26
Re: TDA7439 + OLED_1.3+IR+ENCODER
#define ENC_DT       8
#define ENC_CLK      9
#define ENC_SW       10
#define IR           12
#define MENU      0x33B820DF // button encoder
#define UP        0x33B810EF // >>>
#define DW        0x33B8E01F // <<<
#define INPUT_IR  0x33B88877 // IN
#define POWER_IR  0x33B800FF // POWER
#define MUTE_IR   0x33B811FF // MUTE
#define IN            2
#define POWER         6
#define POWER_OUT_PIN 13
#define MUTE          3
#define IN1_OUT   A0
#define IN2_OUT   A1
#define IN3_OUT   A2
#define IN4_OUT   A3
#include <TDA7439.h>
TDA7439 tda;
IRrecv irrecv(IR);
long oldPosition  = -999,newPosition, times;
int vol_reg,balans,treb_reg,bass_reg,mid_reg,in_reg,gain0,gain1,gain2,gain3,gain4,menu,vol_old;
bool gr1,gr2,w=1,w1,www,power,power_off=1,mute;
  irrecv.enableIRIn();
  pinMode(ENC_SW,INPUT);
  pinMode(IN,INPUT_PULLUP);
  pinMode(MUTE,INPUT_PULLUP);
  pinMode(POWER,INPUT_PULLUP);
  pinMode(POWER_OUT_PIN,OUTPUT);
  pinMode(IN1_OUT,OUTPUT);
  pinMode(IN2_OUT,OUTPUT);
  pinMode(IN3_OUT,OUTPUT);
  pinMode(IN4_OUT,OUTPUT);
  vol_reg = EEPROM.read(0);treb_reg = EEPROM.read(1)-7;mid_reg = EEPROM.read(2)-7;bass_reg = EEPROM.read(3)-7;
  in_reg = EEPROM.read(4);gain1 = EEPROM.read(5);gain2 = EEPROM.read(6);gain3 = EEPROM.read(7);gain4 = EEPROM.read(8);balans = EEPROM.read(9)-8;
  switch(in_reg){
    case 1: gain0=gain1;break;
    case 2: gain0=gain2;break;
    case 3: gain0=gain3;break;
    case 4: gain0=gain4;break;
   if(in_reg==1){digitalWrite(IN1_OUT,HIGH);}else{digitalWrite(IN1_OUT,LOW);}
   if(in_reg==2){digitalWrite(IN2_OUT,HIGH);}else{digitalWrite(IN2_OUT,LOW);}
   if(in_reg==3){digitalWrite(IN3_OUT,HIGH);}else{digitalWrite(IN3_OUT,LOW);}
   if(in_reg==4){digitalWrite(IN4_OUT,HIGH);}else{digitalWrite(IN4_OUT,LOW);}
   else{digitalWrite(IN1_OUT,LOW);digitalWrite(IN2_OUT,LOW);digitalWrite(IN3_OUT,LOW);digitalWrite(IN4_OUT,LOW);}
// BUTTON ///////////////////////////////////////////////////
 if((digitalRead(POWER)==LOW||ir.value==POWER_IR||power_off==1)&&power==0&&mute==0){power_off=0;power=1;menu=100;cl();vol_old=vol_reg;vol_reg=0;audio();
  u8g.firstPage();do {u8g.setFont(u8g_font_profont12r);u8g.drawStr(40,30,"POWER OFF");} while( u8g.nextPage() );
  delay(1500); u8g.firstPage();do {} while( u8g.nextPage() );}
 if((digitalRead(POWER)==LOW||ir.value==POWER_IR)&&power==1){power=0;menu=0;vol_reg=vol_old;times=millis();w=1;w1=1;
  u8g.firstPage();do {u8g.drawStr(42,30,"POWER ON");} while( u8g.nextPage() );delay(1500);audio();}
if(power==0){digitalWrite(POWER_OUT_PIN,HIGH);}else{digitalWrite(POWER_OUT_PIN,LOW);}
 if(digitalRead(ENC_SW)==LOW||ir.value==MENU){menu++;cl();if(menu>4){menu=0;}times=millis();w=1;w1=1;delay(200);}
 if(digitalRead(IN)==LOW||ir.value==INPUT_IR){menu=10;cl();in_reg++;times=millis();w=1;w1=1;www=1;if(in_reg>4){in_reg=1;};delay(200);}
 if((digitalRead(MUTE)==LOW||ir.value==MUTE_IR)&&mute==0){mute=1;menu=100;cl();vol_old=vol_reg;vol_reg=0;audio();
     u8g.firstPage();do {u8g.setFont(u8g_font_profont12r);u8g.drawStr(53,30,"MUTE");} while( u8g.nextPage() );}
 if((digitalRead(MUTE)==LOW||ir.value==MUTE_IR)&&mute==1){mute=0;times=millis();w=1;w1=1;menu=0;cl();vol_reg=vol_old;audio();}
   vol_reg=vol_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;vol_func();audio();}
   if(ir.value==UP){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){vol_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){vol_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){vol_reg--;gr1=0;cl();times=millis();w=1;w1=1;vol_func();audio();}// кнопка <<<<<<
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"VOLUME");u8g.drawStr(0,18,"IN");
  u8g.setPrintPos(20, 18);u8g.print(in_reg);u8g.drawStr(0,28,"GAIN");u8g.setPrintPos(30, 28);u8g.print(gain0);
  u8g.drawLine(0, 32, 128, 32);
  u8g.drawStr(0,44,"TREBLE");u8g.setPrintPos(80, 44);u8g.print(treb_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"MIDDLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"BASS");u8g.setPrintPos(80, 64);u8g.print(bass_reg*2);u8g.drawStr(95,64,"dB");
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(vol_reg);
