Тема: AD7714
http://forum.rcl-radio.ru/uploads/images/2020/06/eab0bf4e0d928fa6558cab6bab57c140.gif
#include <SPI.h>
// SS    10 // CS
// MOSI  11 // DIN
// MISO  12 // DOUT
// SCK   13 // SCLK
// RESET  7
// DRDY   8
// POL, AVdd, DVdd, SYNC,STANDBY = VCC
// AGDN, DGDN,REF IN(-), BUFFER = GND
// REF IN(+) = +1.25...2.5 V
#define RESET 7
#define DRDY 8
long bt24,hi,mid,lo;
int in = 0b001; // Channel Selection AIN1_AIN6
// Pseudo Differential
// AIN1_AIN6 = 0b000
// AIN2_AIN6 = 0b001
// AIN3_AIN6 = 0b010
// AIN4_AIN6 = 0b011
// Fully Differential
// AIN1_AIN2 = 0b100
// AIN3_AIN4 = 0b101
// AIN5_AIN6 = 0b110
  pinMode(DRDY,INPUT); // DRDY
  pinMode(RESET,OUTPUT);// RESET
  digitalWrite(RESET,LOW);
  SPI.beginTransaction(SPISettings(SPI_CLOCK_DIV2, MSBFIRST, SPI_MODE3));
  SPI.begin();
  digitalWrite(RESET,HIGH);
  delay(300);
  Write();
  Read();
  Serial.println(bt24);
void Write(){
  digitalWrite(SS, LOW);
  delayMicroseconds(1);
/////////////// Filter High Register /////////////////////////////////////////////
  // BU WL BST CLKDIS FS11 FS10 FS9 FS8
  // BU   1 UNIPOLAR, 0 BIPOLAR
  // WS   0 = 16 bit, 1 = 24 bit
  // BST  2.4576 MHz BST=0, 1.0000 MHz BST=1
  // CLKDIS   0 (от кварца)
  // FSx  HIGH 4 BITS FILTER (12 BITS)
  SPI.transfer(0b00100000 + in); // Communications Register >  Filter High Register
  SPI.transfer(0b11100001); //  Filter High Register
////////////// Filter Low Register //////////////////////////////////////////////
  // FS7 FS6 FS5 FS4 FS3 FS2 FS1 FS0
  // LOW 8 BITS FILTER (12 BITS)
  SPI.transfer(0b00110000 + in); // Communications Register >  Filter Low Register
  SPI.transfer(0b10000000); //  Filter Low Register
  // 2.4576 MHz / 128 / 4000 (111110100000) = 4.8 Hz
  // FS11...FS8 1111, FS7...FS0 10100000
//////////////// Mode Register /////////////////////////////////////////////////
  // MD2 MD1 MD0 G2 G1 G0 BO FSYNC
  // MDx  Operating Mode
  // Gx   Gain Setting 000...111 = 1...128 GAIN
  // 000 = x1, 001 = x2, 010 = x4, 011 = x8, 100 = x16, 101 = x32, 110 = x64, 111 = x128
  // BO, FSYNC = 0
  SPI.transfer(0b00010000 + in); // Communications Register > Mode Register
  SPI.transfer(0b00100000); // Mode Register //  MDx = 001 Self-Calibration
  digitalWrite(SS, HIGH);
  delay(10);
void Read(){
  while(digitalRead(DRDY)!=LOW);
         SPI.transfer(0b01011000 + in);
         hi = SPI.transfer(0xFF);
         hi = hi<<16;
         mid = SPI.transfer(0xFF);
         mid = mid<<8;
         lo = SPI.transfer(0xFF);
         bt24 = hi | mid | lo;
         while(digitalRead(DRDY)!=HIGH);
         delay(10);
Re: AD7714
Ни как не могу понять как считывать данные с других входов.
3
Re: AD7714
Re: AD7714
Не так понял как одновременно считывать с 2-х каналов
liman324 пишет:
5
Re: AD7714
Только поочереди
int in = 0b001;
Read();
int in = 0b010;
Read();
Re: AD7714
Черт, ничего не получается, если можно сделайте готовый код.
7
Re: AD7714
#include <SPI.h>
// SS    10 // CS
// MOSI  11 // DIN
// MISO  12 // DOUT
// SCK   13 // SCLK
// RESET  7
// DRDY   8
#define RESET 7
#define DRDY 8
  SPI.begin();
  delay(300);
in = 0b001;
 Write();
Read();
in = 0b010;
 Write();
Read();
void Write(){
  // BO, FSYNC = 0
  delay(10);
void Read(){
         hi = hi<<16;
         mid = mid<<8;
         delay(10);
Re: AD7714
http://forum.rcl-radio.ru/uploads/images/2020/10/41fd3960727f17332d6021d39b938724.png
Проблема в том что используются 2 оператора in.
9
Re: AD7714
Я поправил скетч
Re: AD7714
Спасибо, а то я дня 3 не мог заставить ее работать. http://forum.rcl-radio.ru/uploads/images/2020/10/53b5a098c7f85f18c7a0a534ff080f1b.png
