	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Attiny4313&bme280]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=626&amp;type=atom" />
	<updated>2025-01-10T07:10:33Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=626</id>
			<title type="html"><![CDATA[Re: Attiny4313&bme280]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=11265#p11265" />
			<content type="html"><![CDATA[<p>Attiny85 + BME280+ds18b20+max7219<br /></p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#include &quot;TinyBME280.h&quot;
#define DIN PB1
#define CS  PB4
#define CLK PB3
//SDA pin 5 PB0
//SCL pin 7 PB2
const int OneWirePin = 5;
byte DisplayNumtoSeg[] = {126,48, 109, 121, 51, 91, 95, 112, 127, 123};
int t,p,h;
#define t1 DisplayNumtoSeg [t / 1000]
#define t2 DisplayNumtoSeg [t / 100%10]
#define p1 DisplayNumtoSeg [p / 100%10]
#define p2 DisplayNumtoSeg [p / 10%10]
#define p3 DisplayNumtoSeg [p %10]
uint8_t DataBytes[2];
byte d1,d2,d3,d4;
  BME280setI2Caddress(0x76);
  BME280setup();
  DDRB |= (1 &lt;&lt; DIN) | (1 &lt;&lt; CS) | (1 &lt;&lt; CLK);
  max7219(0x0F, 0, 0);// тест выкл.
  max7219(0x0C, 1, 1);// вкл. индик.
  max7219(0x0A, 0x0f, 0x0f);// яркость
  max7219(0x09, 0, 0);// дешифраторы выкл.
  max7219(0x0B, 7, 7);// кол-во разрядов
  TCCR1 = 0&lt;&lt;CTC1 | 0&lt;&lt;PWM1A | 5&lt;&lt;CS10;  // CTC mode, 500kHz clock
  GTCCR = 0&lt;&lt;PWM1B;
  max7219(1, 0,0 );
  max7219(2, 55, 0);
  max7219(3, 79, 0);
  max7219(4, 14, 0);
  max7219(5, 14, 0);
  max7219(6, 126, 0);
  max7219(7, 0, 0);
  max7219(8, 0, 0);
 t = BME280temperature();
 p = BME280pressure()*100/13332;
 h = BME280humidity();
 Temperature ();
  if(t / 1000!=0) max7219(1,t1,103 );
  else  max7219(1,0,103 );
  max7219(2, t2, p1);
  max7219(3, 99, p2);
  max7219(4, d1, p3);
  max7219(5, d2, DisplayNumtoSeg [h /1000]);
  max7219(6, d3, DisplayNumtoSeg [h /100%10]);
  max7219(7, d4, 99);
  max7219(8, 0, 29);
  delay(3000);
     for(char i = 7; i &gt;= 0; i--){
        PORTB &amp;= ~(1 &lt;&lt; CLK);
        if(((reg &gt;&gt; i) &amp; 1) == 1){PORTB |= (1 &lt;&lt; DIN);}else{PORTB &amp;= ~(1 &lt;&lt; DIN);}
        PORTB |=(1 &lt;&lt; CLK);}
        if(((data &gt;&gt; i) &amp; 1) == 1){PORTB |= (1 &lt;&lt; DIN);}else{PORTB &amp;= ~(1 &lt;&lt; DIN);}
        PORTB &amp;= ~(1 &lt;&lt; CLK);PORTB |= (1 &lt;&lt; DIN);
  void max7219(byte reg_n, byte h1, byte h2){
  PORTB &amp;=~(1 &lt;&lt; CS);
  WriteBit16(reg_n,h1);
  WriteBit16(reg_n,h2);
  PORTB |=(1 &lt;&lt; CS);}
inline void PinLow () {
  DDRB = DDRB | 1&lt;&lt;OneWirePin;
inline void PinRelease () {
  DDRB = DDRB &amp; ~(1&lt;&lt;OneWirePin);
// Returns 0 or 1
inline uint8_t PinRead () {
  return PINB&gt;&gt;OneWirePin &amp; 1;
void DelayMicros (int micro) {
  TCNT1 = 0; TIFR = 1&lt;&lt;OCF1A;
  OCR1A = (micro&gt;&gt;1) - 1;
  while ((TIFR &amp; 1&lt;&lt;OCF1A) == 0);
void LowRelease (int low, int high) {
  PinLow();
  DelayMicros(low);
  PinRelease();
  DelayMicros(high);
uint8_t OneWireReset () {
  uint8_t data = 1;
  LowRelease(480, 70);
  data = PinRead();
  DelayMicros(410);
  return data;                         // 0 = device present
void OneWireWrite (uint8_t data) {
  int del;
  for (int i = 0; i&lt;8; i++) {
    if ((data &amp; 1) == 1) del = 6; else del = 60;
    LowRelease(del, 70 - del);
    data = data &gt;&gt; 1;
