Тема: CS3310 - Stereo Digital Volume Control
Features
Complete Digital Volume Control
2 Independent Channels
— Serial Control
— 0.5 dB Step Size
Wide Adjustable Range
— -95.5 dB Attenuation
— +31.5 dB Gain
Low Distortion & Noise
— 0.001% THD+N
— 116 dB Dynamic Range
Noise Free Level Transitions
Channel-to-Channel Crosstalk Better Than 110 dB
datasheet.pdf
http://forum.rcl-radio.ru/uploads/images/2020/05/4e56bff41d83cacd0632e2a36f8782b5.png
http://forum.rcl-radio.ru/uploads/images/2020/05/10751bef417c60d033677607035b79ab.png
http://forum.rcl-radio.ru/uploads/images/2020/05/c41c65cf63314985570b7f83166cf8c7.png
http://forum.rcl-radio.ru/uploads/images/2020/05/107e11d73cdbf6f5db20bf33e90f3e78.png
cs3310.zip
test.ino
#include <CS3310.h>
CS3310 cs(2,3,4);//CS,SCLK,SDATAI
  delay(100);
void loop(){}
  cs.setVol(200,200);
  // byte 0  === mute
  // byte 1...255 === -95.5...+31.5 dB (step 0.5 dB)
CS3310.h
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  CS3310_H
#define  CS3310_H
#include <Arduino.h>
class  CS3310
    public:
  CS3310(uint8_t, uint8_t, uint8_t);
  void setVol(byte r, byte l);
    private:
  uint8_t CS;
  uint8_t SCLK;
  uint8_t SDATAI;
#endif
CS3310.cpp
#include <CS3310.h>
CS3310::CS3310(uint8_t cs, uint8_t sclk, uint8_t sdatai){
            CS = cs;
            SCLK = sclk;
            SDATAI = sdatai;
      pinMode(CS,OUTPUT);
      pinMode(SCLK,OUTPUT);
      pinMode(SDATAI,OUTPUT);
void CS3310::setVol(byte r, byte l){
     // start
     digitalWrite(CS,HIGH);
     digitalWrite(SCLK,HIGH);
     delay(2);
     digitalWrite(CS,LOW);
     //  R
  for(int i = 7; i >= 0; i--){
        digitalWrite(SCLK,LOW);//delay(1);
        digitalWrite(SDATAI, (r >> i) & 0x01);delay(1);
        digitalWrite(SCLK,HIGH);delay(1);
     //  L
        digitalWrite(SDATAI, (l >> i) & 0x01);delay(1);
   // end
Re: CS3310 - Stereo Digital Volume Control
http://forum.rcl-radio.ru/uploads/images/2020/05/60ef81cf6ff197690bfee2ecb84efb85.png
#include <Encoder.h>  // http://rcl-radio.ru/wp-content/uploads/2019/05/Encoder.zip
#include <CS3310.h>
  Encoder myEnc(9, 8);//CLK, DT
  int vol,vol_d,z,z0,z1;
  byte w,w1;
  lcd.init();lcd.backlight();
  lcd.setCursor(0,0);lcd.print("     CS3310   ");delay(3000);lcd.clear();// ЗАСТАВКА
  vol = EEPROM.read(0);
   vol=vol+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;vol_func();audio();Serial.print(vol*0.5-96,1);Serial.print(" ");Serial.println(vol);}
   vol_d=map(vol,0,255,0,45);
   if(w1==1){
   if(z1==2){lcd.setCursor(z0,1);lcd.write((uint8_t)2);}w1=0;}
     if(vol*0.5-96>=0){lcd.print("+");}
     lcd.print(vol*0.5-96,1);lcd.print(" ");
     lcd.setCursor(14,0);lcd.print("dB");
//     delay(10);
 //////// EEPROM //////////////////////////////////////////////////
  if(millis()-times>3000 && w==1){EEPROM.update(0,vol);w=0;}
  } // LOOP
  cs.setVol(vol,vol);
  // byte 0  === mute
void vol_func(){if(vol<0){vol=0;}if(vol>255){vol=255;}
3
mute
#include <CS3310.h>
  int vol,vol_d,z,z0,z1,vol_old;
  byte w,w1,mute;
  pinMode(7,INPUT);
   if (newPosition != oldPosition&&mute==0){oldPosition = newPosition;
   if(w1==1){
   if(digitalRead(7)==LOW&&mute==0){mute=1;vol_old=vol;vol=0;audio();lcd.clear();lcd.setCursor(0,0);lcd.print("      MUTE   ");delay(300);}
   if(digitalRead(7)==LOW&&mute==1){mute=0;vol=vol_old;      audio();lcd.clear();w1=1;delay(300);}
   if(mute==0){
     lcd.setCursor(14,0);lcd.print("dB");}
//     delay(10);
  } // LOOP
  cs.setVol(vol,vol);
  // byte 0  === mute
4
Интересная тема...Делал РГ на этой микре,хорошая вещь,но диапазон регулировки громкости в большинстве случаев сильно избыточен,неплохо бы иметь возможность ограничивать его,как сверху,так и снизу,или через меню настроек или перед прошивкой какие то константы менять.
