	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Кодовый замок]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=577&amp;type=atom" />
	<updated>2023-09-08T06:44:53Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=577</id>
			<title type="html"><![CDATA[Кодовый замок]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8534#p8534" />
			<content type="html"><![CDATA[<div class="codebox"><pre><code>#define MASTER 345623
#define TIME_OPEN 3000
#include &lt;iarduino_KB.h&gt;  // https://github.com/tremaru/iarduino_KB.git
#include &lt;TM1637_6_LED.h&gt;
#include &lt;EEPROM.h&gt;
 TM1637_6_LED tm(9, 10); // CLK, DIO
 iarduino_KB KB(8,7,6,5,4,3,2); /// 8765 432
 long code[8],ccc,i,i1,times,master,user;
 int start;
 bool w,w1,cod;
  pinMode(13,OUTPUT);// output
  pinMode(11,OUTPUT);// tone
  KB.begin(KB3);
  tm.brig(1); // ЯРКОСТЬ 0...7
  tm.print(0, 0, 0b01000000, 0b00111001, 0b01011100, 0b01011110, 0b01111001, 0b01000000);
  EEPROM.get(0, user);
  if(KB.check(KEY_DOWN )){
     if(KB.getNum==15){i=0;ccc=0;for(i1=0;i1&lt;8;i1++){code[i]=0;}Serial.println(ccc);
       tone(11, 400, 100);tm.print(ccc, 0, -1, -1, -1, -1, -1, -1);} // # стереть число
     if(KB.getNum==14&amp;&amp;cod==1){Serial.println(ccc);delay(200);cod=0;start=1;user=EEPROM.put(0, ccc);
     times=millis();w=1;tone(11, 400, 300);} // start master
     if(KB.getNum==14&amp;&amp;cod==0){Serial.println(ccc);delay(200);w1=1;start=1;tone(11, 400, 300);} // start user
     if(KB.getNum&lt;10&amp;&amp;i&lt;8){times=millis();w=1;
      code[i] = KB.getNum; tone(11, 500+code[i]*50, 200);
     case 0: ccc = code[0];break;
     case 1: ccc = code[0]*10 + code[1];break;
     case 2: ccc = code[0]*100 + code[1]*10 + code[2];break;
     case 3: ccc = code[0]*1000 + code[1]*100 + code[2]*10 + code[3];break;
     case 4: ccc = code[0]*10000 + code[1]*1000 + code[2]*100 + code[3]*10 + code[4];break;
     case 5: ccc = code[0]*100000 + code[1]*10000 + code[2]*1000 + code[3]*100 + code[4]*10 + code[5];break;
    }i++; if(i&gt;5){i=7;}delay(200);Serial.println(ccc); tm.print(ccc, 0, -1, -1, -1, -1, -1, -1);}
 if(millis()-times&gt;5000&amp;&amp;w==1){w=0;
  i=0;ccc=0;w=0;for(i1=0;i1&lt;8;i1++){code[i]=0;
  tm.print(0, 0, 0b01000000, 0b00111001, 0b01011100, 0b01011110, 0b01111001, 0b01000000);}
  Serial.println(ccc);} // -code-
 if(start==1&amp;&amp;ccc==MASTER){start=0;cod=1;i=0;ccc=0;w=0;for(i1=0;i1&lt;8;i1++){code[i]=0;}
  tm.print(0, 0, 0b01000000, 0b01110110, 0b01110110, 0b01110110, 0b01110110, 0b01000000);
 } // -hhhh-
 if(start==1&amp;&amp;ccc==user&amp;&amp;w1==1){start=0;w1=0;digitalWrite(13,HIGH);
  tm.print(0, 0, 0b01000000, 0b00111111, 0b01110011, 0b01111001, 0b01010100, 0b01000000);
  tone(11, 1000, 1000);delay(TIME_OPEN);digitalWrite(13,LOW);times=millis()-5000;w=1;}// -open-
 if(start==1&amp;&amp;ccc!=user&amp;&amp;w1==1){start=0;w1=0;
  times=millis()-4000;w=1;
  tm.print(0, 0, 0b01000000, 0b01000000, 0b01000000, 0b01000000, 0b01000000, 0b01000000);}// ------
}//loop</code></pre></div>]]></content>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8534#p8534</id>