uint8_t OneWireRead () {
  uint8_t data = 0;
    LowRelease(6, 9);
    data = data | PinRead()&lt;&lt;i;
    DelayMicros(55);
  return data;
void Temperature () {
  int temp;
   cli(); // No interrupts
  if(OneWireReset()!=0){
  d1=78;
  d2=d3=d4=128;
  else{
  OneWireWrite(0xCC);
    OneWireWrite(0x44);
    while (OneWireRead() != 0xFF);
    OneWireReset();
    OneWireWrite(0xCC);
    OneWireWrite(0xBE);
    DataBytes[0]=OneWireRead();
    DataBytes[1]=OneWireRead();
    OneWireReset();
 temp =(DataBytes[1]&lt;&lt;8 | DataBytes[0])/16;
if (temp&gt;=100)d1=DisplayNumtoSeg[temp/100];
if (temp&lt;0) d1=1;
else d1=0;
if(abs(temp)/10 % 10==0){
   d2=DisplayNumtoSeg[abs(temp) % 10];
   d3=99;
   d4=78;
else {
 d2= DisplayNumtoSeg[abs(temp)/10%10];
 d3= DisplayNumtoSeg[abs(temp) % 10];
 d4 = 99;}
				<name><![CDATA[klause]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=2004</uri>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=11265#p11265</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=10743#p10743" />
			<content type="html"><![CDATA[<p>Отличная разработка.<br />Если добавить измерение СО2 на MQ135, то получится интересная штука для дома.</p>]]></content>
			<updated>2024-09-12T12:32:10Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=10743#p10743</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=10742#p10742" />
			<content type="html"><![CDATA[<p>Attiny85,LCD1602,Dht11,bmp280<br /><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2024/09/99e5ba8b2d9c7339aff097538b2e5590.jpg" alt="http://forum.rcl-radio.ru/uploads/images/2024/09/99e5ba8b2d9c7339aff097538b2e5590.jpg" /></span><br /></p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
int const sda = PB0;//SDA pin 5 PB0
int const scl = PB2;//SCL pin 7 PB2
#define DHT PB4 // +подключить внешнюю подтяжку.
byte _hum, _temp;// переменные для влажности и температуры
LiquidCrystal_I2C lcd(0x27, 16, 2);
byte c[] = {B00110,B01001,B01001,B00110,B00000,B00000,B00000,B00000};
  BME280setup();
  lcd.begin();
  lcd.backlight();
  lcd.print(&quot;Hello, world!&quot;);
  lcd.clear();
  lcd.createChar(0, c);
dht_read(&amp;_hum, &amp;_temp);// опроса датчика
int t = BME280temperature();
int p = BME280pressure()/10;
int h = p/1.333224;
 lcd.home();
 lcd.print(&quot;P=&quot;);
 lcd.print(p/1000);
 lcd.print(p / 100 % 10);
 lcd.print(p/ 10 % 10);
 lcd.print(&quot;kPa &quot;);
 lcd.print(h/1000);
 lcd.print(h / 100 % 10);
 lcd.print(h/ 10 % 10);
 lcd.print(&quot;mmHg&quot;);
 lcd.setCursor(0, 1);
 lcd.print(&quot;T=&quot;);
 lcd.print(t / 1000);
 lcd.print(t/ 100 % 10 );
 lcd.print(&quot;.&quot;);
 lcd.print(t/ 10 % 10);
 lcd.write(0);
 lcd.print(&quot;C&quot;);
 lcd.print(&quot; Hum=&quot;);
 lcd.print(_hum/ 10 % 10 );
 lcd.print(_hum % 10);
 lcd.print(&quot;%&quot;);
// общая функция опроса датчика
  byte data[5];// массив под данные датчика
  byte error=dht_start();// стартуем и получаем код ошибки в переменную
  if (error) return error; // если есть ошибки выходим с кодом ошибки
  // получаем 5 байт от датчика
  for (byte i=0; i&lt;5; i++)
    data[i]=dht_byte();
  if (data[0]+data[1]+data[2]+data[3]!=data[4]) return 3; // если контрольная сумма не сошлась вернем ошибку 3
  *hum=data[0];// пишем данные влажности
  *temp=data[2];// пишем данные температуры
  return 0;// вернем 0 - ошибок нет.
