Тема: LCD1602_I2C_LOW
http://rcl-radio.ru/wp-content/uploads/ … 2c_low.zip
Lcd1602_i2c_low.h
// rcl-radio.ru liman324@yandex.ru
// Atmega8
// Atmega48
// Atmega88
// Atmega168
// Atmega328
#ifndef Lcd1602_i2c_low_H
#define Lcd1602_i2c_low_H
#include <Arduino.h>
class Lcd1602_i2c_low{
public:
Lcd1602_i2c_low(uint8_t);
void setInit();
void Clear();
void Curs(byte str, byte mesto);
void PrintString(const char* str);
void PrintChar(const char chr);
void led(bool led_on_off);
void PrintInt(int data_int);
void PrintFloat(float data_float, byte dp);
void Write(byte addr_w, byte wr1,byte wr2,byte wr3,byte wr4,byte wr5,byte wr6,byte wr7,byte wr8);
private:
uint8_t ADDR_LED;
void i2c_write_1bit(byte a);
void lcd(uint8_t sett);
void lcdSend(bool rs, byte data);
void e_pin();
#endif //Lcd1602_i2c_lowLcd1602_i2c_low.cpp
#include <avr/io.h>
#include <util/delay.h>
#include <Wire_low.h>
#include <Lcd1602_i2c_low.h>
#define RS 0
#define E 2
#define LED 3
byte led_b;
Lcd1602_i2c_low::Lcd1602_i2c_low(uint8_t addr_led){
ADDR_LED = addr_led;
void Lcd1602_i2c_low::led(bool led_on_off){
if(led_on_off==1){i2c_write_1bit(led_b |= (1<<LED));}
if(led_on_off==0){i2c_write_1bit(led_b &=~ (1<<LED));}
void Lcd1602_i2c_low::Write(byte addr_w, byte wr1,byte wr2,byte wr3,byte wr4,byte wr5,byte wr6,byte wr7,byte wr8){
lcd(0b01000000|addr_w*8);PrintChar(wr1);PrintChar(wr2);PrintChar(wr3);PrintChar(wr4);PrintChar(wr5);PrintChar(wr6);PrintChar(wr7);PrintChar(wr8);}
void Lcd1602_i2c_low::PrintInt(int data_int){char str[6];PrintString(itoa(data_int, str, 10));}
void Lcd1602_i2c_low::PrintFloat(float data_float, byte dp){
char str[8];
if(data_float<0){data_float=-data_float;PrintChar(0b101101);PrintString(itoa((int)data_float, str, 10));}
else{PrintString(itoa((int)data_float, str, 10));}
int float10 = round((data_float - (int)data_float)*pow(10,dp));
PrintChar(0b101110);
PrintString(itoa(float10, str, 10));
void Lcd1602_i2c_low::setInit(){
lcd(0x03);_delay_us(4500);
lcd(0x03);_delay_us(200);
lcd(0b00000010);_delay_ms(5);
lcd(0b00001100);_delay_ms(5);
lcd(0b00000001);
void Lcd1602_i2c_low::Clear(){lcd(0b00000001);}
void Lcd1602_i2c_low::Curs(byte str, byte mesto){
void Lcd1602_i2c_low::PrintString(const char* str) {while(*str != '\0') {_delay_us(200);PrintChar(*str);str++;}}
void Lcd1602_i2c_low::PrintChar(const char chr) {lcdSend(false, (uint8_t)chr);}
void Lcd1602_i2c_low::e_pin(){
i2c_write_1bit(led_b |= (1<<E));
_delay_us(200);
i2c_write_1bit(led_b &= ~(1<<E));
void Lcd1602_i2c_low::lcd(uint8_t sett) {lcdSend(true, sett);}
void Lcd1602_i2c_low::lcdSend(bool rs, byte data) {
// cli();
if(rs==0){led_b |= (1<<RS);} else {led_b &= ~(1<<RS);}//RS
_delay_us(200);
if(((data >> 7) & 1) ==1){i2c_write_1bit(led_b |= (1<<7));} else {i2c_write_1bit(led_b &= ~(1<<7));}
if(((data >> 6) & 1) ==1){i2c_write_1bit(led_b |= (1<<6));} else {i2c_write_1bit(led_b &= ~(1<<6));}
if(((data >> 5) & 1) ==1){i2c_write_1bit(led_b |= (1<<5));} else {i2c_write_1bit(led_b &= ~(1<<5));}
if(((data >> 4) & 1) ==1){i2c_write_1bit(led_b |= (1<<4));} else {i2c_write_1bit(led_b &= ~(1<<4));}
e_pin();
if(((data >> 3) & 1) ==1){i2c_write_1bit(led_b |= (1<<7));} else {i2c_write_1bit(led_b &= ~(1<<7));}
if(((data >> 2) & 1) ==1){i2c_write_1bit(led_b |= (1<<6));} else {i2c_write_1bit(led_b &= ~(1<<6));}
if(((data >> 1) & 1) ==1){i2c_write_1bit(led_b |= (1<<5));} else {i2c_write_1bit(led_b &= ~(1<<5));}
if(((data >> 0) & 1) ==1){i2c_write_1bit(led_b |= (1<<4));} else {i2c_write_1bit(led_b &= ~(1<<4));}
e_pin();
// sei();
void Lcd1602_i2c_low::i2c_write_1bit(byte i2c_reg){
wire_start_w(ADDR_LED);
wire_write(i2c_reg);
wire_stop();
} test.ino
// ATMEGA8 ATMEGA48 ATMEGA88 ATMEGA168 ATMEGA328
#include <avr/io.h>
Lcd1602_i2c_low lcd(0x27);// адрес I2C
int main(){
wire_set(12000000,100000); // тактовая частота контроллера, частота шины I2C
lcd.setInit();
lcd.Clear(); // очистка экрана
lcd.led(1); // включение и отключение подсветки экрана
// собственные символы, 0...7
lcd.Write(0, 0b11111,
0b00000,
0b10001,
0b10001,
0b10001,
0b10001,
0b00000,
0b11111);
lcd.Write(1, 0b11111,
0b10001,
0b11111,
0b10001,
0b11111,
0b10001,
0b11111,
0b00000);
while(1){
lcd.Curs(0,0); // номер строки, положение курсора
lcd.PrintString("ATMEGA88 ");// вывод String
lcd.PrintFloat(1.227,3); // вывод Float
lcd.Curs(1,4); // номер строки, положение курсора
lcd.PrintInt(-30125); // вывод int
lcd.PrintChar(0); // вывод собственного символа 0
lcd.PrintChar(1); // вывод собственного символа 1
_delay_ms(100);
