	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Serial Port tda7719]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=94&amp;type=atom" />
	<updated>2020-02-13T14:12:53Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=94</id>
			<title type="html"><![CDATA[Re: Serial Port tda7719]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=925#p925" />
			<content type="html"><![CDATA[<p><span class="attention-yellow"></span> </p><br /><div class="codebox"><pre><code>#include &quot;TEF6686.h&quot;
#include &lt;Wire.h&gt;
#include &lt;EEPROM.h&gt;
#include &lt;BD37033FV.h&gt;
#include &lt;FlexiTimer2.h&gt; // http://forum.rcl-radio.ru/misc.php?action=pan_download&amp;item=298&amp;download=1
#include &lt;Encoder.h&gt;
  BD37033FV tda;
int frequency;
int volume;
uint8_t isRDSReady;
char programTypePrevious[17] = &quot; &quot;;
char programServicePrevious[9];
char radioTextPrevious[65];
boolean isFmSeekMode;
boolean isFmSeekUp;
int vol,treb,mid,bas,lon,mix,bas_f,mid_f,treb_f,lon_f, att_f1,att_f2,att_r1,att_r2,in,set_in,save;
int buff[2], w,w0,i,param,data,www,f,f1,w2=1;
unsigned long times,newPosition,oldPosition  = -999;
TEF6686 radio;
RdsInfo rdsInfo;
    Serial.begin(115200);
    FlexiTimer2::set(3, flash);  FlexiTimer2::start();
    vol = EEPROM.read(0);treb = EEPROM.read(1);mid = EEPROM.read(2);bas = EEPROM.read(3);in = EEPROM.read(4);
    lon = EEPROM.read(5);mix = EEPROM.read(6);bas_f = EEPROM.read(7);mid_f = EEPROM.read(8);treb_f = EEPROM.read(9);
    lon_f = EEPROM.read(10);att_f1 = EEPROM.read(11);att_f2 = EEPROM.read(12);att_r1 = EEPROM.read(13);att_r2 = EEPROM.read(14);
    set_in = EEPROM.read(15);
    radio.init();
    radio.powerOn();
    radio.setFrequency(10210);
    frequency = radio.getFrequency();
    displayInfo();
    audio();delay(100);
  while (Serial.available()&gt;0){
    for (i=0;i&lt;1;i++) {
      buff[0] = Serial.parseInt();
      buff[1] = Serial.parseInt();}
      w=1;w0=1;times=millis();}
      if(w==1){w=0;
param = buff[0]/100;
data = buff[0]-(buff[0]/100)*100;
switch(param){
  case 10: vol = data;audio();break; // 1000...1094 vol громкость
  case 11: treb = data;audio();break; // 1100...1130 treb тембр  ВЧ
  case 12: mid = data;audio();break; // 1200...1230 mid тембр  CЧ
  case 13: bas = data;audio();break; // 1300...1330 bas тембр  НЧ
  case 14: lon = data;audio();break; // 1400...1415 lon loudness
  case 15: set_in = data;if(set_in == 0){in = 0,mix = 2;}
                         if(set_in == 1){in = 1,mix = 0;}
           audio();break; // 1500 или 1501 0 = 2.0.0.0 in 0 | 1 = 0.0.0.0 in 1
  case 16: bas_f = data;audio();break; // 1600...1603 bas_f центральная частота НЧ
  case 17: mid_f = data;audio();break; // 1700...1703 mid_f центральная частота CЧ
  case 18: treb_f = data;audio();break; // 1800...1803 treb_f центральная частота BЧ
  case 19: lon_f = data;audio();break; // 1900...1903 lon_f центральная частота loudness
  case 20: att_f1 = data;audio();break; // 2000...2015 att_f1 front 1
  case 21: att_f2 = data;audio();break; // 2100...2115 att_f2 front 2
  case 22: att_r1 = data;audio();break; // 2200...2215 att_r1 rear 1
  case 23: att_r2 = data;audio();break; // 2300...2315 att_r2 rear 2
  case 50: save = data;break; // 5001 - save запись в EEPROM