// функция передачи условия &quot;старт&quot; на линию и проверка ответов от датчика.
 byte  dht_start(){
  DDRB|=(1&lt;&lt;DHT);// притянули линию к земле - 0
  delay(20);// пауза 20 мс
  DDRB&amp;=~(1&lt;&lt;DHT);// отпустили линию - 1
  delayMicroseconds(40);// ждем 40 мкс чтобы попасть в середину низкого сигнала
  if (PINB&amp;(1&lt;&lt;DHT)) return 1; // если на линии 1 ошибка - &quot;датчик не ответил&quot;
  delayMicroseconds(80); // ждем 80 мкс чтобы попасть в середину высокого сигнала
  if (!(PINB&amp;(1&lt;&lt;DHT))) return 2; // если на линии 0 ошибка - &quot;датчик не готов &quot;
  while(PINB&amp;(1&lt;&lt;DHT));// ждем пока датчик не притянет линию к земле.
  return 0;// ошибок нет
// получение байта от датчика
byte dht_byte(){
  byte i=8, byte=0;// переменная для цикла и под байт
  while(i--){
    while(!(PINB&amp;(1&lt;&lt;DHT)));// ждем пока линия не поднимится в 1
    delayMicroseconds(40);// отступаем 40 мкс
    if (PINB&amp;(1&lt;&lt;DHT)) {// если на линии 1 = приняли 1
      byte|=(1&lt;&lt;i);// поднимаем итый бит в 1
      while(PINB&amp;(1&lt;&lt;DHT));// ждем пока линия упадет в 0
  return byte;// возвращаем полученный байт
 </code></pre></div><p>BMP180, DHT11.<br /><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2024/10/7989d5912c85746f677e8690d7f72b93.jpg" alt="http://forum.rcl-radio.ru/uploads/images/2024/10/7989d5912c85746f677e8690d7f72b93.jpg" /></span> <br /><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2024/10/61c769bf2790ea9209e4925d9963d0ed.jpg" alt="http://forum.rcl-radio.ru/uploads/images/2024/10/61c769bf2790ea9209e4925d9963d0ed.jpg" /></span> <br /></p><div class="codebox"><pre><code>#include &lt;TinyWireM.h&gt;
#include &lt;tinyBMP085.h&gt;
tinyBMP085 bmp;
#define DIN PB1
#define CS  PB3
#define CLK PB4
//SDA pin 5 PB0
//SCL pin 7 PB2
byte _hum, _temp;
#define DHT PB5
unsigned long StartTime;
  bmp.begin();
  delay(2);
    int pres = bmp.readPressure()/100; //kилопаскалях
    pres=pres-2;// коррекция
    int  p = pres/0.133322;// мм ртутного столба
   // int temp = bmp.readTemperature10C();
  max7219(1, 103, DisplayNumtoSeg [_temp / 10%10]);
  max7219(2, 5, DisplayNumtoSeg [_temp %10]);
  max7219(3, DisplayNumtoSeg [p / 1000], 99);
  max7219(4, DisplayNumtoSeg [p / 100%10], 78);
  max7219(5 ,DisplayNumtoSeg [p / 10%10] , DisplayNumtoSeg [_hum/ 10%10]);
  max7219(6, 0 , DisplayNumtoSeg [_hum %10]);
  max7219(7, 0, 99);
  max7219(8, 0, 29);
  if(millis()-StartTime &gt; 10000){
   StartTime= millis();
  if(pres&gt;=1000)max7219(1, DisplayNumtoSeg [pres / 1000], DisplayNumtoSeg [_temp / 10%10]);
  else max7219(1,0, DisplayNumtoSeg [_temp / 10%10]);
