	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Переделка акустики BBK MA-970S 5.1 на ручное управление]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=561&amp;type=atom" />
	<updated>2023-09-22T16:58:50Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=561</id>
			<title type="html"><![CDATA[Re: Переделка акустики BBK MA-970S 5.1 на ручное управление]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8673#p8673" />
			<content type="html"><![CDATA[<div class="codebox"><pre><code>#define ENC_CLK     8
#define ENC_DT      9
#define ENC_SW      10
#define SEG_A       0
#define SEG_B       1
#define SEG_C       2
#define SEG_D       3
#define SEG_E       4
#define SEG_F       5
#define SEG_G       6
#define DP          7
#define KAT_0       A0
#define KAT_1       A1
#include &lt;Wire.h&gt;
#include &lt;PT2322.h&gt;
#include &lt;EEPROM.h&gt;
#include &lt;Encoder.h&gt;            // http://rcl-radio.ru/wp-content/uploads/2019/05/Encoder.zip
#include &lt;MsTimer2.h&gt;           // http://rcl-radio.ru/wp-content/uploads/2018/11/MsTimer2.zip
 Encoder myEnc(ENC_DT, ENC_CLK);// DT, CLK
 PT2322 pt1;
 long oldPosition  = -999,newPosition,times;
 int an, segm,i,vol,menu;
 byte a[2];
 bool w;
    MsTimer2::set(6, to_Timer);MsTimer2::start();
    pinMode(ENC_SW,INPUT);
    pinMode(SEG_A,OUTPUT);
    pinMode(SEG_B,OUTPUT);
    pinMode(SEG_C,OUTPUT);
    pinMode(SEG_D,OUTPUT);
    pinMode(SEG_E,OUTPUT);
    pinMode(SEG_F,OUTPUT);
    pinMode(SEG_G,OUTPUT);
    pinMode(DP,OUTPUT);
    pinMode(KAT_0,OUTPUT);
    pinMode(KAT_1,OUTPUT);
    vol = EEPROM.read(0);
    if(vol&gt;79){vol=0;}
////////////// BUTTON //////////////////////////////////////////////////////////////////
  if(digitalRead(10)==LOW){menu++;if(menu&gt;2){menu=0;}w=1;times=millis();delay(200);}
////////////// VOLUME /////////////////////////////////////////////////////////////////////////////////////////////////////////////
    if(newPosition != oldPosition){oldPosition = newPosition;if(newPosition&gt;1){newPosition=1;}if(newPosition&lt;-1){newPosition=-1;}
    vol=vol+newPosition;myEnc.write(0);newPosition=0;times=millis();w=1;if(vol&gt;79){vol=79;}if(vol&lt;0){vol=0;}}
    a[0]=(79-vol)/10%10;
    a[1]=(79-vol)%10;
 if(millis()-times&gt;5000 &amp;&amp; w==1){
     EEPROM.update(0,vol);
     menu=0;w=0;}
}//end loop
void to_Timer(){
   newPosition = myEnc.read()/4;
    case 0: segm = 10; segment();an=0; anod();delayMicroseconds(200);segm=a[0]; an=0; anod(); segment();break;
    case 1: segm = 10; segment();an=1; anod();delayMicroseconds(200);segm=a[1]; an=1; anod(); segment();break;
    }i++;if(i&gt;1){i=0;}}
void segment(){
  switch(segm){
             //  A          B           C            D          E          F         G
    case 0: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,1);ch(SEG_F,1);ch(SEG_G,0);break;// 0
    case 1: ch(SEG_A,0);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,0);ch(SEG_E,0);ch(SEG_F,0);ch(SEG_G,0);break;// 1
    case 2: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,0);ch(SEG_D,1);ch(SEG_E,1);ch(SEG_F,0);ch(SEG_G,1);break;// 2
    case 3: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,0);ch(SEG_F,0);ch(SEG_G,1);break;// 3
    case 4: ch(SEG_A,0);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,0);ch(SEG_E,0);ch(SEG_F,1);ch(SEG_G,1);break;// 4
    case 5: ch(SEG_A,1);ch(SEG_B,0);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,0);ch(SEG_F,1);ch(SEG_G,1);break;// 5
    case 6: ch(SEG_A,1);ch(SEG_B,0);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,1);ch(SEG_F,1);ch(SEG_G,1);break;// 6
    case 7: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,0);ch(SEG_E,0);ch(SEG_F,0);ch(SEG_G,0);break;// 7
    case 8: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,1);ch(SEG_F,1);ch(SEG_G,1);break;// 8