  case 30:
    if(data==1){w2=1;frequency = radio.seekUp();readRds();showFmSeek();}
    if(data==2){w2=1;frequency = radio.seekDown();readRds();showFmSeek();}
    if(data==3){w2=1;frequency = radio.tuneUp();readRds();showFmSeek();}
    if(data==4){w2=1;frequency = radio.tuneDown();readRds();showFmSeek();}
    if(data==5){w2=1; radio.powerOn();showFmSeek();}
    if(data==6){w2=1;radio.powerOff();showFmSeek();}
    break;
   case 31: w2=1;volume = data;radio.setVolume(volume-60);readRds();showFmSeek();break; // 3100...3184
   case 60: f=data;break; // 5000...5040 === 60 + 0...50 = 60...110 MHz
   case 51: f1=data;www=1;break; // 5100...5099 === f+f1
   if(www==1){www=0;w2=1;radio.setFrequency( (f+55)*100 + f1 );frequency
= radio.getFrequency();}// 5041 = 101 5150 = 50 ==== 10150
   if(w2==1){w2=0;displayInfo();}
//Serial.print(vol);Serial.println(&quot; &quot;);
//////////// EEPROM ////////////////////////////////////////////////////////////////////////////////////
  if(save==1){save=0;
     EEPROM.update(0,vol);EEPROM.update(1,treb);EEPROM.update(2,mid);EEPROM.update(3,bas);EEPROM.update(4,in);
     EEPROM.update(5,lon);EEPROM.update(6,mix);EEPROM.update(7,bas_f);EEPROM.update(8,mid_f);EEPROM.update(9,treb_f);
     EEPROM.update(10,lon_f);EEPROM.update(11,att_f1);EEPROM.update(12,att_f2);EEPROM.update(13,att_r1);EEPROM.update(14,att_r2);
     EEPROM.update(15,set_in);
    oldPosition = newPosition;
    vol=vol-newPosition;myEnc.write(0);newPosition=0;w=1;if(vol&lt;0){vol=0;}if(vol&gt;94){vol=94;}audio();}
}// loop
        tda.setInitial();
        tda.setSub_setup(0,0,0); // off 55hz 85hz 120hz 160hz pass = int sub_f(0...5) || LPF front rear sub = int sub_out(0...3) 0 - default || 0 180 = int faza(0...1)
        tda.setLoud_f(mix,lon_f,0,0); // mix_in off || 400hz 800hz 2400hz Prohibition = int loud_f(0...3) || MIXING 1ch 2ch -- on off = mix_ch1(0...1) mix_ch2(0..1)
        tda.setIn(in); // in1 in2 in3 = int in(0...2)
        tda.setIn_gain(0,0); // 0...16 dB = int in_gain(0...16) || off on = int mute(0...1)
        tda.setVol(-vol+15); // -79...+15 dB = int vol(-79...15)
        tda.setFront_1(att_f1); // -79...+15 dB = int -79...15
        tda.setFront_2(att_f2); // -79...+15 dB = int -79...15
        tda.setRear_1(att_r1); // -79...+15 dB = int -79...15
        tda.setRear_2(att_r2); // -79...+15 dB = int -79...15
        tda.setSub1(0); // -79...+15 dB = int -79...15
        tda.setSub2(0); // -79...+15 dB = int -79...15
        tda.setBass_setup(0,bas_f); // 0.5 1.0 1.5 2.0 --- int 0...3, 60Hz 80Hz 100Hz 120Hz --- int 0...3
        tda.setMiddle_setup(0,mid_f); // 0.75 1.0 1.25 1.5 --- int 0...3, 500Hz 1kHz 1.5kHz 2.5kHz --- int 0...3
        tda.setTreble_setup(0,treb_f); // 0.75 1.25  --- int 0...1, 7.5kHz 10kHz 12.5kHz 15kHz --- int 0...3
        tda.setBass_gain(bas); // --15 ... +15 dB = int -15 ... 15
        tda.setMiddle_gain(mid-15); // --15 ... +15 dB = int -15 ... 15
        tda.setTreble_gain(treb-15); // --15 ... +15 dB = int -15 ... 15
        tda.setLoudness_gain(lon); // 0 ... 15 dB = int 0 ... 15
void flash(){newPosition = myEnc.read()/2;}
void readRds() {
isRDSReady = radio.readRDS();
radio.getRDS(&amp;rdsInfo);
showPTY();
showPS();
showRadioText();
void showPTY() {
