26
  lcd.init();
   lcd.backlight();
  Serial.begin(9600);Wire.begin(); lcd.begin(20,4);irrecv.enableIRIn(); // запускаем модуль IR
  audioChip.initialize(0,true);
  ADMUX  = 0b01100000; ADCSRA = 0b11010100; // http://rcl-radio.ru/?p=57478
  EEPROM.update(6,gain0);EEPROM.update(7,gain1);EEPROM.update(8,gain0);
27
Не весь код
28
  if(spek==0){
    }else{
      byte v1[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b01100};
      byte v2[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b01100, 0b01100};
      byte v3[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b01100, 0b01100, 0b01100};
      byte v4[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b01100, 0b01100, 0b01100, 0b01100};
      byte v5[8] = {0b00000, 0b00000, 0b00000, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100};
      byte v6[8] = {0b00000, 0b00000, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100};
      byte v7[8] = {0b00000, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100};
      byte v8[8] = {0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100, 0b01100};
  ///////////////////// управление ////////////////////////////////////////////////////
   if(digitalRead(10)==LOW){menu++;cl();;time=millis();w=1;w2=1;if(menu>4){menu=0;}}// меню
   if(digitalRead(11)==HIGH){in++;;cl();time=millis()-7000;w=1;w2=1;www=1;menu=4;if(in>2){in=0;};audio();}// КНОПКА ВЫБОРА ВХОДА IN
  if(ir.value==0x2FD708F){in++;cl();time=millis()-7000;w=1;w2=1;www=1;menu=4;if(in>1){in=0;};gr1=0;gr2=0;audio();}// IN
 /////////////////////// VOLUME //////////////
     lcd.setCursor(3,1);lcd.print("Volume  ");
     lcd.setCursor(9,1);lcd.print(" ");lcd.print(-62+vol);lcd.print(" ");lcd.setCursor(15,1);lcd.print("dB");vol_d=vol-14;
   if(w2==1){
   if(z1==1){lcd.setCursor(z0+2,2);lcd.write((uint8_t)0);lcd.setCursor(z0+1+2,2);lcd.print("   ");}}
   if(z1==3){lcd.setCursor(z0+2,2);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+2,2);lcd.write((uint8_t)2);}w2=0;}}
  ///////////////////  BASS  //////////////
   lcd.setCursor(3,1);lcd.print("MegaBass  ");
   lcd.setCursor(11,1);lcd.print(" ");lcd.print(bass*2);lcd.print(" ");lcd.setCursor(16,1);lcd.print("dB");bass_d=bass*2+15;
   if(w2==1){
   if(z1==1){lcd.setCursor(z0+5,2);lcd.write((uint8_t)0);lcd.setCursor(z0+1+5,2);lcd.print("   ");}}
   if(z1==3){lcd.setCursor(z0+5,2);lcd.write((uint8_t)1);}
   if(z1==2){lcd.setCursor(z0+5,2);lcd.write((uint8_t)2);}w2=0;}}
  ///////////////// TREBLE //////////////////
   lcd.setCursor(3,1);lcd.print("Treble  ");
   lcd.setCursor(11,1);lcd.print(" ");lcd.print(treb*2);lcd.print(" ");lcd.setCursor(15,1);lcd.print("dB");treb_d=treb*2+15;
   if(w2==1){
  //////////////// BALANSE  +\- 4 dB /////////////
     if(ir.value==0x2FD906F){balans++;gr1=1;gr2=0;cl();balans_func();audio();}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){balans++;gr2=0;cl();balans_func();audio();}// кнопка >>>>>>
     if(ir.value==0x2FDF20D){balans--;gr1=0;gr2=1;cl();balans_func();audio();}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){balans--;gr1=0;cl();balans_func();audio();}// кнопка <<<<<<
    balans=balans+newPosition;myEnc.write(0);newPosition=0;lcd.clear();time=millis();w=1;balans_func();audio();}
  lcd.setCursor(0,0);
  if(balans==0){lcd.print(" <>  ");}
  if(balans<0){lcd.print(" <   ");}
  if(balans>0){lcd.print("  >  ");}
  /////////// input + gain /////////////////////////////////////////
     case 0: gain = gain0;break;
     case 1: gain = gain1;break;
     case 2: gain = gain2;break;
     if(ir.value==0x2FD906F){gain++;gr1=1;gr2=0;cl();time=millis();w=1;w2=1;gain_func();audio();}// кнопка >
     if(ir.value==0xFFFFFFFF and gr1==1){gain++;gr2=0;cl();time=millis();w=1;;w2=1;gain_func();audio();}// кнопка >>>>>>
     if(ir.value==0x2FDF20D){gain--;gr1=0;gr2=1;cl();time=millis();w=1;w2=1;gain_func();audio();}// кнопка <
     if(ir.value==0xFFFFFFFF and gr2==1){gain--;gr1=0;cl();time=millis();w=1;w2=1;gain_func();audio();}// кнопка <<<<<<
