	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; 7657696767676987]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=559&amp;type=atom" />
	<updated>2023-04-28T09:59:00Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=559</id>
			<title type="html"><![CDATA[7657696767676987]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7779#p7779" />
			<content type="html"><![CDATA[<div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#define SSD1306_I2C_ADDR 0x3D
#define SSD1306_CMD_DISPLAY_OFF 0xAE
#define SSD1306_CMD_DISPLAY_ON 0xAF
#define SSD1306_CMD_SET_MEMORY_MODE 0x20
#define SSD1306_CMD_SET_COLUMN_RANGE 0x21
#define SSD1306_CMD_SET_PAGE_RANGE 0x22
#define SSD1306_CMD_SET_DISPLAY_START_LINE 0x40
#define SSD1306_CMD_SET_CONTRAST_CONTROL 0x81
#define SSD1306_CMD_SET_SEGMENT_REMAP 0xA1
#define SSD1306_CMD_SET_COM_SCAN_DIRECTION 0xC8
#define SSD1306_CMD_SET_DISPLAY_OFFSET 0xD3
#define SSD1306_CMD_SET_COM_PIN_CONFIG 0xDA
#define SSD1306_CMD_SET_CLOCK_DIVIDE_RATIO 0xD5
#define SSD1306_CMD_SET_PRECHARGE_PERIOD 0xD9
#define SSD1306_CMD_SET_VCOMH_DESELECT_LEVEL 0xDB
#define SSD1306_CMD_SET_CHARGE_PUMP 0x8D
#define SSD1306_DATA_START_PAGE 0xB0
#define SSD1306_DATA_START_COLUMN 0x00
uint8_t      scrbuf[1024];
const uint8_t OLED_FONT[] PROGMEM = {
   0x00, 0x00, 0x00, 0x00, 0x00, // sp
   0x00, 0x00, 0x5F, 0x00, 0x00, // !
   0x00, 0x03, 0x00, 0x03, 0x00, // &quot;
   0x14, 0x3E, 0x14, 0x3E, 0x14, // #
   0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
   0x43, 0x33, 0x08, 0x66, 0x61, // %
   0x36, 0x49, 0x55, 0x22, 0x50, // &amp;
   0x00, 0x05, 0x03, 0x00, 0x00, // &#039;
   0x00, 0x1C, 0x22, 0x41, 0x00, // (
   0x00, 0x41, 0x22, 0x1C, 0x00, // )
   0x14, 0x08, 0x3E, 0x08, 0x14, // *
   0x08, 0x08, 0x3E, 0x08, 0x08, // +
   0x00, 0x50, 0x30, 0x00, 0x00, // ,
   0x08, 0x08, 0x08, 0x08, 0x08, // -
   0x00, 0x60, 0x60, 0x00, 0x00, // .
   0x20, 0x10, 0x08, 0x04, 0x02, // /
   0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
   0x00, 0x04, 0x02, 0x7F, 0x00, // 1
   0x42, 0x61, 0x51, 0x49, 0x46, // 2
   0x22, 0x41, 0x49, 0x49, 0x36, // 3
   0x18, 0x14, 0x12, 0x7F, 0x10, // 4
   0x27, 0x45, 0x45, 0x45, 0x39, // 5
   0x3E, 0x49, 0x49, 0x49, 0x32, // 6
   0x01, 0x01, 0x71, 0x09, 0x07, // 7
   0x36, 0x49, 0x49, 0x49, 0x36, // 8
   0x26, 0x49, 0x49, 0x49, 0x3E, // 9
   0x00, 0x36, 0x36, 0x00, 0x00, // :
   0x00, 0x56, 0x36, 0x00, 0x00, // ;
   0x08, 0x14, 0x22, 0x41, 0x00, // &lt;
   0x14, 0x14, 0x14, 0x14, 0x14, // =
   0x00, 0x41, 0x22, 0x14, 0x08, // &gt;
   0x02, 0x01, 0x51, 0x09, 0x06, // ?