  max7219(2, DisplayNumtoSeg [pres / 100%10], DisplayNumtoSeg [_temp %10]);
  max7219(3, DisplayNumtoSeg [pres / 10%10], 99);
  max7219(4, DisplayNumtoSeg [pres %10], 78);
  max7219(5 ,0 , DisplayNumtoSeg [_hum/ 10%10]);
  max7219(6, 103, DisplayNumtoSeg [_hum %10]);
  max7219(7, 0, 99);
  max7219(8, 0, 29);
    data[i]=dht_byte();
 byte  dht_start(){
byte dht_byte(){
  while(i--){
			<updated>2024-09-12T11:05:27Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=10742#p10742</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=10019#p10019" />
			<content type="html"><![CDATA[<div class="quotebox"><cite>liman324 пишет:</cite><blockquote><p>Отличная работа, рекомендую опубликовать на сайте rck-radio.ru Ваши проекты, там намного больше посещаемость, больше вероятность получить отзывы о Ваших проектах.</p></blockquote></div><p>Спасибо. Но это просто творческий порыв, для своего развития. Код ещё надо подкорректировать. В свойствах платы отключить millis()/micros(), чтобы код вместился.</p>]]></content>
			<updated>2024-03-29T07:59:16Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=10019#p10019</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=9978#p9978" />
			<content type="html"><![CDATA[<p>Отличная работа, рекомендую опубликовать на сайте rck-radio.ru Ваши проекты, там намного больше посещаемость, больше вероятность получить отзывы о Ваших проектах.</p>]]></content>
			<updated>2024-03-27T11:24:37Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=9978#p9978</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=9975#p9975" />
			<content type="html"><![CDATA[<p>С дисплеем нокиа3410.<br /></p><div class="codebox"><pre><code>#include &lt;avr/io.h&gt;
#include &lt;avr/pgmspace.h&gt;
#include &lt;stdint.h&gt;
#include &lt;stdlib.h&gt;
#include &lt;stdbool.h&gt;
#include &lt;avr/sleep.h&gt;
#include &lt;util/delay.h&gt;
#include &lt;avr/wdt.h&gt;
#include &lt;avr/interrupt.h&gt;
// Nokia LCD pin numbers
#define LCD_MOSI  PINB4 //DIN,SDA,data
#define LCD_SCK   PINB3 //CLK,SCL,clock
#define LCD_CD    PINB2 //DC, D/C
#define LCD_RESET PINB1 //Res,reset
/*pin CS подключить на GND
pin Vout через конденсатор на GND */
/** Number of columns */
#define LCD_COL 96 //for Nokia 3310-84
/** Number of text rows */
#define LCD_ROW 10 //for Nokia 3310-6
int const sda = PB5;//pin 17
int const scl = PB7;//pin 19
#define DHT PIND0
const unsigned long Alarm = 300000; //  time - 5 minutes
//unsigned long StartTime = 0;        // start time
const int Dht = PIND1; // +dht11
byte _hum, _temp;
extern const uint8_t SMALL_FONT[] PROGMEM;
const uint8_t SMALL_FONT[] PROGMEM = {
  0x00, 0x60, 0x60, 0x00, 0x00,//.