    case 9: ch(SEG_A,1);ch(SEG_B,1);ch(SEG_C,1);ch(SEG_D,1);ch(SEG_E,0);ch(SEG_F,1);ch(SEG_G,1);break;// 9
   case 10: ch(SEG_A,0);ch(SEG_B,0);ch(SEG_C,0);ch(SEG_D,0);ch(SEG_E,0);ch(SEG_F,0);ch(SEG_G,0);break;// пусто
void anod(){
  switch(an){
    case 0:ch(KAT_0,1);ch(KAT_1,0); break;
    case 1:ch(KAT_0,0);ch(KAT_1,1); break;
pt1.setFront_lk_att(0);// att front L
pt1.setFront_rk_att(0);// att front R
pt1.setCenter_att(0);  // att center
pt1.setRear_lk_att(0); // att rear L
pt1.setRear_rk_att(0); // att rear R
pt1.setSub_att(0);     // att sub
// int -7...7 = -14...+14 dB
pt1.setFunc(0,0,0);// FUNC:
                   // mute - 0 выкл, 1 вкл
                   // 3d - 0 вкл, 1 выкл
                   // тембр - 0 вкл, 1 выкл
                   // (int 0,0,0) - по умолчанию
pt1.setBass(0);            // BASS    -14...0...14 dB (int -7...0...7)
pt1.setMiddle(0);          // MIDDLE  -14...0...14 dB (int -7...0...7)
pt1.setTreble(0);          // TREBLE  -14...0...14 dB (int -7...0...7)
pt1.setVol(vol); // 0...79
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8673#p8673</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8672#p8672" />
			<content type="html"><![CDATA[<p>Теперь все сегменты отображаются как нужно, писк стал намного тише, но все еще работает только одна строка которая отображает цифры от 0 до 7</p>]]></content>
				<name><![CDATA[ER]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=2088</uri>
			<updated>2023-09-22T15:18:57Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8672#p8672</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8671#p8671" />
#define ENC_DT      9
#define ENC_SW      10
#define SEG_A       0
#define SEG_B       1
#define SEG_C       2
#define SEG_D       3
#define SEG_E       4
#define SEG_F       5
#define SEG_G       6
#define DP          7
#define KAT_0       A0
#define KAT_1       A1
 PT2322 pt1;
 byte a[2];
 bool w;
    pinMode(DP,OUTPUT);
    a[1]=(79-vol)%10;
     menu=0;w=1;}
}//end loop
void to_Timer(){newPosition = myEnc.read()/4;
void segment(){
  switch(segm){
             //  A          B           C            D          E          F         G
void anod(){
  switch(an){
			<updated>2023-09-22T13:35:40Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8671#p8671</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8670#p8670" />
			<content type="html"><![CDATA[<p>Прошил ардуино представленным выше скетчем. <br />Имеются следующие проблемы:<br />- постоянно светятся сегменты А и В вне зависимости от отображаемых цифр(проверял, каждый светодиод светится по отдельности нормально);<br />- светиться первый ряд светодиодов, если в скетче поменять значение &quot;#define KAT_0 A0&quot; на &quot;#define KAT_0 A1&quot;, и &quot;#define KAT_1 A1&quot; на &quot;#define KAT_1 A0&quot;&nbsp; начинает светится второй ряд светодиодов, первый выключается;<br />- опять появился неприятный писк в колонках, с тестовый скетчем с энкодером писк отсутствует.</p><p>Ниже прикладываю изображение с отображением информации на индикаторе, а именно отображение цифр 1, 4, 5, 6.<br /><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2023/09/94fed9ce3075f08df957fec9614a6b77.png" alt="http://forum.rcl-radio.ru/uploads/images/2023/09/94fed9ce3075f08df957fec9614a6b77.png" /></span></p>]]></content>
			<updated>2023-09-22T13:24:12Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8670#p8670</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8668#p8668" />
#define ENC_DT      9
#define ENC_SW      10
#define SEG_A       0
#define SEG_B       1
#define SEG_C       2
#define SEG_D       3
#define SEG_E       4
#define SEG_F       5
#define SEG_G       6
#define DP          7
#define KAT_0       A0
#define KAT_1       A1
 PT2322 pt1;
 byte a[2];
 bool w;
    pinMode(DP,OUTPUT);
    a[0]=(79-vol)%10;
     menu=0;w=1;}