   0x3E, 0x41, 0x59, 0x55, 0x5E, // @
   0x7E, 0x09, 0x09, 0x09, 0x7E, // A
   0x7F, 0x49, 0x49, 0x49, 0x36, // B
   0x3E, 0x41, 0x41, 0x41, 0x22, // C
   0x7F, 0x41, 0x41, 0x41, 0x3E, // D
   0x7F, 0x49, 0x49, 0x49, 0x41, // E
   0x7F, 0x09, 0x09, 0x09, 0x01, // F
   0x3E, 0x41, 0x41, 0x49, 0x3A, // G
   0x7F, 0x08, 0x08, 0x08, 0x7F, // H
   0x00, 0x41, 0x7F, 0x41, 0x00, // I
   0x30, 0x40, 0x40, 0x40, 0x3F, // J
   0x7F, 0x08, 0x14, 0x22, 0x41, // K
   0x7F, 0x40, 0x40, 0x40, 0x40, // L
   0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
   0x7F, 0x02, 0x04, 0x08, 0x7F, // N
   0x3E, 0x41, 0x41, 0x41, 0x3E, // O
   0x7F, 0x09, 0x09, 0x09, 0x06, // P
   0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
   0x7F, 0x09, 0x09, 0x09, 0x76, // R
   0x26, 0x49, 0x49, 0x49, 0x32, // S
   0x01, 0x01, 0x7F, 0x01, 0x01, // T
   0x3F, 0x40, 0x40, 0x40, 0x3F, // U
   0x1F, 0x20, 0x40, 0x20, 0x1F, // V
   0x7F, 0x20, 0x10, 0x20, 0x7F, // W
   0x41, 0x22, 0x1C, 0x22, 0x41, // X
   0x07, 0x08, 0x70, 0x08, 0x07, // Y
   0x61, 0x51, 0x49, 0x45, 0x43, // Z
   0x00, 0x7F, 0x41, 0x00, 0x00, // [
   0x02, 0x04, 0x08, 0x10, 0x20, // &quot;/&quot;
   0x00, 0x00, 0x41, 0x7F, 0x00, // ]
   0x04, 0x02, 0x01, 0x02, 0x04, // ^
   0x40, 0x40, 0x40, 0x40, 0x40, // _
   0x00, 0x01, 0x02, 0x04, 0x00, // `
   0x20, 0x54, 0x54, 0x54, 0x78, // a
   0x7F, 0x44, 0x44, 0x44, 0x38, // b
   0x38, 0x44, 0x44, 0x44, 0x44, // c
   0x38, 0x44, 0x44, 0x44, 0x7F, // d
   0x38, 0x54, 0x54, 0x54, 0x18, // e
   0x04, 0x04, 0x7E, 0x05, 0x05, // f
   0x08, 0x54, 0x54, 0x54, 0x3C, // g
   0x7F, 0x08, 0x04, 0x04, 0x78, // h
   0x00, 0x44, 0x7D, 0x40, 0x00, // i
   0x20, 0x40, 0x44, 0x3D, 0x00, // j
   0x7F, 0x10, 0x28, 0x44, 0x00, // k
   0x00, 0x41, 0x7F, 0x40, 0x00, // l
   0x7C, 0x04, 0x78, 0x04, 0x78, // m
   0x7C, 0x08, 0x04, 0x04, 0x78, // n
   0x38, 0x44, 0x44, 0x44, 0x38, // o
   0x7C, 0x14, 0x14, 0x14, 0x08, // p
   0x08, 0x14, 0x14, 0x14, 0x7C, // q
   0x00, 0x7C, 0x08, 0x04, 0x04, // r
   0x48, 0x54, 0x54, 0x54, 0x20, // s
   0x04, 0x04, 0x3F, 0x44, 0x44, // t
   0x3C, 0x40, 0x40, 0x20, 0x7C, // u
   0x1C, 0x20, 0x40, 0x20, 0x1C, // v
   0x3C, 0x40, 0x30, 0x40, 0x3C, // w
   0x44, 0x28, 0x10, 0x28, 0x44, // x
   0x0C, 0x50, 0x50, 0x50, 0x3C, // y
   0x44, 0x64, 0x54, 0x4C, 0x44, // z
   0x00, 0x08, 0x36, 0x41, 0x41, // {
   0x00, 0x00, 0x7F, 0x00, 0x00, // |
   0x41, 0x41, 0x36, 0x08, 0x00, // }
   0x02, 0x01, 0x02, 0x04, 0x02, // ~
#define GAIN      100
#define STEP      3
#define LOW_SOUND 100
#define MAX_SOUND 600
  int strela=-45;
  int hMeter = 65;
  int vMeter = 85;
  int rMeter = 80;
  int ur,urr;
void sendCommand(uint8_t cmd) {
  Wire.beginTransmission(SSD1306_I2C_ADDR);
  Wire.write(0x00);
  Wire.write(cmd);
  Wire.endTransmission();
void sendData(uint8_t data) {
  Wire.write(0x40);
  Wire.write(data);
void initDisplay() {
  sendCommand(SSD1306_CMD_DISPLAY_OFF);
  sendCommand(SSD1306_CMD_SET_MEMORY_MODE);
  sendCommand(0x00); // Horizontal addressing mode
  sendCommand(SSD1306_CMD_SET_COLUMN_RANGE);
  sendCommand(0x00); // Column start address
  sendCommand(0x7F); // Column end address
  sendCommand(SSD1306_CMD_SET_PAGE_RANGE);
  sendCommand(0x00); // Page start address
  sendCommand(0x07); // Page end address
  sendCommand(SSD1306_CMD_SET_DISPLAY_START_LINE);
  sendCommand(SSD1306_CMD_SET_CONTRAST_CONTROL);
  sendCommand(0xCF); // Contrast value
  sendCommand(SSD1306_CMD_SET_SEGMENT_REMAP);
  sendCommand(SSD1306_CMD_SET_COM_SCAN_DIRECTION);
  sendCommand(SSD1306_CMD_SET_DISPLAY_OFFSET);
  sendCommand(0x00); // No offset
  sendCommand(SSD1306_CMD_SET_COM_PIN_CONFIG);
  sendCommand(0x12); // Sequential COM pin configuration
  sendCommand(SSD1306_CMD_SET_CLOCK_DIVIDE_RATIO);
