	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; NJW1153]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=565&amp;type=atom" />
	<updated>2023-06-01T05:16:47Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=565</id>
			<title type="html"><![CDATA[NJW1153]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7915#p7915" />
			<content type="html"><![CDATA[<p>GENERAL DESCRIPTION <br />NJW1153 is a 6-channel electronic volume IC. It includes Input selector, tone control, volume, mute, input selector gain control, volume output gain control and 3 REC outputs. Each mode and conditions are set by the 3-wired serial control data.</p><p><a href="http://forum.rcl-radio.ru/uploads/images/2023/06/fbf5824b54d0ee372b06850dcb91fb07.pdf">http://forum.rcl-radio.ru/uploads/image … 91fb07.pdf</a></p><br /><p>NJW1153.h</p><div class="codebox"><pre><code>//  NJW1153 MITSUBISHI SOUND PROCESSOR ICs
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  NJW1153_H
#define  NJW1153_H
#define VOL_1   0B00000101
#define VOL_2   0B00010101
#define VOL_3   0B00100101
#define VOL_4   0B00110101
#define VOL_5   0B01000101
#define VOL_6   0B01010101
#define SETUP1  0B01100101
#define SETUP2  0B01110101
#define SETUP3  0B10000101
#define SETUP4  0B10010101
#include &lt;Arduino.h&gt;
class  NJW1153
    public:
 NJW1153(uint8_t,uint8_t,uint8_t);
 void init();
 void volume1(byte vol1);
 void volume2(byte vol2);
 void volume3(byte vol3);
 void volume4(byte vol4);
 void volume5(byte vol5);
 void volume6(byte vol6);
 void setup1(byte in_gain, byte out_gain, bool bsw, bool ssw);
 void setup2(int treb, bool tsw);
 void setup3(int bass);
 void setup4(byte input, byte multi_sel, bool rec2, bool rec1, bool rec0);
    private:
  uint8_t REQ_PIN;
  uint8_t SCK_PIN;
  uint8_t DATA_PIN;
  void Write(byte reg, byte dout);
#endif</code></pre></div><p>NJW1153.cpp</p><div class="codebox"><pre><code>#include &lt;NJW1153.h&gt;
NJW1153::NJW1153(uint8_t req, uint8_t sck, uint8_t data){
          REQ_PIN = req;
          SCK_PIN = sck;
          DATA_PIN = data;
      pinMode(REQ_PIN,OUTPUT);
      pinMode(SCK_PIN,OUTPUT);
      pinMode(DATA_PIN,OUTPUT);
      digitalWrite(REQ_PIN,HIGH);
      digitalWrite(SCK_PIN,HIGH);
      digitalWrite(DATA_PIN,HIGH);
void NJW1153::init(){// INITIAL CONDITION
   Write(255,VOL_1);
   Write(255,VOL_2);
   Write(255,VOL_3);
   Write(255,VOL_4);
   Write(255,VOL_5);
   Write(255,VOL_6);
   Write(0,SETUP1);
   Write(0,SETUP2);
   Write(0,SETUP3);
   Write(0,SETUP4);
     INITIAL CONDITION
D15 ......................... D0
1 1 1 1 1 1 1 1 0 0 0 0 0 1 0 1
1 1 1 1 1 1 1 1 0 0 0 1 0 1 0 1
1 1 1 1 1 1 1 1 0 0 1 0 0 1 0 1
1 1 1 1 1 1 1 1 0 0 1 1 0 1 0 1
1 1 1 1 1 1 1 1 0 1 0 0 0 1 0 1
1 1 1 1 1 1 1 1 0 1 0 1 0 1 0 1
0 0 0 0 0 0 0 0 0 1 1 0 0 1 0 1
0 0 0 0 0 0 0 0 0 1 1 1 0 1 0 1
0 0 0 0 0 0 0 0 1 0 0 0 0 1 0 1
0 0 0 0 0 0 0 0 1 0 0 1 0 1 0 1