    gain=gain+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;w2=1;gain_func();audio();}
     case 0: gain0 = gain;break;
     case 1: gain1 = gain;break;
     case 2: gain2 = gain;break;
   lcd.setCursor(0,0);lcd.print(" INPUT ");lcd.print(in);
   lcd.setCursor(0,1);lcd.print(" GAIN ");
      switch(gain){
        case 3: lcd.print(" +11.25 dB");break;
        case 2: lcd.print("   +7.5 dB");break;
        case 1: lcd.print("  +3.75 dB");break;
        case 0: lcd.print("      0 dB");break;
 // запись всех настроек в EEPROM если кнопки + и - не нажимались в течении 10 сек
 // если настройки тембра, баланса и номер входа не менялись в течении 10 сек, переход в рег. Громкости
     EEPROM.update(0,vol);
     EEPROM.update(4,balans+4);
     EEPROM.update(1,bass+7);
     EEPROM.update(3,treb+7);
     EEPROM.update(5,in);
     EEPROM.update(6,gain0); EEPROM.update(7,gain1); EEPROM.update(8,gain2);
 menu=100;lcd.clear();w=0;w2=1;cl();spek=1;
 if(spek==1){
  for (int pos = 0; pos < 15; pos++) {   // для окошек дисплея с 0 по 15
    lcd.setCursor(pos+2, 1);
  while(yyy<2){yyy++;
    if (posLevel > 7) {               // если значение больше 7 (значит нижний квадратик будет полный)
      lcd.setCursor(pos+2, 2);          // перейти на нижний квадратик
      lcd.print(" ");                 // верхний квадратик пустой
      lcd.setCursor(pos+2, 2);          // нижний квадратик
    }} yyy=0;
  if (AUTO_GAIN) {
      else gain_sp = 100;
      gainTimer = millis();
  }else{gain_sp = DEF_GAIN;}
29
}// LOOP
  audioChip.source(in);//select your source 1...3  вход 3...1
  audioChip.volume(vol);//Vol 0...62 шаг 1 дБ
  audioChip.gain(gain);//gain 0...3 шаг 3.75 дБ
  audioChip.bass(bass);//bass -7...+7 шаг 2 дБ
  audioChip.treble(treb);//treble -7...+7 шаг 2 дБ
  audioChip.balance(balans);//-31...+31 программно ограничено до +\-8 дБ
  audioChip.loudness(true);//true or false // тонкомпенсация
void gain_func(){if(gain<0){gain=3;}if(gain>3){gain=0;}}
void balans_func(){if(balans>4){balans=4;}if(balans<-4){balans=-4;}}
void vol_func(){if(vol<0){vol=0;}if(vol>62){vol=62;}}
void analyzeAudio() {
 while( i1 < FHT_N ) {  i1++;
    do{ADCSRA |= (1 << ADSC);}
    //fht_input[i1] = ADCH;
    }i1=0;
   {lcd.setCursor(2, 3); lcd.print("----------------");lcd.setCursor(2, 0); lcd.print("----------------");
    lcd.setCursor(1, 1); lcd.print("|");lcd.setCursor(1, 2); lcd.print("|");
    lcd.setCursor(18, 1); lcd.print("|");lcd.setCursor(18, 2); lcd.print("|");
30 (2020-01-25 14:14:06 отредактировано roline)
Не весь код
весь не дает... только кусками... по порядку
31
Пока не вижу ни чего такого, сделал правки, проверьте
#define LOW_PASS 30      // нижний порог чувствительности шумов (нет скачков при отсутствии звука)
#define DEF_GAIN 150       // максимальный порог по умолчанию
#define FHT_N 128        // ширина спектра х2
#define LOG_OUT 1
#include <FHT.h>
#include <PT2313.h>
#include <Encoder.h>
#include <IRremote.h>
LiquidCrystal_I2C lcd(0x27,20,4);
  PT2313 audioChip;
  Encoder myEnc(9, 8);//CLK, DT
 byte menu,in,w,w2,gr1,gr2,www,z,z0,z1;
 int vol,vol_d,bass,bass_d,treb,treb_d,balans,gain,gain0,gain1,gain2;
 unsigned long gainTimer;
 float k = 0.1;
 byte gain_sp = DEF_GAIN;
 int i1,yyy;
  lcd.init();
   lcd.backlight();
  if(spek==0){
    }else{
   if(w2==1){
   if(w2==1){
   if(w2==1){
  lcd.setCursor(0,0);
      switch(gain){
 if(spek==1){
  while(yyy<2){yyy++;
    }} yyy=0;
  if (AUTO_GAIN) {
      else gain_sp = 100;
  }// LOOP
  audioChip.initialize(1,true);
    }i1=0;
 //  {lcd.setCursor(2, 3); lcd.print("----------------");lcd.setCursor(2, 0); lcd.print("----------------");
  //  lcd.setCursor(1, 1); lcd.print("|");lcd.setCursor(1, 2); lcd.print("|");
 //   lcd.setCursor(18, 1); lcd.print("|");lcd.setCursor(18, 2); lcd.print("|");
32
Попробуйте запустить после подачи питания отключить i2c от аудиопроцессора.
