Тема: Измеритель емкости на LGT8F328
Основная статья - http://rcl-radio.ru/?p=131737
#define CALL_UF 6.10
#define CALL_NF 6.58
//U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE|U8G_I2C_OPT_DEV_0);
U8GLIB_SSD1306_128X32 u8g(U8G_I2C_OPT_NONE); // I2C / TWI
volatile int x;
float null_c;
bool mk;
unsigned long c_f,times0,times1;
PORTB |=(1<<PB5);
// TIMER_1 /////////////////////////
TCNT1 = 0;TCCR1A = 0;TCCR1C = 0;TCCR1B = 2;TIMSK1 |= (1 << TOIE1);
// COMPARATOR_0 ////////////////////
C0SR = 0;C0XR=0;ADMUX=0;ADCSRB=0;
ADCSRB = 0b01000000;// ADMUX
ADMUX = 0b00000000; // A0 A1 A2
C0SR &=~(1<<C0BG);C0XR |=(1<<C0PS0);// ACXP
// ADC ////////////////////////////
ADCSRD |= (1<<REFS2); // 4.096 ИОН
ADCSRA |= 1 << ADEN | 1 << ADSC | 1 << ADATE | 0b111;
delay(200);
PORTB |=(1<<PB0);DDRB &=~ (1<<PB0);
DDRD |=(1<<PD6);PORTD &=~ (1<<PD6);delay(300);
DDRB &=~ (1<<PB0);PORTB &=~(1<<PB0);
times1=millis();
while(analogRead(A0)>10);
delay(100);
TCNT1=0;x=0;PORTD |= (1<<PD6);
while(((C0SR >> 5) & 1)==1);null_c = (x * 65535 + TCNT1)/CALL_NF;
u8g.firstPage(); do {u8g.setFont(u8g_font_profont17r);u8g.drawStr(20,11,"CALL_0");
u8g.setPrintPos(20,28);u8g.print(null_c,1);u8g.drawStr(80,28,"pF");
} while( u8g.nextPage() );
delay(2000);
///// uF ////////////////////////////////////////////////
PORTD &=~(1<<PD6);DDRD &=~(1<<PD6);
DDRB |= (1<<PB0);PORTB &=~ (1<<PB0);delay(10);
TCNT1=0;x=0;PORTB |= (1<<PB0);
while(((C0SR >> 5) & 1)==1){c_f = x * 65535 + TCNT1;PORTB|=(1<<PB5);}
PORTB&=~(1<<PB5);
if((c_f/CALL_UF)/1000.0<0.3){mk=1;}else{mk=0;}
///// nF ////////////////////////////////////////////////
if(mk==1){
times1=millis();
while(analogRead(A0)>10){if(millis()-times1>2000){mk=0;break;}};
delay(100);
while(((C0SR >> 5) & 1)==1){PORTB|=(1<<PB5);if(x>50){mk=0;break;}}
PORTB&=~(1<<PB5);c_f = x * 65535 + TCNT1;
u8g.setFont(u8g_font_profont29r);u8g.setPrintPos(0,25);
if(mk==1){
if((c_f/CALL_NF-null_c)<9999){
u8g.print(abs(c_f/CALL_NF-null_c),0);u8g.drawStr(100,25,"pF");
}else{
u8g.print((c_f/CALL_NF-null_c)/1000.0,2);u8g.drawStr(100,25,"nF");}
if(mk==0){
if((c_f/CALL_UF)/1000.0<9.99){
u8g.print((c_f/CALL_UF)/1000.0,2);u8g.drawStr(100,25,"uF");
}else{
u8g.print((c_f/CALL_UF)/1000.0,1);u8g.drawStr(100,25,"uF");
Serial.println((c_f/CALL_UF)/1000.0);
ISR(TIMER1_OVF_vect){x++;}