  0x7F, 0x02, 0x0C, 0x02, 0x7F// m
extern const uint8_t BIG_FONT[] PROGMEM;
const uint8_t BIG_FONT[] PROGMEM = {
   0x00,0xF0,0xFC,0xFE,0x06,0x02,0x06,0xFE,0xFC,0xF0,0x00,// 0
   0x00,0x07,0x1F,0x3F,0x30,0x20,0x30,0x3F,0x1F,0x07,0x00,
   0x00,0x00,0x08,0x0C,0xFC,0xFE,0xFE,0x00,0x00,0x00,0x00,// 1
   0x00,0x20,0x20,0x20,0x3F,0x3F,0x3F,0x20,0x20,0x20,0x00,
   0x00,0x0C,0x0E,0x06,0x02,0x02,0x86,0xFE,0x7C,0x38,0x00,// 2
   0x00,0x30,0x38,0x3C,0x36,0x33,0x31,0x30,0x30,0x38,0x00,
   0x00,0x0C,0x0E,0x86,0x82,0x82,0xC6,0xFE,0x7C,0x38,0x00,// 3
   0x00,0x18,0x38,0x30,0x20,0x20,0x31,0x3F,0x1F,0x0E,0x00,
   0x00,0x00,0xC0,0x20,0x18,0x04,0xFE,0xFE,0xFE,0x00,0x00,// 4
   0x00,0x03,0x02,0x02,0x02,0x22,0x3F,0x3F,0x3F,0x22,0x02,
   0x00,0x00,0x7E,0x7E,0x46,0x46,0xC6,0xC6,0x86,0x00,0x00,// 5
   0x00,0x18,0x38,0x30,0x20,0x20,0x30,0x3F,0x1F,0x0F,0x00,
   0x00,0xC0,0xF0,0xF8,0xFC,0x4C,0xC6,0xC2,0x82,0x00,0x00,// 6
   0x00,0x0F,0x1F,0x3F,0x30,0x20,0x30,0x3F,0x1F,0x0F,0x00,
   0x00,0x06,0x06,0x06,0x06,0x06,0xC6,0xF6,0x3E,0x0E,0x00,// 7
   0x00,0x00,0x00,0x30,0x3C,0x0F,0x03,0x00,0x00,0x00,0x00,
   0x00,0x38,0x7C,0xFE,0xC6,0x82,0xC6,0xFE,0x7C,0x38,0x00,// 8
   0x00,0x0E,0x1F,0x3F,0x31,0x20,0x31,0x3F,0x1F,0x0E,0x00,
   0x00,0x78,0xFC,0xFE,0x86,0x02,0x86,0xFE,0xFC,0xF8,0x00,// 9
   0x00,0x00,0x00,0x21,0x21,0x31,0x1D,0x1F,0x0F,0x03,0x00,
   0xF0,0xF8,0x0C,0x06,0x02,0x02,0x02,0x02,0x0E,0x0C,0x00,// C
   0x03,0x07,0x0C,0x18,0x10,0x10,0x10,0x10,0x1C,0x0C,0x00,
   0x00,0x1C,0x22,0x22,0x22,0x1C,0x00,0x00,0x00,0x00,0x00,// degrees
   0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
   0x00,0x1C,0x22,0x22,0x22,0x1C,0x80,0x40,0x20,0x10,0x08,// %
   0x00,0x10,0x08,0x04,0x02,0x01,0x38,0x44,0x44,0x44,0x38,
   0x88,0x48,0x29,0xDA,0x2C,0x32,0x32,0x4C,0x9A,0xA9,0x48,//Рress
   0x00,0x06,0x49,0x29,0x88,0x48,0x28,0x08,0x48,0x24,0x03,
   0x44,0x54,0x54,0xFE,0x01,0xFE,0x00,0xC6,0x29,0x29,0x46,//Тemp
   0x00,0x01,0x71,0x8F,0x80,0x8F,0x70,0x07,0x08,0x08,0x04,
   0x00,0x80,0x40,0x30,0x0E,0x07,0x38,0xE0,0xC0,0x80,0x00,//Нum
   0x00,0x3E,0x41,0x80,0x80,0x80,0x80,0xC0,0xFF,0x7F,0x3E,
 DDRD|=(1&lt;&lt;Dht);
 PORTD = PORTD | 1&lt;&lt;Dht;
  unitLCD();
  clearLCD();
  BME280setup();
 set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  do{
int p = BME280pressure()*100/13332;
       lcdPrintBChar(6, 0, 15, 0, 0);
       lcdPrintBChar(6, 34,_hum / 10%10, 0, 0);
       lcdPrintBChar(6, 46,_hum %10, 0, 0);
       lcdPrintBChar(6, 58, 12, 0, 0);
       lcdPrintBChar(3, 1, 14, 0, 0);
       lcdPrintBChar(3, 22,t/1000%10, 0, 0);
       lcdPrintBChar(3, 34,t/100%10, 0, 0);
       lcdPrintChar (4, 44,0);
       lcdPrintBChar(3, 51,t/10%10, 0, 0);
       lcdPrintBChar(3, 63, 11, 0, 0);
       lcdPrintBChar(3, 73, 10, 0, 0);
       lcdPrintBChar(0, 1, 13, 0, 0);
       lcdPrintBChar(0, 27,p /100%10, 0, 0);
       lcdPrintBChar(0, 39,p/10%10, 0, 0);