void NJW1153::volume1(byte vol1){Write(vol1&lt;&lt;1,VOL_1);}
void NJW1153::volume2(byte vol2){Write(vol2&lt;&lt;1,VOL_2);}
void NJW1153::volume3(byte vol3){Write(vol3&lt;&lt;1,VOL_3);}
void NJW1153::volume4(byte vol4){Write(vol4&lt;&lt;1,VOL_4);}
void NJW1153::volume5(byte vol5){Write(vol5&lt;&lt;1,VOL_5);}
void NJW1153::volume6(byte vol6){Write(vol6&lt;&lt;1,VOL_6);}
void NJW1153::setup1(byte in_gain, byte out_gain, bool bsw, bool ssw){
 byte set1 = in_gain &lt;&lt; 5 | out_gain &lt;&lt; 2 | bsw &lt;&lt; 1 | ssw;
 Write(set1,SETUP1);
void NJW1153::setup2(int treb, bool tsw){
   bool cb_treb;
   if(treb&gt;0){cb_treb=1;}else{cb_treb=0;}
   byte set2 = cb_treb &lt;&lt; 7 | abs(treb) &lt;&lt; 3 | tsw &lt;&lt; 2;
   Write(set2,SETUP2);
void NJW1153::setup3(int bass){
   bool cb_bass;
   if(bass &gt; 0){cb_bass=1;}else{cb_bass=0;}
   byte set3 = cb_bass &lt;&lt; 7 | abs(bass) &lt;&lt; 3;
   Write(set3,SETUP3);
void NJW1153::setup4(byte input, byte multi_sel, bool rec2, bool rec1, bool rec0){
   byte set4 = input &lt;&lt; 5 | multi_sel &lt;&lt; 3 | rec2 &lt;&lt; 2 | rec1 &lt;&lt; 1 | rec0;
   Write(set4,SETUP4);
void NJW1153::Write(byte reg, byte dout){  // WRITE_REG
   digitalWrite(REQ_PIN,LOW);
        digitalWrite(DATA_PIN, (dout &gt;&gt; i) &amp; 0x01);
        digitalWrite(SCK_PIN,LOW);digitalWrite(SCK_PIN,HIGH);
        digitalWrite(DATA_PIN, (reg &gt;&gt; i) &amp; 0x01);
        digitalWrite(SCK_PIN,LOW); digitalWrite(SCK_PIN,HIGH);
   delay(1);
 }  </code></pre></div><p>test.ino</p><div class="codebox"><pre><code>#define REQ    2
#define SCK    3
#define DATA   4
NJW1153 njw(REQ,SCK,DATA);
  //init();
  njw.volume1(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.volume2(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.volume3(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.volume4(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.volume5(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.volume6(0);//  0...-100dB === byte 0...100 | mute = byte 127
  njw.setup1(0, 0, 1, 0);
  // in_gain 0|-3|-6|-9|-12dB === byte 0...4
  // out_gain 0|+3|+6|+9|+12|+15|+18 === byte 0...6
  // bsw (SWch Output add to L/Rch Output) off|add === bool 0...1
  // ssw (SW Output ON/OFF) sw output on|sw output off === bool 0...1
  njw.setup2(0, 1);
  // treb +-10dB === int -10...+10
  // tsw (Tone Control) off|on === bool 0...1
  njw.setup3(0);
  // bass +-10dB === int -10...+10
  njw.setup4(0, 0,  0,0,0);
  // input 1...8 === byte 0...7
  // multi_sel (Multi Channel Selector):
  //       Input Selector Output Signal === byte 0
  //       Multi channel Input Signal A === byte 1
  //       Multi channel Input Signal B === byte 2
  // rec2 on|off === bool 0...1
  // rec1 on|off === bool 0...1
  // rec0 on|off === bool 0...1
  }    </code></pre></div>]]></content>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7915#p7915</id>