}//end loop
    case 0: segm = 10; segment();segm=a[0]; an=0; anod(); segment();break;
    case 1: segm = 10; segment();segm=a[1]; an=1; anod(); segment();break;
void segment(){
  switch(segm){
             //  A          B           C            D          E          F         G
void anod(){
  switch(an){
			<updated>2023-09-21T12:19:12Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8668#p8668</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8667#p8667" />
			<content type="html"><![CDATA[<p>Готово, все распаял.</p>]]></content>
			<updated>2023-09-21T10:38:12Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8667#p8667</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8660#p8660" />
			<content type="html"><![CDATA[<p>завтра постараюсь все распаять</p>]]></content>
			<updated>2023-09-19T16:11:12Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8660#p8660</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8659#p8659" />
			<content type="html"><![CDATA[<p>У энкодера должна быть такая схема</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2023/09/632dc3fd3470793dccc116df2eedc14f.png" alt="http://forum.rcl-radio.ru/uploads/images/2023/09/632dc3fd3470793dccc116df2eedc14f.png" /></span></p>]]></content>
			<updated>2023-09-19T14:54:19Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8659#p8659</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8658#p8658" />
			<content type="html"><![CDATA[<p>да, с кнопкой</p>]]></content>
			<updated>2023-09-19T14:54:12Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8658#p8658</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8657#p8657" />
			<content type="html"><![CDATA[<p>У Вас энкодер с кнопкой?</p>]]></content>
			<updated>2023-09-19T14:53:25Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8657#p8657</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8656#p8656" />
			<content type="html"><![CDATA[<p>Вот распиновка энкодера</p><div class="codebox"><pre><code>#define ENC_CLK     8
#define ENC_DT      9
#define ENC_SW      10</code></pre></div>]]></content>
			<updated>2023-09-19T14:47:10Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8656#p8656</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8655#p8655" />
			<content type="html"><![CDATA[<p>Вот распиновка к ардуино</p><div class="codebox"><pre><code>#define SEG_A       0
#define SEG_B       1
#define SEG_C       2
#define SEG_D       3
#define SEG_E       4
#define SEG_F       5
#define SEG_G       6
#define DP          7
#define KAT_0       A0
#define KAT_1       A1</code></pre></div>]]></content>
			<updated>2023-09-19T14:39:31Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8655#p8655</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8654#p8654" />
			<content type="html"><![CDATA[<p>Отлично.</p>]]></content>
			<updated>2023-09-19T14:35:24Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8654#p8654</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8653#p8653" />
			<content type="html"><![CDATA[<div class="quotebox"><cite>liman324 пишет:</cite><blockquote><p>Вам нужно 2 транзистора n-p-n bc337 bc557 или аналогичные<br />2 резистора по 1-10 кОм<br />8 резисторов по 200-330 Ом</p></blockquote></div><p>Имеется в наличии 2 резистора 4,7 кОм, 8 резисторов 330 Ом, 2 транзистора bc547</p>]]></content>
			<updated>2023-09-19T14:31:59Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8653#p8653</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=8652#p8652" />
			<content type="html"><![CDATA[<p>Можно не ставить транзисторы, но тогда нужно померить ток катода, при поданном на все аноды 5В через резисторы 330 Ом, если ток будет в пределах 20 мА, то транзисторы не нужны.</p>]]></content>
			<updated>2023-09-19T14:28:52Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=8652#p8652</id>