  sendCommand(0x80); // Default oscillator frequency
  sendCommand(SSD1306_CMD_SET_PRECHARGE_PERIOD);
  sendCommand(0x22); // Phase 1 period of 15 DCLKs, Phase 2 period of 1 DCLK
  sendCommand(SSD1306_CMD_SET_VCOMH_DESELECT_LEVEL);
  sendCommand(0x20); // VCOMH deselect level
  sendCommand(SSD1306_CMD_SET_CHARGE_PUMP);
  sendCommand(0x14); // Enable charge pump
  sendCommand(SSD1306_CMD_DISPLAY_ON);
void clearDisplay() {
  for (uint8_t page = 0; page &lt; 8; page++) {
    sendCommand(SSD1306_DATA_START_PAGE + page);
    sendCommand(SSD1306_DATA_START_COLUMN);
    for (uint8_t column = 0; column &lt; 128; column++) {
      sendData(0x00);}}}
void setPixel(uint16_t x, uint16_t y){
  int by, bi;
  if ((x&gt;=0) and (x&lt;128) and (y&gt;=0) and (y&lt;64)){
    by=((y/8)*128)+x;
    bi=y % 8;
    scrbuf[by]=scrbuf[by] | (1&lt;&lt;bi);}
    Wire.write(0xC0);
    Wire.write(scrbuf[by]);
void drawLine (uint8_t x1, uint8_t x2, uint8_t y1, uint8_t y2)
  // determinant
  int16_t D;
  // deltas
  int16_t delta_x, delta_y;
  // steps
  int16_t trace_x = 1, trace_y = 1;
  // delta x
  delta_x = x2 - x1;
  // delta y
  delta_y = y2 - y1;
  // check if x2 &gt; x1
  if (delta_x &lt; 0) {
    // negate delta x
    delta_x = -delta_x;
    // negate step x
    trace_x = -trace_x;
  // check if y2 &gt; y1
  if (delta_y &lt; 0) {
    // negate detla y
    delta_y = -delta_y;
    // negate step y
    trace_y = -trace_y;
  // Bresenham condition for m &lt; 1 (dy &lt; dx)
  if (delta_y &lt; delta_x) {
    // calculate determinant
    D = (delta_y &lt;&lt; 1) - delta_x;
    // draw first pixel
    setPixel (x1, y1);
    // check if x1 equal x2
    while (x1 != x2) {
      // update x1
      x1 += trace_x;
      // check if determinant is positive
      if (D &gt;= 0) {
        // update y1
        y1 += trace_y;
        // update determinant
        D -= 2*delta_x;
      // update deteminant
      D += 2*delta_y;
      // draw next pixel
      setPixel (x1, y1);
  // for m &gt; 1 (dy &gt; dx)
  } else {
    D = delta_y - (delta_x &lt;&lt; 1);
    // draw first pixel
    setPixel (x1, y1);
    // check if y2 equal y1
    while (y1 != y2) {
      // update y1
      y1 += trace_y;
      if (D &lt;= 0) {
        // update y1
        x1 += trace_x;
        D += 2*delta_y;
      D -= 2*delta_x;
      // draw next pixel
      setPixel (x1, y1);
void drawHLine(int x, int y, int l){
  int by, bi;
    for (int cx=0; cx&lt;l; cx++){
      by=((y/8)*128)+x;
      bi=y % 8;
      scrbuf[by+cx] |= (1&lt;&lt;bi);
      Wire.write(0xC0);
      Wire.write(scrbuf[by+cx]);
void OLED_printC(char ch) {
  uint16_t offset = ch-32;
  offset += offset &lt;&lt; 2;
  Wire.write(0x00);
  for(uint8_t i=5; i; i--) Wire.write(pgm_read_byte(&amp;OLED_FONT[offset++]));
void OLED_printS(const char* p) {
  Wire.write(0x40);
  while(*p) OLED_printC(*p++);
void OLED_num(byte num){
  Wire.write(0x40);
  OLED_printC(num+48);
void OLED_cursor(uint8_t xpos, uint8_t ypos) {
  Wire.write(0x00);
  Wire.write(xpos &amp; 0x0F);
  Wire.write(0x10 | (xpos &gt;&gt; 4));
  Wire.write(0xB0 | (ypos &amp; 0x07));
  analogReference(INTERNAL);  // если очень маленький уровень сигнала
  pinMode(A0,INPUT);
  Wire.setClock(800000);
  initDisplay();
  clearDisplay();
 // OLED_num(5);
 //OLED_cursor(10, 0);
 //OLED_printS(&quot;RCL-R&quot;);OLED_printS(&quot;ADIO.&quot;);OLED_printS(&quot;RU&quot;);
  int a1 = (hMeter + (sin(ur / 57.296) * rMeter)); // meter needle horizontal coordinate
  int a2 = (vMeter - (cos(ur / 57.296) * rMeter)); // meter needle vertical coordinate
 drawLine(12, 100, 10, 15);
  delay(50);
  //clearDisplay();
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7779#p7779</id>