       lcdPrintBChar(0, 51,p%10, 0, 0);
       lcdPrintChar (1, 65,1);
       lcdPrintChar (1, 72,1);
  while( millis() &lt; Alarm);
  PORTD = PORTD &amp; ~(1&lt;&lt;Dht);
  PORTB=0;
  sleep_enable();
  sleep_cpu();
void sspiOutMSB(uint8_t sck, uint8_t mosi, uint16_t data, uint8_t bits) {
  uint16_t mask = (1 &lt;&lt; (bits - 1));
  uint8_t output = (1 &lt;&lt; mosi);
  uint8_t clock = (1 &lt;&lt; sck);
  while(bits) {
    // Set data
    if(data&amp;mask)
      PORTB |= output;
    else
      PORTB &amp;= ~output;
    // Bring the clock high
    PORTB |= clock;
    // Move to the next bit
    mask = mask &gt;&gt; 1;
    bits--;
    // Bring the clock low again
    PORTB &amp;= ~clock;
void lcdData(uint8_t data) {
  // Bring CD high
  PORTB |= (1 &lt;&lt; LCD_CD);
  // Send the data
  sspiOutMSB(LCD_SCK, LCD_MOSI, data, 8);
/** Send a command byte to the LCD
 * @param cmd the command byte to send.
void lcdCommand(uint8_t cmd) {
  // Bring CD low
  PORTB &amp;= ~(1 &lt;&lt; LCD_CD);
  // Send the data
  sspiOutMSB(LCD_SCK, LCD_MOSI, cmd, 8);
/** Write a single character
void lcdPrintChar(uint8_t row, uint8_t col, uint8_t ch) {
  // Set the starting address
  const uint8_t *chdata = SMALL_FONT + (ch * 5);
    lcdCommand(0x80 | col);
    lcdCommand(0x40 | (row % LCD_ROW));
    // And send the column data
   for(uint8_t pixels = 0; pixels &lt; 5; pixels++, chdata++) {
    uint8_t data = pgm_read_byte_near(chdata);
    lcdData(data);
    // for double sized font put
   // lcdData(data);
  // Add the padding byte
//if(col &lt; LCD_COL)
 lcdData(0x00);
  void clearLCD()
  { lcdCommand(0x80);
    lcdCommand(0x40);
    // Fill in the whole display with ZEROS
    for(uint16_t index = 0; index &lt; (LCD_COL * LCD_ROW); index++)
     lcdData(0x00);}
  void unitLCD()
    uint8_t val = (1 &lt;&lt; LCD_SCK) | (1 &lt;&lt; LCD_MOSI) | (1 &lt;&lt; LCD_RESET) | (1 &lt;&lt; LCD_CD);
   PORTB &amp;= ~val;
   DDRB |= val;
   PORTB |= (1 &lt;&lt; LCD_RESET);
   lcdCommand(0x21);  // LCD Extended Commands.
   lcdCommand(0xA1);  // Set LCD Vop (Contrast).
   lcdCommand(0x04);  // Set Temp coefficent.
   lcdCommand(0x14);  // LCD bias mode 1:48.
   lcdCommand(0x20);  // LCD Normal commands
   lcdCommand(0x0C);  // Normal display, horizontal addressing
    data[i]=dht_byte();
 byte  dht_start(){
  DDRD|=(1&lt;&lt;DHT);// притянули линию к земле - 0
  _delay_ms(20);// пауза 20 мс
  DDRD&amp;=~(1&lt;&lt;DHT);// отпустили линию - 1
  _delay_us(40);// ждем 40 мкс чтобы попасть в середину низкого сигнала
  if (PIND&amp;(1&lt;&lt;DHT)) return 1; // если на линии 1 ошибка - &quot;датчик не ответил&quot;
  _delay_us(80); // ждем 80 мкс чтобы попасть в середину высокого сигнала
  if (!(PIND&amp;(1&lt;&lt;DHT))) return 2; // если на линии 0 ошибка - &quot;датчик не готов &quot;
  while(PIND&amp;(1&lt;&lt;DHT));// ждем пока датчик не притянет линию к земле.