//////// TRABLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
   treb_reg=treb_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;treb_func();audio();}
   if(ir.value==UP){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){treb_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){treb_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){treb_reg--;gr1=0;cl();times=millis();w=1;w1=1;treb_func();audio();}// кнопка <<<<<<
   if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(treb_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"TREBLE");u8g.drawStr(0,44,"MIDDLE");u8g.setPrintPos(80, 44);u8g.print(mid_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"BASS");u8g.setPrintPos(80, 54);u8g.print(bass_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"BALANCE");u8g.setPrintPos(80, 64);u8g.print(balans);u8g.drawStr(95,64,"dB");
//////// MIDDLE //////////////////////////////////////////////////////////////////////////////////////////////////////////////
   mid_reg=mid_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;mid_func();audio();}
   if(ir.value==UP){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){mid_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){mid_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){mid_reg--;gr1=0;cl();times=millis();w=1;w1=1;mid_func();audio();}// кнопка <<<<<<
   if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(mid_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"MIDDLE");u8g.drawStr(0,44,"BASS");u8g.setPrintPos(80, 44);u8g.print(bass_reg*2);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"BALANCE");u8g.setPrintPos(80, 54);u8g.print(balans);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"VOLUME");u8g.setPrintPos(80, 64);u8g.print(vol_reg);u8g.drawStr(95,64,"dB");
   bass_reg=bass_reg+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;bass_func();audio();}
   if(ir.value==UP){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){bass_reg++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){bass_reg--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){bass_reg--;gr1=0;cl();times=millis();w=1;w1=1;bass_func();audio();}// кнопка <<<<<<
 if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(bass_reg*2);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BASS");
  u8g.drawStr(0,44,"BALANCE");u8g.setPrintPos(80, 44);u8g.print(balans);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"VOLUME");u8g.setPrintPos(80, 54);u8g.print(vol_reg);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"TREBLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
  if (newPosition != oldPosition){oldPosition = newPosition;balans=balans+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;ball_func();audio();}
   if(ir.value==UP){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){balans++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка >>>>>>
   if(ir.value==DW){balans--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){balans--;gr1=0;cl();times=millis();w=1;w1=1;ball_func();audio();}// кнопка <<<<<<
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"BALANCE");u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(abs(balans));
  if(balans<=0){u8g.drawStr(50,20,"LCH");}
  if(balans>=0){u8g.drawStr(105,20,"RCH");}
  u8g.drawStr(0,44,"VOLUME");u8g.setPrintPos(80, 44);u8g.print(vol_reg);u8g.drawStr(95,44,"dB");
  u8g.drawStr(0,54,"TREBLE");u8g.setPrintPos(80, 54);u8g.print(mid_reg*2);u8g.drawStr(95,54,"dB");
  u8g.drawStr(0,64,"MIDDLE");u8g.setPrintPos(80, 64);u8g.print(treb_reg*2);u8g.drawStr(95,64,"dB");
 if(menu==10){
  switch(in_reg){
   gain0=gain0+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;w1=1;www=1;gain_func();}
   if(ir.value==UP){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >
   if(ir.value==0xFFFFFFFF and gr1==1){gain0++;gr1=1;gr2=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка >>>>>>
   if(ir.value==DW){gain0--;gr1=0;gr2=1;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <
   if(ir.value==0xFFFFFFFF and gr2==1){gain0--;gr1=0;cl();times=millis();w=1;w1=1;gain_func();www=1;}// кнопка <<<<<<
  switch(in_reg){
