Тема: Тест TM1637
#include <Arduino.h>
#include <TM1637Display.h>
// Module connection pins (Digital Pins)
#define CLK 2
#define DIO 3
// The amount of time (in milliseconds) between tests
#define TEST_DELAY   2000
const uint8_t SEG_DONE[] = {
    SEG_B | SEG_C | SEG_D | SEG_E | SEG_G,           // d
    SEG_A | SEG_B | SEG_C | SEG_D | SEG_E | SEG_F,   // O
    SEG_C | SEG_E | SEG_G,                           // n
    SEG_A | SEG_D | SEG_E | SEG_F | SEG_G            // E
TM1637Display display(CLK, DIO);
void setup()
void loop()
  int k;
  uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
  display.setBrightness(0x0f);
  // All segments on
  display.setSegments(data);
  delay(TEST_DELAY);
  // Selectively set different digits
  data[0] = 0b01001001;
  data[1] = display.encodeDigit(1);
  data[2] = display.encodeDigit(2);
  data[3] = display.encodeDigit(3);
  for(k = 3; k >= 0; k--) {
    display.setSegments(data, 1, k);
    delay(TEST_DELAY);
  display.setSegments(data+2, 2, 2);
  delay(TEST_DELAY);
  display.setSegments(data+2, 2, 1);
  delay(TEST_DELAY);
  display.setSegments(data+1, 3, 1);
  delay(TEST_DELAY);
  // Show decimal numbers with/without leading zeros
  bool lz = false;
  for (uint8_t z = 0; z < 2; z++) {
    for(k = 0; k < 10000; k += k*4 + 7) {
        display.showNumberDec(k, lz);
        delay(TEST_DELAY);
    lz = true;
  // Show decimal number whose length is smaller than 4
  for(k = 0; k < 4; k++)
    data[k] = 0;
    // Run through all the dots
    for(k=0; k <= 4; k++) {
        display.showNumberDecEx(0, (0x80 >> k), true);
        delay(TEST_DELAY);
  display.showNumberDec(153, false, 3, 1);
  delay(TEST_DELAY);
  display.showNumberDec(22, false, 2, 2);
  delay(TEST_DELAY);
  display.showNumberDec(0, true, 1, 3);
  delay(TEST_DELAY);
  display.showNumberDec(0, true, 1, 2);
  delay(TEST_DELAY);
  display.showNumberDec(0, true, 1, 1);
  delay(TEST_DELAY);
  display.showNumberDec(0, true, 1, 0);
  delay(TEST_DELAY);
  // Brightness Test
    data[k] = 0xff;
  for(k = 0; k < 7; k++) {
    display.setBrightness(k);
    delay(TEST_DELAY);
  // On/Off test
  for(k = 0; k < 4; k++) {
    display.setBrightness(7, false);  // Turn off
    delay(TEST_DELAY);
    display.setBrightness(7, true); // Turn on
    delay(TEST_DELAY);
  // Done!
  display.setSegments(SEG_DONE);
  while(1);
Re: Тест TM1637
тест работает
3
Re: Тест TM1637
http://forum.rcl-radio.ru/uploads/images/2019/11/a9ac5638919a866cc44ce32bceb5fa81.jpg
