Тема: Частотомер FGT8F328 MAX7219 8 разрядов
Основная статья - http://rcl-radio.ru/?p=130049
#define DIN PD4
#define CLK PD2
#define CS PD3
#define CAL 62502; //62499 = 1 sec
static unsigned long tic,freq;
bool w=1;
byte fq[8],pd,x;
PORTD |= (1 << PD5); // подтягивающий резистор на PD5 (вход T1)
DDRB |= (1 << PB3); // D11 OUTPUT 8 MHz
_delay_ms(2);
PORTD |= (1 << CS);
WriteBit16(0x0F, 0);// тест выкл.
WriteBit16(0x0C, 1);// вкл. индик.
WriteBit16(0x0A, 0);// яркость
WriteBit16(0x09, 0xFF);// дешифраторы вкл.
WriteBit16(0x0B, 7);// кол-во разрядов
cl();
_delay_ms(2);
noInterrupts();
// TIMER_1 INPUT T1
TCCR1B = (1 << CS12) | (1 << CS11) | (1 << CS10);
TIMSK1 = (1 << TOIE1);
TCKCSR = (1 << F2XEN) | (1 << TC2XS1);
// TIMER_3 1 SEC
TCCR3A = 0;
TCCR3B = 0;
TCNT3=0;
TCCR3B = (1 << CS32) | (1 << WGM32);
TIMSK3 = (1 << OCIE3A);
OCR3A = CAL;
// TIMER_2 OUTPUT 8 MHz
TCCR2A = 0;TCCR2B = 0;TCNT2=0;
TCCR2A = 1 << COM2A0 |1 << WGM21;
TCCR2B = 1 << CS20;
OCR2A = 0;
interrupts();
if(w==1){w=0;
if(freq>=10000000){WriteBit16(0x0B, 7);x=8;}
if(freq<10000000&&freq>=1000000){WriteBit16(0x0B, 6);x=7;}
if(freq<1000000&&freq>=100000){WriteBit16(0x0B, 5);x=6;}
if(freq<100000&&freq>=10000){WriteBit16(0x0B, 4);x=5;}
if(freq<10000&&freq>=1000){WriteBit16(0x0B, 3);x=4;}
if(freq<1000&&freq>=100){WriteBit16(0x0B, 2);x=3;}
if(freq<100&&freq>=10){WriteBit16(0x0B, 1);x=2;}
if(freq<10){WriteBit16(0x0B, 0);x=1;}
fq[7]= freq/10000000%10;
fq[6]= freq/1000000%10|0b10000000;
fq[5]= freq/100000%10;
fq[4]= freq/10000%10;
fq[3]= freq/1000%10|0b10000000;
fq[2]= freq/100%10;
fq[1]= freq/10%10;
fq[0]= freq%10%10;
for(int i=0;i<8;i++){WriteBit16(i+1, fq[i]);}
ISR(TIMER1_OVF_vect) {tic++;}
ISR(TIMER3_vect) {
if (TIFR3 & (1 << OCF3A)){
TIFR3 = 1 << OCF3A;
freq = tic*0xFFFF + TCNT1;
tic=0;TCNT1=0;
w=1;
void cl(){for(char i=1;i<=8;i++){WriteBit16(i, 0);}}
PORTD &= ~(1 << CLK);PORTD &= ~(1 << CS);
for(int i = 7; i >= 0; i--){
PORTD |=(1 << CLK);PORTD &= ~(1 << CLK);
PORTD &= ~(1 << CLK);PORTD &= ~(1 << DIN);PORTD |=(1 << CS);
