Тема: Интернет часы ESP8266 + TFT 3'2 SPI
Основная статья - http://rcl-radio.ru/?p=67569
#include <NTPClient.h>
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <UTFT.h>
#include <SPI.h>
 WiFiUDP ntpUDP;
 NTPClient timeClient(ntpUDP, "pool.ntp.org", 21600);
 extern uint8_t BigFont[],SmallFont[];
 UTFT myGLCD ( ILI9341_S5P, 13, 14, 15, 0, 12 );//SDI (MOSI), SCK, CS, RESET, DC == D7 D5 D8 D3 D6
 const char *ssid     = "Keenetic-9009";
 const char *password = "32481975";
 String date_time;
 float sx,sy,osx,osy,mx,my,omx,omy,hx,hy,ohx,ohy;
 unsigned long times;
  WiFi.mode(WIFI_STA);WiFi.begin(ssid, password);
  while ( WiFi.status() != WL_CONNECTED ) {
    delay(500);Serial.print(".");
    timeClient.begin();}
  myGLCD.InitLCD(0);myGLCD.fillRect(0,0,320,240);myGLCD.setFont(BigFont);myGLCD.clrScr(); // первоначальные настройки экрана
  myGLCD.fillScr(0x0000);myGLCD.setColor(0xffff);myGLCD.setBackColor(0x0000);
   for(int i=0;i<360;i+=30){
    sx=cos((i-90)*0.0174532925);
    sy=sin((i-90)*0.0174532925);
    myGLCD.drawLine(sx*120+120,sy*120+120,sx*110+120,sy*110+120);}
   for(int i=0;i<360;i+=6){
    myGLCD.drawPixel(sx*115+120,sy*115+120);}
  if(millis()-times>=1000){times=millis();
 int hh = timeClient.getHours();
 int mm = timeClient.getMinutes();
 int ss = timeClient.getSeconds();
  date_time = timeClient.getFormattedDate();
 int index_date = date_time.indexOf("T");
 String date = date_time.substring(0, index_date);
  hx=cos(((hh*30+mm*6*0.08333333)-90)*0.0174532925);
  hy=sin(((hh*30+mm*6*0.08333333)-90)*0.0174532925);
  mx=cos(((mm*6+ss*6*0.01666667)-90)*0.0174532925);
  my=sin(((mm*6+ss*6*0.01666667)-90)*0.0174532925);
  sx=cos((ss*6-90)*0.0174532925);
  sy=sin((ss*6-90)*0.0174532925);
 myGLCD.setColor(0x0000);// clear
 myGLCD.drawLine(osx,osy,120,120);
 myGLCD.drawLine(omx,omy,120,120);
 myGLCD.drawLine(ohx,ohy,120,120);
 myGLCD.print("12",104,0);
 myGLCD.print("6",112,225);
 myGLCD.print("9",0,112);
 myGLCD.print("3",224,112);
  ohx = hx*70+120;
  ohy = hy*70+120;
  omx = mx*100+120;
  omy = my*100+120;
  osx = sx*110+120;
  osy = sy*110+120;
 myGLCD.setColor(0xf000);
 myGLCD.setColor(0xfff5);
 myGLCD.fillCircle(120,120,4);
 myGLCD.print(timeClient.getFormattedTime(),60,275);
 myGLCD.print(date,45,295);
 }//loop
Re: Интернет часы ESP8266 + TFT 3'2 SPI
При проверке прошивки выдает ошибка Ошибка компиляции для платы Generic ESP8266 Module.
3
http://rcl-radio.ru/?p=48790
4
Разместите текст ошибок.
5
Привет. При запуске программы сразу выскакивает сообщение. Попробую еще дома на другом компе. Я думаю при ошибке в программе были сообщения.
C:\Program Files (x86)\Arduino\arduino-builder возвратил 2
Ошибка компиляции для платы NodeMCU 0.9 (ESP-12 Module).
6
Привет. Дома все отлично ,программа прошла. Но есть проблема . У меня дисплей 380х240 ili9341 spi . Где делать исправления.
7
myGLCD.fillRect(0,0,380,240);
Если есть возможность опубликуйте фото экрана чтобы было понято что делать.
8
Экран белый.
9
Стал белый после корректировки разрешения или был всегда белым?
10
ОН и был белый как залил прошивку.
11
Логин и пароль сети указали свой?
12
С программами для теста дисплея работал.
13
библиотеку установили которая указана на сайте к статье? Надо устанавливать именно эту, она специальная для ESP8266 + TFT 3'2 SPI - http://rcl-radio.ru/wp-content/uploads/ … w_UTFT.zip
14
Нажмите кнопку подписаться на форуме, что бы сразу получать сообщения об новых ответах.
15
Все как указано в описании .
16
Пока вижу только две причины
1. Нет соединения wi-fi и программа вошла в бесконечный цикл пытаясь подключится к роутеру
2. Ошибка подключения экрана к модулю esp
17
Дайте описание подключения дисплея ( Ваше) . lsd--
sck
sdi
dc
reset
итд
18
Вся информация в строке:
19
Я как вторую неделю этим занялся.
20
Выводы экрана должны соответствовать выводам esp
D7               D5    D8  D3       D6
21
Так и есть , экран белый.
22
Проверьте эти строчки:
пока других идей нет, буду думать.
23
Вывод LED куда?
24
+3,3В
25
При включении должно же  что то появляться или нет? wi-fi тут плохой и подключения нет.
