Тема: Библиотека ESP32_TM1637_4LED
esp32tm16374led.zip
ESP32_TM1637_4LED.h
//  ESP32_TM1637_4LED
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  ESP32_TM1637_4LED_H
#define  ESP32_TM1637_4LED_H
#include <Arduino.h>
#define CODE0    0b10001000
#define CODE1    0x40
#define ADDR0    0xC0
class  ESP32_TM1637_4LED
    public:
  ESP32_TM1637_4LED(uint8_t, uint8_t);
  void print(int t, byte pd_t,   int h0, int h1, int h2, int h3);
  void brig(byte br);
    private:
  void dec(byte dig);
  void stop();
  void start();
  void del();
  byte qwer;
  uint8_t DIO;
  uint8_t CLK;
#endif
ESP32_TM1637_4LED.cpp
#include <ESP32_TM1637_4LED.h>
ESP32_TM1637_4LED::ESP32_TM1637_4LED(uint8_t clk, uint8_t dio){
         CLK = clk;
         DIO = dio;
void ESP32_TM1637_4LED::brig(byte br){
     qwer = br + CODE0;
void ESP32_TM1637_4LED::del(){delayMicroseconds(100);}
void ESP32_TM1637_4LED::dec(byte dig){
       for(int i = 0; i < 8; i++) {
         pinMode(CLK,OUTPUT);del();
       if (dig & 0x01)
         pinMode(DIO,INPUT);
       else
         pinMode(DIO,OUTPUT);del();
         pinMode(CLK,INPUT);del();
         dig = dig >> 1;
         pinMode(DIO,INPUT);del();
       if (digitalRead(DIO) == 0)
void ESP32_TM1637_4LED::stop(){
void ESP32_TM1637_4LED::start(){
void ESP32_TM1637_4LED::print(int t, byte pd_t,   int h0, int h1, int h2, int h3){
        start();dec(qwer);stop();start();
        dec(CODE1);stop();start();
        int data0 = t / 1000 % 10;
        int data1 = t / 100 % 10;
        int data2 = t / 10 % 10;
        int data3 = t % 10;
      for(byte n = 0; n < 4; n++){
        int data;
      switch(n){
        case 0: data = data0;break;
        case 1: data = data1;break;
        case 2: data = data2;break;
        case 3: data = data3;break;
      switch(data){    // XGFEDCBA
        if(n == 0){data0 = data;}
        if(n == 1){data1 = data;}
        if(n == 2){data2 = data;}
        if(n == 3){data3 = data;}
      switch(pd_t){
        if(h0>=0){data0 = h0;}
        if(h1>=0){data1 = h1;}
        if(h2>=0){data2 = h2;}
        if(h3>=0){data3 = h3;}
      dec(0xC0);dec(data0);dec(data1);dec(data2);dec(data3);stop();
test.ino
  ESP32_TM1637_4LED  tm(12,13);// CLK, DIO
  delay(100);
  tm.brig(7); // яркость 0...7
  tm.print(100,0,  0b01111000,-1,-1,-1);
  delay(100);
tm.print(x, dp,    h0, h1, h2, h3);
x — число от 0 до 9999
dp — положение запятой от 0 до 3
h0-h3 — замена цифры на символ
h0-h3 = -1 замена цифры не происходит
Для замены цифры символом можно использовать следующие значения:
0                   //  (пусто)
0b01000000  // — (минус)
0b01110111   // A
0b01111100   // b
0b00111001  // C
0b01011110  // d
0b01111001  // E
0b01110001  // F
0b01111000  // t
0b01110011  // P
XGFEDCBA
0b00000000
http://forum.rcl-radio.ru/uploads/images/2022/01/7649cff9e1cb48cee7ef17c8980aca12.png
