Тема: INA3221
Основная статья - http://rcl-radio.ru/?p=132614
#include <INA3221.h>
#define SERIAL_SPEED 9600 // serial baud rate
#define PRINT_DEC_POINTS 3 // decimal points to print
// Set I2C address to 0x41 (A0 pin -> VCC)
INA3221 ina3221(INA3221_ADDR40_GND);
Serial.begin(SERIAL_SPEED);
while (!Serial) {
delay(1);
ina3221.begin();
ina3221.reset();
// Set shunt resistors to 10 mOhm for all channels
ina3221.setShuntRes(100, 100, 100);
// Set series filter resistors to 10 Ohm for all channels.
// Series filter resistors introduce error to the current measurement.
// The error can be estimated and depends on the resitor values and the bus
// voltage.
ina3221.setFilterRes(100, 100, 100);
float current[3];
float current_compensated[3];
float voltage[3];
current[0] = ina3221.getCurrent(INA3221_CH1);
current_compensated[0] = ina3221.getCurrentCompensated(INA3221_CH1);
voltage[0] = ina3221.getVoltage(INA3221_CH1);
current[1] = ina3221.getCurrent(INA3221_CH2);
current_compensated[1] = ina3221.getCurrentCompensated(INA3221_CH2);
voltage[1] = ina3221.getVoltage(INA3221_CH2);
current[2] = ina3221.getCurrent(INA3221_CH3);
current_compensated[2] = ina3221.getCurrentCompensated(INA3221_CH3);
voltage[2] = ina3221.getVoltage(INA3221_CH3);
Serial.print("Channel 1: \n Current: ");
Serial.print(current[0], PRINT_DEC_POINTS);
Serial.print("A\n Compensated current: ");
Serial.print(current_compensated[0], PRINT_DEC_POINTS);
Serial.print("\n Voltage: ");
Serial.print(voltage[0], PRINT_DEC_POINTS);
Serial.println("V");
Serial.print("Channel 2: \n Current: ");
Serial.print(current[1], PRINT_DEC_POINTS);
Serial.print(current_compensated[1], PRINT_DEC_POINTS);
Serial.print(voltage[1], PRINT_DEC_POINTS);
Serial.print("Channel 3: \n Current: ");
Serial.print(current[2], PRINT_DEC_POINTS);
Serial.print(current_compensated[2], PRINT_DEC_POINTS);
Serial.print(voltage[2], PRINT_DEC_POINTS);
Serial.println("V\n");
delay(1000);
