51
Re: Часы (DS3231) с будильником (Arduino)
http://forum.rcl-radio.ru/uploads/images/2024/04/6830cf5a837fb7d70aa18644b58e61da.jpg
52
День недели
#include <Adafruit_Sensor.h>    // https://github.com/adafruit/Adafruit_Sensor.git
#include <Adafruit_BME280.h>    // https://github.com/adafruit/Adafruit_BME280_Library.git
// может понадобится библиотека Adafruit_I2CDevice.h >>> https://github.com/adafruit/Adafruit_BusIO.git
 Adafruit_BME280 bme;
 int hour,minut,secon,year,month,day,den;
 int svet;
 float temp,p,h;
 byte v1[8] = {0b00111111,0b11000110,0b00011000,0b01100011,0b00000100};// П
 byte v2[8] = {0b00110001,0b11000110,0b00001111,0b00100001,0b11111100};// Ч
 byte v3[8] = {0x3f,0x84,0x17,0xe3,0x03};// Б
  lcd.init();lcd.backlight();
  lcd.createChar(1, v1);lcd.createChar(2, v2);lcd.createChar(3, v3);
  pinMode(10,OUTPUT);
  analogWrite(10, 200);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  svet = map(200, 0,250,50,250);if(svet>250){svet=250;}
  analogWrite(10, svet);
  hour = DateTime.hour;
  minut = DateTime.minute;
  secon = DateTime.second;
  year=DateTime.year;
  month=DateTime.month;
  day=DateTime.day;
  den=DateTime.dayOfWeek;
  temp = bme.readTemperature();
  p = bme.readPressure() / 133.3224;
  h = bme.readHumidity();
  Serial.print(hour/10);Serial.print(hour%10);Serial.print(":");
  Serial.print(minut/10);Serial.print(minut%10);Serial.print(":");
  Serial.print(secon/10);Serial.println(secon%10);
  Serial.println(temp,1);
  Serial.println(p,1);
  Serial.println(h,1);
  Serial.println(svet);
  lcd.setCursor(0, 0);
  lcd.print(temp,1);lcd.print((char)223);lcd.print("C ");
  lcd.setCursor(8, 0);
  lcd.print(hour/10);lcd.print(hour%10);lcd.print(":");lcd.print(minut/10);lcd.print(minut%10);
  switch(den){
    case 1: lcd.write((uint8_t)1);lcd.print("H");break;//ПН
    case 2: lcd.print("BT");break;
    case 3: lcd.print("CP");break;
    case 4: lcd.write((uint8_t)2);lcd.print("T");break; //ЧТ
    case 5: lcd.write((uint8_t)1);lcd.print("T");break; //ПТ
    case 6: lcd.print("C");lcd.write((uint8_t)3);break; //СБ
    case 7: lcd.print("BC");break;
  lcd.setCursor(0, 1);
  lcd.print(p,0);lcd.print("mH");
  lcd.setCursor(6, 1);
  lcd.print(day/10);lcd.print(day%10);lcd.print(".");lcd.print(month/10);lcd.print(month%10);lcd.print(".");lcd.print(year);
  delay(1000);
53
http://forum.rcl-radio.ru/uploads/images/2024/04/68bab81635d1bef3f145cdf299614199.jpg
54
 int svet;
 float temp,p,h;
 byte v1[8] = {B11111,B10001,B10001,B10001,B10001,B10001,B10001,B00000};// П
 byte v2[8] = {B10001,B10001,B10001,B01111,B00001,B00001,B00001,B00000};// Ч
 byte v3[8] = {B11110,B10000,B10000,B11110,B10001,B10001,B11110,B00000};// Б
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  year=DateTime.year;
  day=DateTime.day;
  lcd.setCursor(14, 0);
  switch(den){
  delay(1000);
55
http://forum.rcl-radio.ru/uploads/images/2024/04/5572c41f1e112558842b00b312780350.jpg
56
Напишите алгоритм установки времени, какие кнопки нажимать и при каких условиях, с учетом что потом нужно будет устанавливать время будильника
57
При нажимании кнопки D4 «СБРОС» происходит перебор элементов меню, для коррекции часов, даты и месяца, установки времени будильника.
Включение или отключение будильника осуществляется переключением тумблера D5"СИГНАЛ".
Установка времени срабатывания будильника осуществляется кнопками: кнопка D2"ЧАС" = кнопке «+», кнопка D3"МИН" = кнопке «-», кнопка «СБРОС»=SET.
Отключение будильника во время срабатывания в установленное время, сенсорной кнопкой №2 D12.