    case 1: gain1=gain0;break;
    case 2: gain2=gain0;break;
    case 3: gain3=gain0;break;
    case 4: gain4=gain0;break;
  if(www==1){audio();www=0;}
  if(w==1){w=0;
  u8g.firstPage();
   do {
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 22);u8g.print(in_reg);
  u8g.setFont(u8g_font_profont12r);u8g.drawStr(0,8,"INPUT");u8g.drawStr(0,44,"GAIN");
  u8g.setFont(u8g_font_profont29r); u8g.setPrintPos(78, 60);u8g.print(gain0);
if(millis()-times>5000 && w1==1 && power==0 && mute==0){
     EEPROM.update(0,vol_reg);EEPROM.update(1,treb_reg+7);EEPROM.update(2,mid_reg+7);EEPROM.update(3,bass_reg+7);
     EEPROM.update(4,in_reg);EEPROM.update(5,gain1);EEPROM.update(6,gain2);EEPROM.update(7,gain3);EEPROM.update(8,gain4);EEPROM.update(9,balans+8);
void vol_func(){if(vol_reg<0){vol_reg=0;}if(vol_reg>48){vol_reg=48;}}
void treb_func(){if(treb_reg<-7){treb_reg=-7;}if(treb_reg>7){treb_reg=7;}}
void mid_func(){if(mid_reg<-7){mid_reg=-7;}if(mid_reg>7){mid_reg=7;}}
void bass_func(){if(bass_reg<-7){bass_reg=-7;}if(bass_reg>7){bass_reg=7;}}
void gain_func(){if(gain0>15){gain0=15;}if(gain0<0){gain0=0;}}
void ball_func(){if(balans>8){balans=8;}if(balans<-8){balans=-8;}}
  tda.setInput(in_reg); // 1 to 4 // номер канала
  tda.setVolume(vol_reg); // 0 to 48 ( 0 is mute) // громкость
  tda.setSnd(bass_reg, 1); //-7 to +7 , 1 - Bass | 2 - Mids | 3 - Trebble
  tda.setSnd(mid_reg, 2);
  tda.setSnd(treb_reg, 3);
  tda.spkAtt(8 + balans ,8 - balans); // баланс R L от 0 to 79 (db)
27
Использую этот скетч от 2023-11-23 20:03:32
28
#define ENC_DT       8
#define ENC_CLK      9
#define ENC_SW       10
#define IR           12
#define IN            2
#define POWER         6
#define MUTE          3
#define IN1_OUT   A0
#define IN2_OUT   A1
#define IN3_OUT   A2
#define IN4_OUT   A3
TDA7439 tda;
IRrecv irrecv(IR);
  switch(in_reg){
  digitalWrite(POWER_OUT_PIN,HIGH);delay(1000);digitalWrite(POWER_OUT_PIN,LOW);
  audio();}
  if(w==1){w=0;
  u8g.firstPage();
   do {
   if(w==1){w=0;
  u8g.firstPage();
   do {
   if(w==1){w=0;
  u8g.firstPage();
   do {
 if(w==1){w=0;
  u8g.firstPage();
   do {
  if(w==1){w=0;
  u8g.firstPage();
   do {
 if(menu==10){
  switch(in_reg){
  switch(in_reg){
  if(w==1){w=0;
  u8g.firstPage();
   do {
29
Добрый день. Подскажите  в чем проблема. Собрал схему (пока  еще без ИК модуля). Заливаю скетч, на экране белые точки. Экран проверял,  из примеров HelloWorld выводится. Сканером I2C видно адреса TDA7439 и экрана.
30
какую библиотеку и скетч использовали?
31 (2026-02-28 21:41:10 отредактировано RIGOR81)
Скетч из примеров в Арудуину ИДЕ. Библиотека U8glib.
Вот с этими строками работало
//U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NONE);    // I2C / TWI
//U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_FAST);    // Dev 0, Fast I2C / TWI
//U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_NO_ACK);    // Display which does not send ACK
Экран менял.  LGT8F328P вначале была зеленая платка, поменял на фиолетовую. Ничего непоменялось.
32
Не вижу причин почему не работает
Попробуйте очистить память принудительно.
замените
на
for(int i=0;i<101;i++){EEPROM.update(i,0);}
33
Ни чего не изменилось. Возможно я неправильно настроил ардуино ИДЕhttp://forum.rcl-radio.ru/uploads/images/2026/02/a22432adebe86760578ed9516a816bd8.jpg
http://forum.rcl-radio.ru/uploads/images/2026/02/88b51b9ea01aa69b89cde6229e33fbce.jpg
http://forum.rcl-radio.ru/uploads/images/2026/02/39d61ff02dd57e6ee4cc87e2fb71bcdd.jpg
34
driver 1 а не 16
35
Огромное спасибо, заработало.
36
Подскажите еще один вопрос. Энкодер при вращении в лево, идет увиличение, в право уменьшение во всех режимах. Как это исправить?
37
Всем спасибо, разобрался сам как сделать.
38
#define ENC_DT       8
#define ENC_CLK      9
#define ENC_SW       10
#define IR           12
заменить на
#define ENC_DT       9
#define ENC_CLK      8
#define ENC_SW       10
#define IR           12
39
Я сделал так:
Encoder myEnc(ENC_CLK, ENC_DT)  (было Encoder myEnc(ENC_DT, ENC_CLK)
40
Благодарю Вас за проделанную работу!
41
Александр здравствуйте, можно убрать из программы кнопку POWER OFF/ON. Спасибо
