		<title><![CDATA[forum.rcl-radio.ru &mdash; Часы+будильник на П543 (ИЛЦ5-4/7М)]]></title>
		<link>http://forum.rcl-radio.ru/viewtopic.php?id=696</link>
		<atom:link href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=696&amp;type=rss" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «Часы+будильник на П543 (ИЛЦ5-4/7М)».]]></description>
		<lastBuildDate>Wed, 18 Mar 2026 17:38:30 +0000</lastBuildDate>
			<title><![CDATA[Re: Часы+будильник на П543 (ИЛЦ5-4/7М)]]></title>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12620#p12620</link>
			<description><![CDATA[<p>Не помогло...</p>]]></description>
			<author><![CDATA[null@example.com (ross74)]]></author>
			<pubDate>Wed, 18 Mar 2026 17:38:30 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12620#p12620</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12619#p12619</link>
			<description><![CDATA[<p>возможно поможет</p><p>void setka(){<br />&nbsp; switch(c){&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;<br />&nbsp; &nbsp; case 0:ch(C1_SET,0);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 1:ch(C1_SET,1);ch(C2_SET,0);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 2:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,0);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 3:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,0);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 4:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,0);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 5:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,0);break; <br />&nbsp; }} </p><p>замените на </p><p>void setka(){<br />&nbsp; switch(c){&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;<br />&nbsp; &nbsp; case 0:ch(C1_SET,0);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 1:ch(C1_SET,1);ch(C2_SET,0);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 2:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,0);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 3:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,0);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 4:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,0);ch(C6_SET,1);break; <br />&nbsp; &nbsp; case 5:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,0);break; <br />&nbsp; &nbsp; case 6:ch(C1_SET,1);ch(C2_SET,1);ch(C3_SET,1);ch(C4_SET,1);ch(C5_SET,1);ch(C6_SET,1);break; <br />&nbsp; }} </p><br /><p>void to_Timer(){ <br />&nbsp; &nbsp; switch(i){<br />&nbsp; &nbsp; case 0:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm_dn=wesk; c=5;&nbsp; setka();dn(bud); break;<br />&nbsp; &nbsp; case 1:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[0];&nbsp; &nbsp; c=4;&nbsp; setka();segment(1); break;<br />&nbsp; &nbsp; case 2:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[1];&nbsp; &nbsp; c=3;&nbsp; setka();segment(kolorol); break;<br />&nbsp; &nbsp; case 3:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm=s_tic;&nbsp; &nbsp;c=2;&nbsp; setka();tic(); break;<br />&nbsp; &nbsp; case 4:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[2];&nbsp; &nbsp; c=1;&nbsp; setka();segment(prog); break;<br />&nbsp; &nbsp; case 5:&nbsp; segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[3];&nbsp; &nbsp; c=0;&nbsp; setka();segment(timers); break;<br />&nbsp; }i++;if(i&gt;5){i=0;}}</p><p>заменить на</p><p>void to_Timer(){ <br />&nbsp; &nbsp; switch(i){<br />&nbsp; &nbsp; case 0:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm_dn=wesk; c=5;&nbsp; setka();dn(bud); break;<br />&nbsp; &nbsp; case 1:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[0];&nbsp; &nbsp; c=4;&nbsp; setka();segment(1); break;<br />&nbsp; &nbsp; case 2:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[1];&nbsp; &nbsp; c=3;&nbsp; setka();segment(kolorol); break;<br />&nbsp; &nbsp; case 3:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=s_tic;&nbsp; &nbsp;c=2;&nbsp; setka();tic(); break;<br />&nbsp; &nbsp; case 4:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[2];&nbsp; &nbsp; c=1;&nbsp; setka();segment(prog); break;<br />&nbsp; &nbsp; case 5:&nbsp; c=6;segm=12; setka();segment(1); delayMicroseconds(brig); segm=a[3];&nbsp; &nbsp; c=0;&nbsp; setka();segment(timers); break;<br />&nbsp; }i++;if(i&gt;5){i=0;}}</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 17:24:57 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12619#p12619</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12618#p12618</link>
			<description><![CDATA[<p>Время на часах 22:14,остальные сегменты моргают:<span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2026/03/b8e8912baf583e98d0d899c8a0a27aea.jpg" alt="http://forum.rcl-radio.ru/uploads/images/2026/03/b8e8912baf583e98d0d899c8a0a27aea.jpg" /></span></p>]]></description>
			<pubDate>Wed, 18 Mar 2026 17:18:55 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12618#p12618</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12617#p12617</link>
			<description><![CDATA[<p>Загрузил,ничего не поменялось,всё так-же мерцают неактивные сегменты.</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 17:11:27 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12617#p12617</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12616#p12616</link>
			<description><![CDATA[<p>Загрузите скетч со страницы проекта - <a href="http://rcl-radio.ru/?p=133796">http://rcl-radio.ru/?p=133796</a></p>]]></description>
			<pubDate>Wed, 18 Mar 2026 17:00:50 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12616#p12616</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12615#p12615</link>
			<description><![CDATA[<p>Хорошо.попробую</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 17:00:22 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12615#p12615</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12614#p12614</link>
			<description><![CDATA[<p>Возможно избыточная яркость, можно попробовать снизить анодно-сеточное напряжение</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 16:57:17 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12614#p12614</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12613#p12613</link>
			<description><![CDATA[<p>ардуино нано,атмега328</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 16:50:34 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12613#p12613</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12612#p12612</link>
			<description><![CDATA[<p>Какой контроллер?</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 16:12:50 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12612#p12612</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12611#p12611</link>
			<description><![CDATA[<p>Сегменты не постоянно подсвечиваются,а быстро мерцают</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 16:09:01 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12611#p12611</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12610#p12610</link>
			<pubDate>Wed, 18 Mar 2026 16:03:47 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12610#p12610</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12609#p12609</link>
			<description><![CDATA[<p>Загрузил последний ваш скетч:https://cloud.mail.ru/public/NBuw/RSFk6TvHu</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 15:54:16 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12609#p12609</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12608#p12608</link>
			<description><![CDATA[<p>26в</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 15:43:12 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12608#p12608</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12607#p12607</link>
			<description><![CDATA[<p>Померьте анодное напряжение</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 15:39:50 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12607#p12607</guid>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=12606#p12606</link>
			<description><![CDATA[<p>А уже загрузив скетч из сообщения 17,начинается мерцание и подсветка сегментов.</p>]]></description>
			<pubDate>Wed, 18 Mar 2026 15:34:39 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=12606#p12606</guid>