if ((isRDSReady == 1) &amp;&amp; !strcmp(rdsInfo.programType,
programTypePrevious, 16)) {
Serial.print(rdsInfo.programType);
strcpy(programTypePrevious, rdsInfo.programType);
Serial.println();
void showPS() {
if ((isRDSReady == 1) &amp;&amp; (strlen(rdsInfo.programService) == 8) &amp;&amp;
!strcmp(rdsInfo.programService, programServicePrevious, 8)) {
Serial.print(&quot;-=[ &quot;);
Serial.print(rdsInfo.programService);
Serial.print(&quot; ]=-&quot;);
strcpy(programServicePrevious, rdsInfo.programService);
Serial.println();
void showRadioText() {
if ((isRDSReady == 1) &amp;&amp; !strcmp(rdsInfo.radioText, radioTextPrevious, 65)){
Serial.print(rdsInfo.radioText);
strcpy(radioTextPrevious, rdsInfo.radioText);
Serial.println();
bool strcmp(char* str1, char* str2, int length) {
for (int i = 0; i &lt; length; i++) {
if (str1[i] != str2[i]) {
return false;}}
return true;}
void showFmSeek() {
if (isFmSeekMode) {
if (radio.seekSync(isFmSeekUp)) {
isFmSeekMode = false;
Serial.println(&quot;Seek stopped&quot;);
void displayInfo() {
    delay(10);
    Serial.print(&quot;Frequency:&quot;);
    Serial.println(&quot;&lt;FREQ:&quot;+String(frequency*0.01)+&quot;&gt;&quot;);
    Serial.print(&quot; Volume:&quot;);
    Serial.println(volume);
    Serial.print(&quot;Level:&quot;);
    Serial.println(radio.getLevel() / 10);
    Serial.print(&quot;Stereo:&quot;);
    Serial.println(radio.getStereoStatus());
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=925#p925</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=924#p924" />
			<content type="html"><![CDATA[<div class="codebox"><pre><code>#include &lt;Wire.h&gt;
 BD37033FV tda;
int buff[2], w,w0,i,param,data;
void setup(){Serial.begin(115200);Wire.begin();
if(w==1){w=0;
switch(param){
// ОТПРАВКА В МОНИТОР ПОРТА
  Serial.println(vol);
  if(save==1){save=0;
}// loop
        tda.setInitial();
void flash(){newPosition = myEnc.read()/2;}  </code></pre></div>]]></content>
			<updated>2020-02-13T14:02:15Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=924#p924</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=905#p905" />
			<content type="html"><![CDATA[<div class="codebox"><pre><code>#include &quot;TEF6686.h&quot;
int frequency;
int volume;
uint8_t isRDSReady;
boolean isFmSeekUp;
TEF6686 radio;
RdsInfo rdsInfo;
while (!Serial);
Serial.println(&quot;Begin&quot;);
radio.init();
radio.powerOn();
     if(w==1){w=0;
switch(param){
  case 30:
   if(data==5){w2=1;isFmSeekMode = true;isFmSeekUp = true;readRds();showFmSeek();}
   if(data==6){w2=1;isFmSeekMode = true;isFmSeekUp = false;readRds();showFmSeek();}
   break;
  case 50: f=data;break; // 5000...5040 === 60 + 0...50 = 60...110 MHz
  if(www==1){www=0;w2=1;radio.setFrequency( (f+60)*100 + f1 );frequency = radio.getFrequency();}// 5041 = 101 5150 = 50 ==== 10150
}// loop
void readRds() {
showPTY();
showPS();
showRadioText();
void showPTY() {
if ((isRDSReady == 1) &amp;&amp; !strcmp(rdsInfo.programType, programTypePrevious, 16)) {
Serial.println();
void showPS() {
if ((isRDSReady == 1) &amp;&amp; (strlen(rdsInfo.programService) == 8) &amp;&amp; !strcmp(rdsInfo.programService, programServicePrevious, 8)) {
Serial.println();
Serial.println();
return false;
return true;
void showFmSeek() {
if (isFmSeekMode) {
