Тема: TM1637 + STM32FC103
Разработка библиотеки
STM32_TM1637 v1.0
Библиотека в архиве:
test.ino
#include <STM32_TM1637.h>
//  CLK      PB0
//  DIO      PB1
STM32_TM1637 tm;
int h=12;
byte p=0;
  tm.brig(7); // ЯРКОСТЬ 0...7
   tm.print_dec(h,p,  0b1111000,0,0,0);
   delay(1000);
  tm.print_dec(h,p,  h0,h1,h2,h3);
  int h = 0...9999
  byte p = 0...3 | 0 = 0000 1 = 000,0 2 = 00,00 3 = 0,000
      A
  F |   | B
     -G-
  E |   | C
      D
 h0 h1 h2 h3
   XGFEDCBA (X - запятая)
 0b00000000
STM32_TM1637.h
//  STM32_TM1637 v1.0
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  STM32_TM1637_H
#define  STM32_TM1637_H
#include <Arduino.h>
#define CLK      PB0
#define DIO      PB1
#define CODE0    0b10001000
#define CODE1    0x40
#define ADDR0    0xC0
class  STM32_TM1637
  public:
     STM32_TM1637();
void print_dec(int decimal, int pd, int h0, int h1, int h2, int h3);
void brig(byte br);
  private:
void dec(byte dig);
void stop();
void start();
byte qwer;
#endif
STM32_TM1637.cpp
STM32_TM1637::STM32_TM1637(){};
void STM32_TM1637::brig(byte br){
     qwer = br + CODE0;
void STM32_TM1637::dec(byte dig){
         for(int i = 0; i < 8; i++) {
           pinMode(CLK, OUTPUT);
           delayMicroseconds(100);
         if (dig & 0x01)
           pinMode(DIO, INPUT);
         else
           pinMode(DIO, OUTPUT);
           pinMode(CLK, INPUT);
           dig = dig >> 1;
           uint8_t ack = digitalRead(DIO);
         if (ack == 0)
void STM32_TM1637::stop(){
void STM32_TM1637::start(){
void STM32_TM1637::print_dec(int decimal, int pd,    int h0, int h1, int h2, int h3){
        start();dec(qwer);stop();start();dec(CODE1);stop();start();
        byte w;
        if(decimal<0){decimal = abs(decimal); w=0b01000000;}else{w=0b00000000;}
        int data0 = decimal/1000;
        int data1 = decimal/100%10;
        int data2 = decimal/10%10;
        int data3 = decimal%10;
        for(int n=0;n<4;n++){
        int data;
        if(n==0){data=data0;}
        if(n==1){data=data1;}
        if(n==2){data=data2;}
        if(n==3){data=data3;}
        switch(data){  // XGFEDCBA
        if(n==0){data0=data;}
        if(n==1){data1=data;}
        if(n==2){data2=data;}
        if(n==3){data3=data;}
        if(decimal<1000&&decimal>99){data0 = w;}
        if(decimal<100&&decimal>9){data0 = 0b00000000;data1 = w;}
        if(decimal<10){data0 = 0b00000000; data1 = 0b00000000; data2 = w;}
        switch(pd){
        case 0 : data0;data1;data2;data3;break;
        if(h0>0){data0 = h0;}
        if(h1>0){data1 = h1;}
        if(h2>0){data2 = h2;}
        if(h3>0){data3 = h3;}
        dec(ADDR0);dec(data0);dec(data1);dec(data2);dec(data3);stop();
Re: TM1637 + STM32FC103
STM32_TM1637 v1.1
//  CLK      PB0
//  DIO      PB1
STM32_TM1637 tm;
int h=23;
byte p=11;
   tm.print_dec(h,p,  0b01000000,-1,-1,-1);
   delay(1000);
  int h = 0...9999
  byte p = 0...3   (h=0) | 0  = ###0  1 = ###.0  2 = ##.#0  3 = #.##0 // # - пусто
  byte p = 10...13 (h=0) | 10 = 0000 11 = 000.0 12 = 00.00 13 = 0.000
      A
  F |   | B
     -G-
  E |   | C
      D
 h0 h1 h2 h3
 0b00000000 - пусто
 0b01000000 - минус
 -1         - символы не испольуются
ПРИМЕРЫ (# - пусто)
ЧИСЛО    ФУНКЦИЯ
0.012    tm.print_dec(12,13,  -1,-1,-1,-1);
 0.12    tm.print_dec(12,12,   0,-1,-1,-1);
   12    tm.print_dec(12,0,   -1,-1,-1,-1);
 0012    tm.print_dec(12,10,  -1,-1,-1,-1);
 -12.3   tm.print_dec(123,11, 0b01000000,-1,-1,-1);
 -#2.3   tm.print_dec(23,1,   0b01000000,-1,-1,-1);
 -02.3   tm.print_dec(23,11,  0b01000000,-1,-1,-1);
3
STM32_TM1637 v2.0
STM32_TM1637 tm(PB0,PB1);// CLK, DIO
float h=0.1;
byte p=1;
   tm.print_float(h,p,  0,0,0,0);
   delay(500);
  tm.print_float(h,p,  h0,h1,h2,h3);
  float h = -999...9999 | -0.99...0.999 | -9.99...99.99 | -99.9...999.9
  byte p = 0...3 - число знаков после запятой
      A
  F |   | B
     -G-
  E |   | C
      D
 h0 h1 h2 h3
 0b00000000
4
Добавлена функция print.time для вывода времени на индикатор с двоеточием.
Пример:
#include <STM32_TM1637.h> // http://forum.rcl-radio.ru/misc.php?action=pan_download&item=403&download=1
#include <uRTCLib.h>//https://github.com/Naguissa/uRTCLib.git
   uRTCLib rtc(0x68);
   // PB7 = SDA DS1307 (DS3231)
   // PB6 = SCL DS1307 (DS3231)
   // PB0 = CLK TM1637
   // PB1 = DIO TM1637
float h;
int i;
  // rtc.set(30, 37, 23, 2, 17, 12, 19);
  // RTCLib::set(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year)
   rtc.refresh();// опрос времни
   h = rtc.hour()*100 + rtc.minute();
   tm.print_time(h, 0);
   delay(500);
   tm.print_time(h, 1);
   delay(500);
i++;
if(i==10){i=0;tm.print_float(rtc.temp()/100,0 ,0b1111000,0,0,0);delay(2000);}// вывод температуры DS3231
5
Прочитал в  datasheet на эту микросхему, что она может опрашивать до 16 кнопок, но  нигде не нашёл примеров использования. Точно такая же ситуация и с tm1650 обе эти микросхемы очень часто используются в спутниковых ресиверах. Готовый корпус плюс блок питания хорошая основа для радиолюбителя.
