 0;
     i2c_start();
     i2c_start();
     i2c_stop();
     return data;
     i2c_start();
     i2c_stop();
5
attiny13+DHT11+ds18b20 - мини погодная станция
температура на улице
температура в помещении
влажность в помещении
// MAX7219
#define DIN  PB0
#define CLK  PB1
#define CS   PB2
#define TEMP PB4
#define DHT  PB3
bool minus;
byte data_dht[5];
#include <avr/io.h>
int main(void) {
while(1) {
  _delay_ms(3000);
  dht_read();
  WriteBit16(1, 15);
  WriteBit16(2, 15);
  WriteBit16(3, data_dht[2]/10%10);
  WriteBit16(4, data_dht[2]%10);
  _delay_ms(3000);
  WriteBit16(1, 12);
  WriteBit16(2, 15);
  WriteBit16(3, data_dht[0]/10%10);
  WriteBit16(4, data_dht[0]%10);
  _delay_ms(3000);
    uint8_t i;
    _delay_us(480);
    _delay_us(60);
    _delay_us(420);
    return i;
    _delay_us(60);
    uint8_t bit=0;
    _delay_us(14);
    _delay_us(45);
    return bit;
    uint8_t i=8, n=0;
    return n;
    uint8_t i=8;
int read_temp(){
    int temper;
    therm_reset();
    therm_reset();
    therm_reset();
int dht_read(){
        byte i = 0,i1 = 0;
        for(i = 0;i < 5;i++){data_dht[i] = 0;}
        DDRB |=(1 << DHT);
        PORTB &= ~(1 << DHT);
        _delay_ms(18);
        PORTB |= (1 << DHT);
        _delay_us(40);
        DDRB &= ~(1 << DHT);
        _delay_us(80);
    while(PINB & (1 << DHT));
      for (i = 0; i < 5; i++){
        data_dht[i]=0;
      for (i1=0; i1<8; i1++){
    while(!(PINB & (1 << DHT)));
        _delay_us(30);
      if (PINB & (1 << DHT)){data_dht[i] |= 1 << (7-i1);}
}}return 1;}
6
секундомер 0.0-999.9 сек
// MAX7219
#define DIN    PB0
#define CLK    PB1
#define CS     PB2
#define BUTTON PB4
int ccc;
bool start;
#include <avr/io.h>
int main(void) {
   PORTB |=(1<<BUTTON);
while(1) {
  if(((PINB >> BUTTON) & 1)==LOW && start==0 && ccc==0){start=1;_delay_ms(200);ccc=2;}
  if(((PINB >> BUTTON) & 1)==LOW && start==1){start=0;_delay_ms(200);}
  if(((PINB >> BUTTON) & 1)==LOW && start==0 && ccc>0){ccc=0;_delay_ms(200);}
  if(start==1){ccc++;}
  WriteBit16(2, ccc/100%10);
  WriteBit16(3, ccc/10%10 + 0xF0);
  _delay_ms(100);
7
таймер с звуковым оповещением
минуты фиксированы 1 3 5 7 10 12 15 20 30 45 60 90
// MAX7219
#define DIN    PB0
#define CLK    PB1
#define CS     PB2
#define BUTTON_1 PB4  // start/stop
#define BUTTON_2 PB3  // set time
int ccc,set,min,sec;
bool start;
#include <avr/io.h>
int main(void) {
   PORTB |=(1<<BUTTON_1)|(2<<BUTTON_2);
while(1) {
  if(((PINB >> BUTTON_2) & 1)==LOW){start=0;_delay_ms(200);set++;if(set>11){set=0;}}
if(start==0){
  switch(set){
    case 0: ccc=300;break;
    case 1: ccc=900;break;
    case 2: ccc=1500;break;
    case 3: ccc=2100;break;
    case 4: ccc=3000;break;
    case 5: ccc=3600;break;
    case 6: ccc=4500;break;
    case 7: ccc=6000;break;
    case 8: ccc=9000;break;
    case 9: ccc=13500;break;
    case 10: ccc=18000;break;
    case 11: ccc=27000;break;
  if(((PINB >> BUTTON_1) & 1)==LOW && start==0){start=1;_delay_ms(100);}
  if(start==1){ccc--;if(ccc<0){start=0;
  DDRB |=(1<<BUTTON_1);
  for(int n=0;n<10;n++){PORTB|=(1<<BUTTON_1);_delay_ms(200);PORTB&=~(1<<BUTTON_1);_delay_ms(200);}
  DDRB &=~(1<<BUTTON_1);
  min = ccc/300;
  sec = (ccc*2-(min*600))/10;
  WriteBit16(1, min/10%10);
  WriteBit16(2, min%10 + 0xF0);
  WriteBit16(3, sec/10%10);
  WriteBit16(4, sec%10);
  _delay_ms(200);
8
Привет. Я заметил разницу в настройках arduino ide ( у меня 2.3.3) для attiny13
У тебя указано EEPROM NO RETAINED , А в последней версии по умолчанию EEPROM RETAINED