   delay(10);
   Serial.print(frequency);
			<updated>2020-02-07T02:11:59Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=905#p905</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=765#p765" />
BD37033FV tda;
unsigned long times;
int vol;
if(w==1){w=0;
switch(param){
//Serial.println(param);
//Serial.println(data);
}// loop
        tda.setInitial();
        tda.setLoud_f(3,0,0,0); // mix_in off || 400hz 800hz 2400hz Prohibition = int loud_f(0...3) || MIXING 1ch 2ch -- on off = mix_ch1(0...1) mix_ch2(0..1)
        tda.setIn(0); // in1 in2 in3 = int in(0...2)
        tda.setFront_1(0); // -79...+15 dB = int -79...15
        tda.setFront_2(0); // -79...+15 dB = int -79...15
        tda.setRear_1(0); // -79...+15 dB = int -79...15
        tda.setRear_2(0); // -79...+15 dB = int -79...15
        tda.setBass_setup(0,0); // 0.5 1.0 1.5 2.0 --- int 0...3, 60Hz 80Hz 100Hz 120Hz --- int 0...3
        tda.setMiddle_setup(0,0); // 0.75 1.0 1.25 1.5 --- int 0...3, 500Hz 1kHz 1.5kHz 2.5kHz --- int 0...3
        tda.setTreble_setup(0,0); // 0.75 1.25  --- int 0...1, 7.5kHz 10kHz 12.5kHz 15kHz --- int 0...3
        tda.setBass_gain(0); // --15 ... +15 dB = int -15 ... 15
        tda.setMiddle_gain(0); // --15 ... +15 dB = int -15 ... 15
        tda.setTreble_gain(0); // --15 ... +20 dB = int -15 ... 15
        tda.setLoudness_gain(0); // 0 ... 15 dB = int 0 ... 15
			<updated>2020-01-24T11:10:35Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=765#p765</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=384#p384" />
			<content type="html"><![CDATA[<p>с энкодером<br />D8 D9 подключение энкодера CLK, DT</p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#include &lt;TDA7719.h&gt;
#include &lt;MsTimer2.h&gt;
  TDA7719 tda;
  byte a1,a2,b1,b2,param,data;
  int w,i,vol,treb,treb_f,mid,mid_f,bas,bass_f,in,eeprom,loun,loun_f,vol_att,vol0,vol1,att_RF,att_LF,att_RR,att_LR;
   pinMode(8, INPUT_PULLUP);
   pinMode(9, INPUT_PULLUP);
   loun = EEPROM.read(5);loun_f = EEPROM.read(6);
   vol0=EEPROM.read(7);vol1=EEPROM.read(8);treb_f=EEPROM.read(9);mid_f=EEPROM.read(10);bass_f=EEPROM.read(11);
   att_RF=EEPROM.read(12);att_LF=EEPROM.read(13);att_RR=EEPROM.read(14);att_LR=EEPROM.read(15);
   in_att();audio();
  /////////// Serial Port - получение данных //////////////////////////////////////////////////////////
  if(Serial.available()){w++;time=millis(); delay(10);
      case 0: a1 = Serial.read()-48;
      case 1: a2 = Serial.read()-48;
      case 2: b1 = Serial.read()-48;
      case 3: b2 = Serial.read()-48;}
      param = a1*10+a2;data = b1*10+b2;// получение кода команды и значение
    switch(param){
      case 10: vol=data;break;                                    // передаем переменной vol  значение byte = 79...0 === громкость от -79 до 0 дБ === 1079...1000
      case 11: treb=data;break;                                   // передаем переменной treb  значение byte = 0...30 === тебр ВЧ от -15 до +15 дБ === 1100...1130
      case 12: mid=data;break;                                    // передаем переменной mid  значение byte = 0...30 === тебр СЧ от -15 до +15 дБ === 1200...1230
      case 13: bas=data;break;                                    // передаем переменной bas  значение byte = 0...30 === тебр НЧ от -15 до +15 дБ === 1300...1330