33
писк остался,появились щелчки энкодера
34 (2020-01-25 14:27:46 отредактировано roline)
если откинуть PTшку от шины писк  исчезает. И щелчки энкодера тоже исчезают.
35
DGND 26 вывод PT соединен с общим GND?
36
да
37
А если общий провод разъеденить, DGND от арудино, а GND от источника питания сделать.
38
не меняется
39
Загрузите первый скетч со другим подключением экрана, Ваш экран работать конечно не будет, но надо убедится что это не он источник помех - http://forum.rcl-radio.ru/viewtopic.php?pid=56#p56
40
обратил внимание от ПТшки откидываю CLK- в одном динамике писк пропадает. DT - в дугом
41
дык я же вообще без него подключался... писк оставался
42
Дело не в подключении экрана, а то что Вы подключили библиотеку экрана которая работает на той же шине что и PT. скетч будет отсылать команды экрану даже если он не подключен.
43
афигеть... библиотека шумела,чтоли?откинул дисп полностью, поставил
#include <LiquidCrystal.h> и без дисплея включил... писка нет вообще...
44
Я сейчас то же использую дисплеи с i2c, мне просто лень столько проводов подключать в простом подключении (приходится часто разбирать и собирать схемы), но в Вашем случае я заметил такую особенность, что анализатор спектра при i2c подключении начинает притормаживать, работает рывками. Не хватает скорости шины для работы анализатора.
Так что наверное Вам придется использовать простое подключение экрана.
Так же обратите внимание на http://forum.rcl-radio.ru/viewtopic.php?id=104 - анализатор спектра для LCD2004.
45
сейчас перекоммутирую дисп.  жаль,хотел юзать меньше проводов, но не судьба.
спасибо за консультацию.
Еще вопрос - если  а0 не подключать, то при переходе в режим анализатора дуинка вешается... на энкодер не отвечает до ресета дуины. так и должно быть?
46
roline пишет:
Нет, так в принципе не должно быть, но эту проблему мне так и не удалось решить. Что то там связано с перегрузкой входа, библиотеку клинит, в ней встроено авто усиления уровня. Наверное как то в этим связано.
Есть конечно вариант применить другой код опроса А0, тогда проблем с этим не будет, но спектр немного станет уже.
http://rcl-radio.ru/?p=42903
47
еще раз спасибо! и удачи вам в вашем деле!
48
Чуток подправил скетч под экран 2004,загнал надписи и анализатор а рамку.
http://forum.rcl-radio.ru/uploads/images/2020/01/b0e7e16a99e4d7e006ad0b82bf22d5c7.jpg
http://forum.rcl-radio.ru/uploads/images/2020/01/7c5b965ac17f80cedf72714495aee774.jpg
http://forum.rcl-radio.ru/uploads/images/2020/01/0797d7d39c8436fadc7a959db7736088.jpg
http://forum.rcl-radio.ru/uploads/images/2020/01/26ede3090aff31146d4f8a9860d9bed3.jpg
http://forum.rcl-radio.ru/uploads/images/2020/01/f5d7edf1b02a1f46d0bb3c0950b38f8a.jpg
http://forum.rcl-radio.ru/uploads/images/2020/01/f5834f13085a0919ecd8ce4e49236cd2.jpg
49
Красиво получилось!!!
В анализатор спектра можно добавить одну полосу.
Питание на подсветку без резистора подаете?
50 (2020-01-25 19:46:28 отредактировано roline)
когда добавляю, то паразитная полоска анализатора цепляет рамку...и они весело перемигиваются то кусок рамки,то анализатор. где исправить не нашел( ...на 1602 паразитная полоска за пределами экрана.