58
Коррекция времени
 int svet;
 float temp,p,h;
 int set,hh,mm,ss,dd,mn,gg;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  ///clock.setDateTime(__DATE__, __TIME__);
  year=DateTime.year;
  day=DateTime.day;
  hh=hour;mm=minut;ss=secon;dd=day;mn=month;gg=year;
  if(digitalRead(4)==HIGH){set++;if(set>5){set=0;}delay(200);}
  if(set==1 && digitalRead(2)==HIGH){hh++;if(hh>23){hh=0;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==1 && digitalRead(3)==HIGH){hh--;if(hh<0){hh=0;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==2 && digitalRead(2)==HIGH){mm++;if(mm>59){mm=0;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==2 && digitalRead(3)==HIGH){mm--;if(mm<0){mm=0;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==3 && digitalRead(2)==HIGH){dd++;if(dd>31){dd=1;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==3 && digitalRead(3)==HIGH){dd--;if(dd<1){dd=1;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==4 && digitalRead(2)==HIGH){mn++;if(mn>12){mn=1;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==4 && digitalRead(3)==HIGH){mn--;if(mn<1){mn=1;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==5 && digitalRead(2)==HIGH){gg++;if(gg>2099){gg=2099;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==5 && digitalRead(3)==HIGH){gg--;if(gg<2024){gg=2024;}clock.setDateTime(gg, mn, dd, hh, mm, ss);delay(200);}
  if(set==1&&millis()-times<200){lcd.print("  ");}else{lcd.print(hour/10%10);lcd.print(hour%10);}lcd.print(":");
  if(set==2&&millis()-times<200){lcd.print("  ");}else{lcd.print(minut/10%10);lcd.print(minut%10);}
  switch(den){
  if(set==3&&millis()-times<200){lcd.print("  ");}else{lcd.print(day/10%10);lcd.print(day%10);}lcd.print(".");
  if(set==4&&millis()-times<200){lcd.print("  ");}else{lcd.print(month/10%10);lcd.print(month%10);}lcd.print(".");
  if(set==5&&millis()-times<200){lcd.print("  ");}else{lcd.print(year/10%10);lcd.print(year%10);}
  if(millis()-times>400){times=millis();}
  delay(100);
59
http://forum.rcl-radio.ru/uploads/images/2024/04/3beb0ab08fdd8c603a326a43c51ea156.jpg
60
Коррекция часов, минут и даты происходит правильно, но нет коррекции дня недели. Год потерял первые две цифры.
61
Год поправил.
При коррекции цифры мигают?
 int svet;
 float temp,p,h;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  year=DateTime.year;
  day=DateTime.day;
  switch(den){
  if(set==5&&millis()-times<200){lcd.print("  ");}else{lcd.print(year);}
  delay(100);
62
Коррекции дня недели не бывает, DS3231 это же часы реального времени, они сами по дате определяют день недели
63
Да, при коррекции цифры мигают. Год отображается правильно.
64
Авто-яркость работает?
65
Авто-яркость не работает
66
Выход D10 это подсветка дисплея, все верно?
http://rcl-radio.ru/wp-content/uploads/2020/02/246347c54493232d221007a1c97941fe.png
Посмотрите монитор порта как меняется последний параметр при изменении освещения
67
да, верно, именно так как на фото. Ещё заметил мелкий косяк, при коррекции года мигают первые две цифры, но меняются последние две.
68
Поправил
 int svet;
 float temp,p,h;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  year=DateTime.year;
  day=DateTime.day;
  switch(den){
  delay(100);
69
70
http://forum.rcl-radio.ru/uploads/images/2024/04/39028852687baed9666fd506a676c4ee.jpg
не меняются постоянно 210
71
Нашел ошибку
 int svet;
 float temp,p,h;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  svet = map(analogRead(A4), 0,250,50,250);if(svet>250){svet=250;}
  year=DateTime.year;
  day=DateTime.day;
  switch(den){
  delay(100);
72
для надёжности проверил, залил старый скейч, авторегулировка подсветки работает.
73
 int svet;
 float temp,p,h;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  svet = map(analogRead(A2), 0,250,50,250);if(svet>250){svet=250;}
  year=DateTime.year;
  day=DateTime.day;
  switch(den){
  delay(100);
74
в старом скейче авторегулировка подсветки была реализована через функцию.
http://forum.rcl-radio.ru/uploads/images/2024/04/11d93c392404802ab1da0ceb343ea829.jpg
75
Сделал так же
 int svet;
 float temp,p,h;
 long times;
  pinMode(10,OUTPUT);
  clock.begin();
  bme.begin(0x76);
  pinMode(A2,INPUT);
  pinMode(4,INPUT);
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  svet = map(analogRead(A2), 0,100,10,250);if(svet>250){svet=250;}
  year=DateTime.year;
  day=DateTime.day;
  switch(den){
  delay(100);