      case 14: in=data;break;                                     // передаем переменной in  значение byte = 1...2 === выбор входа от 0 до 1 === 1401...1402
      case 15: loun=data;break;                                   // передаем переменной loun  значение byte = 0...15 === тонкомпенсация ослабление от -15 до 0 дБ === 1500...1515
      case 16: loun_f=data;break;                                 // передаем переменной loun_f  значение byte = 0...3 === тонкомпенсация центральная частота FLAT 400 800 2400 Гц === 1600...1603
      case 17: vol0=data;break;                                   // аттенюатор входа 0 от -15 до +15 дБ  === 1700...1730
      case 18: vol1=data;break;                                   // аттенюатор входа 1 от -15 до +15 дБ  === 1800...1830
      case 19: treb_f=data;break;                                 // передаем переменной treb_f  значение byte = 0...3 === ВЧ центральная частота 10 12.5 15 17.5 кГц === 1900...1903
      case 20: mid_f=data;break;                                  // передаем переменной mid_f  значение byte = 0...3 === CЧ центральная частота 0.5 1 1.5 2.5 кГц === 2000...2003
      case 21: bass_f=data;break;                                 // передаем переменной bass_f  значение byte = 0...3 === НЧ центральная частота 60 80 100 200 Гц === 2100...2103
        //// attenuator output
      case 22: att_RF=data;break;                                 // 2200...2215
      case 23: att_LF=data;break;                                 // 2300...2315
      case 24: att_RR=data;break;                                 // 2400...2415
      case 25: att_LR=data;break;                                 // 2500...2515
      case 99: eeprom=data;break; // EEPROM === 9901 отправить в данные в EEPROM
      i++;}}i=0;
   in_att();
    vol=vol-newPosition;myEnc.write(0);newPosition=0;w=1;if(vol&lt;0){vol=0;}if(vol&gt;79){vol=79;}audio();}
  if(eeprom==1){eeprom=0;
     EEPROM.update(5,loun);EEPROM.update(6,loun_f);EEPROM.update(7,vol0);EEPROM.update(8,vol1);
     EEPROM.update(9,treb_f);EEPROM.update(10,mid_f);EEPROM.update(11,bass_f);
     EEPROM.update(12,att_RF);EEPROM.update(13,att_LF);EEPROM.update(14,att_RR);EEPROM.update(15,att_LR);
  //////////// Отправка данных в минитор порта и аудиопроцессор /////////////////////////////////////////
  if(w==1){audio();
  Serial.print(&quot;vol= &quot;);Serial.print(vol);Serial.print(&quot; treb= &quot;);Serial.print(treb);Serial.print(&quot; mid= &quot;);Serial.print(mid);Serial.print(&quot; bas= &quot;);Serial.print(bas);
  Serial.print(&quot; in= &quot;);Serial.print(in);Serial.print(&quot; loun= &quot;);Serial.print(loun);Serial.print(&quot; loun_f= &quot;);Serial.print(loun_f);
  Serial.print(&quot; vol0= &quot;);Serial.print(vol0);Serial.print(&quot; vol1= &quot;);Serial.print(vol1);Serial.print(&quot; treb_f&quot;);Serial.print(treb_f);Serial.print(&quot; mid_f= &quot;);
  Serial.print(mid_f);Serial.print(&quot; bass_f= &quot;);Serial.print(bass_f);Serial.print(&quot; rf= &quot;);
  Serial.print(att_RF);Serial.print(&quot; lf= &quot;);Serial.print(att_LF);Serial.print(&quot; rr= &quot;);Serial.print(att_RR);Serial.print(&quot; lr= &quot;);Serial.print(att_LR);