5
Эта функция ограничивает диапазон регулировки:
например:
void vol_func(){if(vol<20){vol=20;}if(vol>200){vol=200;}
Диапазон регулировки будет не 255 шагов а 180, можно и меньше сделать
6
Я заметил , что вы как то любите дисплеи 1602 . Как то вы не любите цветные дисплеи , хотя на них все очень здорово смотрится .http://forum.rcl-radio.ru/uploads/images/2020/05/615f74746a4d80ec6cbfd23b2d883c5b.jpg http://forum.rcl-radio.ru/uploads/images/2020/05/bf91353c2f6831357dbd91b20002ef71.jpg http://forum.rcl-radio.ru/uploads/images/2020/05/b8f676a8232f93f9454a8fe75f62b70d.jpg
7
Я делал проекты на ftf экранах для аудиопроцессоров с большим набором параметров, но все же на LCD1602 больше проектов повторяют, да и дешевле.
http://rcl-radio.ru/wp-content/uploads/2019/07/623786862187.png
http://rcl-radio.ru/wp-content/uploads/2019/04/7523965782368.png
8
Ну здесь на мой взгляд как то слишком много информации сразу выведено . Это чисто мое мнение , это как будто панель управления станка ЧПУ.http://forum.rcl-radio.ru/uploads/images/2020/05/bc7bf22400528a271fff16aeaba277f7.jpg  Вот здесь как то более гармонично смотрится .
9
Все можно сделать, но пока на подобные проекты с FTF экранами интересных предложений мне не поступало.
10
Понял , спасибо за ответ .
11
Еще раз убедился на практике,что полный диапазон регулировки нужно ограничивать , в ряде случаев приводит к подвозбуду оконечников и подгоранию резистора в цобеле,когда кто то сдуру загонит регулировку в +31дб,даже при отсутствии сигнала.
12
liman324 пишет:
Все можно сделать.....
Приветствую! Подскажите плииз, я правильно понимаю что эта библиотека может  использоваться для всех регуляторов с похожим протоколом управления ? в частности PGA4311 ?
достаточно только в
объявить не 2, а 4 канала ?
void setVol(byte ch4, byte ch3, byte ch2, byte ch1);  = норм ?
а может вообще плясок с библиотекой не устраивать ? объявить пины и к ним переделанный на 4 канала CS3310.cpp ???
или  не получится ?
13
CS3310.cpp
#include <CS3310.h>
            CS = cs;
            SCLK = sclk;
            SDATAI = sdatai;
      pinMode(CS,OUTPUT);
     // start
     delay(2);
   //  ch1
        digitalWrite(SDATAI, (ch1 >> i) & 0x01);delay(1);
     //  ch2
        digitalWrite(SDATAI, (ch2 >> i) & 0x01);delay(1);
     //  ch3
        digitalWrite(SDATAI, (ch3 >> i) & 0x01);delay(1);
     //  ch4
        digitalWrite(SDATAI, (ch4 >> i) & 0x01);delay(1);
   // end
14
CS3310.h
//  Alexander Liman
//  rcl-radio.ru
#ifndef  CS3310_H
#define  CS3310_H
class  CS3310
    public:
  void setVol(byte ch1, byte ch2, byte ch3, byte ch4);
    private:
  uint8_t CS;
  uint8_t SCLK;
  uint8_t SDATAI;
#endif
15
Не проверял, но должно работать для PGA4311
