Тема: MP3 плеер +arduino+oled1.3"
Доброго Всем времени суток.
Пытаюсь найти схему и скетч MP3 плеера для установки в корпус самодельного усилителя.Китайские декодеры не интересны (эстетически). Есть такой вот проект:
///              MP3 PLAYER PROJECT
/// http://educ8s.tv/arduino-mp3-player/
#include "SoftwareSerial.h"
SoftwareSerial mySerial(10, 11);
# define Start_Byte 0x7E
# define Version_Byte 0xFF
# define Command_Length 0x06
# define End_Byte 0xEF
# define Acknowledge 0x00 //Returns info with command 0x41 [0x01: info, 0x00: no info]
# define ACTIVATED LOW
int buttonNext = 2;
int buttonPause = 3;
int buttonPrevious = 4;
boolean isPlaying = false;
void setup () {
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause,HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext,HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious,HIGH);
mySerial.begin (9600);
delay(1000);
playFirst();
isPlaying = true;
void loop () {
if (digitalRead(buttonPause) == ACTIVATED)
    if(isPlaying)
      pause();
      isPlaying = false;
    }else
      isPlaying = true;
      play();
if (digitalRead(buttonNext) == ACTIVATED)
    if(isPlaying)
      playNext();
   if (digitalRead(buttonPrevious) == ACTIVATED)
    if(isPlaying)
      playPrevious();
void playFirst()
  execute_CMD(0x3F, 0, 0);
  delay(500);
  setVolume(20);
  delay(500);
  execute_CMD(0x11,0,1);
  delay(500);
void pause()
  execute_CMD(0x0E,0,0);
  delay(500);
void play()
  execute_CMD(0x0D,0,1);
  delay(500);
void playNext()
  execute_CMD(0x01,0,1);
  delay(500);
void playPrevious()
  execute_CMD(0x02,0,1);
  delay(500);
void setVolume(int volume)
  execute_CMD(0x06, 0, volume); // Set the volume (0x00~0x30)
  delay(2000);
void execute_CMD(byte CMD, byte Par1, byte Par2)
// Excecute the command and parameters
// Calculate the checksum (2 bytes)
word checksum = -(Version_Byte + Command_Length + CMD + Acknowledge + Par1 + Par2);
// Build the command line
byte Command_line[10] = { Start_Byte, Version_Byte, Command_Length, CMD, Acknowledge,
Par1, Par2, highByte(checksum), lowByte(checksum), End_Byte};
//Send the command line to the module
for (byte k=0; k<10; k++)
mySerial.write( Command_line[k]);
но в нем не подцеплен экран и функционал у DFplayer Mini намного больше, регулирование громкости, работа с плей листом и т.д.
В общем очень бы хотелось чтобы знающий человек посмотрел на это.
Спасибо.
Re: MP3 плеер +arduino+oled1.3"
Что-то типа такого? https://www.instructables.com/How-to-Ma … rduino-an/
Спасибо большое за отклик.
Но к сожалению скетч не компилируется. А так все бы устраивало. выдает очень много ошибок.
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino: In function 'void setup()':
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:48:5: error: 'flashPage' was not declared in this scope
     flashPage();
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:57:53: error: 'leftButtonISR' was not declared in this scope
   attachInterrupt(digitalPinToInterrupt(leftButton),leftButtonISR, FALLING);
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:57:53: note: suggested alternative: 'leftButton'
                                                     leftButton
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:58:54: error: 'rightButtonISR' was not declared in this scope
   attachInterrupt(digitalPinToInterrupt(rightButton),rightButtonISR, FALLING);
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:58:54: note: suggested alternative: 'rightButton'
                                                      rightButton
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:84:3: error: 'startFolderPlay' was not declared in this scope
   startFolderPlay();
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino: In function 'void loop()':
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:100:3: error: 'batteryReader' was not declared in this scope
   batteryReader();
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:100:3: note: suggested alternative: 'batteryLevel'
   batteryReader();
   batteryLevel
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:184:13: error: 'player' was not declared in this scope
             player();
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:184:13: note: suggested alternative: 'playing'
             player();
             playing
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:187:13: error: 'settings' was not declared in this scope
             settings();
C:\Users\Vlad Rudakov\Downloads\soundpod (1)\soundpod (1).ino:187:13: note: suggested alternative: 'String'
             settings();
             String
exit status 1
Compilation error: 'flashPage' was not declared in this scope
4 (2024-01-03 12:02:54 отредактировано Nesco)
Удалось скомпилировать (Ctrl+R) в arduino 1.8.19 файлик soundpod.ino ,
но с предупреждением "Недостаточно памяти, программа может работать нестабильно."
Скачать все файлы с исходниками ino и один jpg в папку для скетча.https://github.com/DKARDU/MP3/tree/main)
Скачивать лучше целиком файлами. Когда делаете копию части текста с веб странички - бывает копируется куча управляющих символов, которые в Arduino Ide не видно глазом. Потом вываливаются непонятные ощибки.
Выбрать плату Arduino Nano, процессор Atmega 328P (Old BootLoader)
Установить билиотеки “DFRobotDFPlayerMini” и ”U8g2”.
После этого должно скомпилироваться.
Но программка конечно не простая.
5
MP3 уходит в историю. Есть ли возможность использовать формат с контейнерами M4A или AAC? Они меньше по размеру, а качество звучания намного приятнее.