  Serial.print(&quot; vol_att=&quot;);Serial.print(vol_att);Serial.print(&quot; общая гром= &quot;);Serial.print(vol+15-att_LR);Serial.println(&quot;&quot;);
   w=0;}
}//LOOP
tda.setInput(in,1,1,7); // 0...7, 0...1, 0...1, 0...7
tda.setInput_2(2,1,1,1,1,1); // 0...7, 0...1, 0...1, 0...1, 0...1, 0...1
tda.setMute(1,0,0,1,1,1,1); // 0...1, 0...1, 0...3, 0...1, 0...1, 0...1, 0...1
tda.setVol(vol_att-15,1,1); // -15...+15, 0...1, 0...1
tda.setTreble(treb-15,treb_f,1); // -15...+15, 0...3, 0...1
tda.setMiddle(mid-15,3,1); // -15...+15, 0...3, 0...1
tda.setBass(bas-15,3,1); // -15...+15, 0...3, 0...1
tda.setSMB(0,1,mid_f,bass_f,1); // 0...3, 0...1, 0...3, 0...3, 0...1
tda.setVol_LF(vol+15-att_LR,1); // 0...-79, 0...1
tda.setVol_RF(vol+15-att_RF,1); // 0...-79, 0...1
tda.setVol_LR(vol+15-att_LR,1); // 0...-79, 0...1
tda.setVol_RR(vol+15-att_RR,1); // 0...-79, 0...1
tda.setVol_SUB_L(vol,1); // 0...-79, 0...1
tda.setVol_SUB_R(vol,1); // 0...-79, 0...1
void in_att(){
     case 1: vol_att = vol0;break;
     case 2: vol_att = vol1;break;
void to_Timer(){newPosition = myEnc.read()/4;}</code></pre></div>]]></content>
			<updated>2019-11-22T13:55:28Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=384#p384</id>
			<title type="html"><![CDATA[Serial Port tda7719]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=372#p372" />
  TDA7719 tda;
  byte w,i,vol,treb,treb_f,mid,mid_f,bas,bass_f,in,eeprom,loun,loun_f,vol_att,vol0,vol1,att_RF,att_LF,att_RR,att_LR;
  unsigned long time;
   in_att();audio();
    switch(param){
      case 14: in=data;break;                                     // передаем переменной in  значение byte = 0...5 === выбор входа от 0 до 5 === 1400...1405
      case 17: vol0=data;break;                                   // аттенюатор входа 1 от -15 до +15 дБ  === 1700...1730
      case 18: vol1=data;break;                                   // аттенюатор входа 2 от -15 до +15 дБ  === 1800...1830
      case 22: att_RF=data;break;                                 // 2215...2200
      case 23: att_LF=data;break;                                 // 2315...2315
      case 24: att_RR=data;break;                                 // 2415...2400
      case 25: att_LR=data;break;                                 // 2515...2500
      i++;}}i=0;
   in_att();
  if(w==1){audio();
  Serial.print(vol);Serial.print(&quot; &quot;);Serial.print(treb);Serial.print(&quot; &quot;);Serial.print(mid);Serial.print(&quot; &quot;);Serial.print(bas);
  Serial.print(&quot; &quot;);Serial.print(in);Serial.print(&quot; &quot;);Serial.print(loun);Serial.print(&quot; &quot;);Serial.print(loun_f);
  Serial.print(&quot; &quot;);Serial.print(vol0);Serial.print(&quot; &quot;);Serial.print(vol1);Serial.print(&quot; &quot;);Serial.print(treb_f);Serial.print(&quot; &quot;);
  Serial.print(mid_f);Serial.print(&quot; &quot;);Serial.print(bass_f);Serial.println(&quot; &quot;);
   w=0;}
}//LOOP
tda.setVol_LF(vol-att_LR,1); // 0...-79, 0...1
tda.setVol_RF(vol-att_RF,1); // 0...-79, 0...1
tda.setVol_LR(vol-att_LR,1); // 0...-79, 0...1
tda.setVol_RR(vol-att_RR,1); // 0...-79, 0...1
void in_att(){
     case 0: vol_att = vol0;break;
     case 1: vol_att = vol1;break;
			<updated>2019-11-18T09:13:21Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=372#p372</id>
