Тема: DS3231 с выводом в монитор порта
#define ADDR 0b1101000
#define CPU_F 16000000 // Clock Speed
#define SCL_F 100000 // // I2C Speed
/// uart init /////
#define BAUD 9600 // USART Speed
// Serial.begin(9600);
TWSR = 0;
USART_Init(CPU_F/16/BAUD-1);
// set_time(21,5,4,29,9,57,0);// год 00-99, ДН 1-7 (1=ВС), месяц 1-12, дата 1-31, час 0-23, минуты 0-59, секунды 0-59
byte sec = (i2c_read(ADDR,0) & 0x0F) + (((i2c_read(ADDR,0) & 0x70) >> 4) * 10);
byte min = (i2c_read(ADDR,1) & 0x0F) + (((i2c_read(ADDR,1) & 0x70) >> 4) * 10);
byte hour = ((i2c_read(ADDR,2) & 0x0F) + ((i2c_read(ADDR,2) & 0x70) >> 4) * 10);
byte day = (i2c_read(ADDR,3) & 0x0F);
byte datat = ((i2c_read(ADDR,4) & 0x0F) + ((i2c_read(ADDR,4) & 0x70) >> 4) * 10);
byte mont = ((i2c_read(ADDR,5) & 0x0F) + ((i2c_read(ADDR,5) & 0x70) >> 4) * 10);
byte year = ((i2c_read(ADDR,6) & 0x0F) + ((i2c_read(ADDR,6) & 0x70) >> 4) * 10);
int temper = (i2c_read(ADDR,0x11)*100 + ((i2c_read(ADDR,0x12) & 0b11000000) >> 6)*25) ;
USART_int(hour);USART_String(":");
USART_int(min);USART_String(":");
USART_int(sec);USART_String(" ");
USART_int(datat);USART_String("-");
USART_int(mont);USART_String("-");
USART_int(year);USART_String(" ");
USART_int(day);USART_String(" ");
USART_int(temper/100);USART_String(".");
USART_int(temper%10);USART_String(" C\n");
delay(1000);
byte i2c_read(byte i2c_addr, byte i2c_reg){
TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // START
while (!(TWCR & (1<<TWINT)));
TWDR = i2c_addr << 1;
TWDR = i2c_reg;
TWDR = (i2c_addr << 1) | 1;
byte i2c_data = TWDR;
TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO); // СТОП
return i2c_data;
void i2c_write(byte i2c_addr, byte i2c_reg, byte i2c_dat){
TWDR = i2c_reg;
TWDR = i2c_dat;
if(second < 255){i2c_write(ADDR,0x00,(second/10<<4)+second%10);}
if(minute < 255){i2c_write(ADDR,0x01,(minute/10<<4)+minute%10);}
if(hours < 255){i2c_write(ADDR,0x02,(hours/10<<4)+hours%10);}
if(days < 255){i2c_write(ADDR,0x03,days);}
if(datas < 255){i2c_write(ADDR,0x04,(datas/10<<4)+datas%10);}
if(monts < 255){i2c_write(ADDR,0x05,(monts/10<<4)+monts%10);}
if(years < 255){i2c_write(ADDR,0x06,(years/10<<4)+years%10);}
void USART_Init( unsigned int ubrr ){
UBRR0H = (unsigned char)(ubrr>>8);
UBRR0L = (unsigned char)ubrr;
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
UCSR0C = (1<<USBS0)|(3<<UCSZ00);
void USART_String(char *data){
for(int i=0;i<strlen(data);i++){
while(!( UCSR0A & (1 << UDRE0 )));
UDR0 = data[i];}
void USART_int(int to_int){
String stringVar = String(to_int, DEC);
char charVar[sizeof(stringVar)];
stringVar.toCharArray(charVar, sizeof(charVar));
USART_String(charVar);}Скетч использует 2812 байт (19%) памяти устройства. Всего доступно 14336 байт.
Глобальные переменные используют 31 байт (3%) динамической памяти, оставляя 993 байт для локальных переменных. Максимум: 1024 байт.