byte dht_byte(){
  while(i--){
    while(!(PIND&amp;(1&lt;&lt;DHT)));// ждем пока линия не поднимится в 1
    _delay_us(40);// отступаем 40 мкс
    if (PIND&amp;(1&lt;&lt;DHT)) {// если на линии 1 = приняли 1
      while(PIND&amp;(1&lt;&lt;DHT));// ждем пока линия упадет в 0
void lcdPrintBChar(uint8_t row, uint8_t col, uint8_t ch, bool big, bool invert) {
  const uint8_t *chdata = BIG_FONT + (ch * 22);
  for(uint8_t rowused = row; rowused &lt; row+2; rowused++) {
    lcdCommand(0x40 | (rowused % LCD_ROW));
   for(uint8_t pixels = 0; pixels &lt; 11; pixels++, chdata++) {
    //double sized font
    lcdData(invert?~data:data);
    if (big) lcdData(invert?~data:data);
   lcdData(invert?0xFF:0x00);
			<updated>2024-03-27T10:56:30Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=9975#p9975</id>
			<title type="html"><![CDATA[Attiny4313&bme280]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=9664#p9664" />
			<content type="html"><![CDATA[<p>Попытался подключить модуль bme280(bmp280). Индикатор на MAx7219.Выводится через 3с температура,давление,влажность. Плата AttinyCore. <br /></p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#define DIN PD3 // нога1
#define CS  PD4 // нога12
#define CLK PD5 // нога13
  // Set up BME280
  BME280setup();
  DDRD |= (1 &lt;&lt; DIN) | (1 &lt;&lt; CS) | (1 &lt;&lt; CLK);
  PORTD |= (1 &lt;&lt; CS);
  PORTD &amp;= ~(1 &lt;&lt; CLK) | (1 &lt;&lt; DIN);
  delay(1);
  WriteBit16(0x0f,0x00); // Тест выкл.
  WriteBit16(0x0C,0x01); // Вкл. индик.
  WriteBit16(0x0B,0x04); // кол-во разрядов
  WriteBit16(0x09,0xFF); // Дешифраторы вкл.
  WriteBit16(0x0A,0x0f); // яркость
void loop () {
int h = BME280humidity();
delay(3000);
  WriteBit16(0x01,t/1000);
  WriteBit16(0x02,((t /100)% 10)|128);
  WriteBit16(0x03,(t/10)%10);
  WriteBit16(0x04,t%10);
  delay(3000);
  WriteBit16(0x01,p/1000);
  WriteBit16(0x02,(p /100)% 10);
  WriteBit16(0x03,((p/10)%10)|128);
  WriteBit16(0x04,p%10);
  delay(3000);
  WriteBit16(0x01,h/1000);
 WriteBit16(0x02,((h /100)% 10)|128);
  WriteBit16(0x03,(h/10)%10);
  WriteBit16(0x04,h%10);
  delay(3000);
     PORTD &amp;= ~(1 &lt;&lt; CLK);PORTD &amp;= ~(1 &lt;&lt; CS);
        if(((reg &gt;&gt; i) &amp; 1) == 1){PORTD |= (1 &lt;&lt; DIN);}else{PORTD &amp;= ~(1 &lt;&lt; DIN);}
        PORTD |=(1 &lt;&lt; CLK);PORTD &amp;= ~(1 &lt;&lt; CLK);
        if(((data &gt;&gt; i) &amp; 1) == 1){PORTD |= (1 &lt;&lt; DIN);}else{PORTD &amp;= ~(1 &lt;&lt; DIN);}
     PORTD |=(1 &lt;&lt; CS);PORTD &amp;= ~(1 &lt;&lt; CLK);PORTD &amp;= ~(1 &lt;&lt; DIN);
  }  </code></pre></div><p><span class="attention-yellow"></span></p>]]></content>
			<updated>2024-03-15T10:42:40Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=9664#p9664</id>
