		<title><![CDATA[forum.rcl-radio.ru &mdash; PT2323 & PT2322 + IR + Clock + encoder]]></title>
		<link>http://forum.rcl-radio.ru/viewtopic.php?id=556</link>
		<atom:link href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=556&amp;type=rss" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «PT2323 & PT2322 + IR + Clock + encoder».]]></description>
		<lastBuildDate>Sat, 22 Apr 2023 03:46:55 +0000</lastBuildDate>
			<title><![CDATA[PT2323 & PT2322 + IR + Clock + encoder]]></title>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=7763#p7763</link>
			<description><![CDATA[<p>Good Day ! <br />i have received This two ic&#039;s and fabricate the a PCB was shared on 320volt.com .<br />Liman im ready to test can you please add Clock and Standby mode to this ?<br /></p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#include &lt;PT2322.h&gt;
#include &lt;PT2323.h&gt;
#include &lt;EEPROM.h&gt;
#include &lt;Encoder.h&gt;
#include &lt;MsTimer2.h&gt;
#include &lt;boarddefs.h&gt;
#include &lt;IRremote.h&gt;
 PT2322 pt; PT2323 pt0;
  Encoder myEnc(9, 8);//CLK, DT encoder connection
  IRrecv irrecv(13); // IR receiver module
   int g1,g2,inn;
  lcd.begin(16, 2);lcd.createChar(0,a1);lcd.createChar(1,a2);lcd.createChar(2,a3);
  pinMode(A0,INPUT); // menu encoder button
  pinMode(12,INPUT); // MUTE button
  pinMode(11,INPUT); // IN select button
  delay(500);
  audio();audio_in();
 void loop(){delay(10);
  if(analogRead(A0)&lt;900){menu++;cl1();myEnc.write(0);time=millis();w=1;if(menu&gt;11){menu=0;}}// menu
  if ( irrecv.decode( &amp;ir )) {Serial.print(&quot;0x&quot;);Serial.println( ir.value,HEX);time=millis();w=1;irrecv.resume();}// IR receiver
   if(ir.value==0xFFE21D){menu++;g1=0;g2=0;cl1();time=millis();w=1;if(menu&gt;11){menu=0;}}// menu CH+ remote button
   if(ir.value==0xFF22DD){menu--;g1=0;g2=0;cl1();time=millis();w=1;if(menu&lt;0){menu=11;}}// menu CH- remote button
   if(ir.value==0xFF02FD){menu=0;g1=0;g2=0;cl1();time=millis();w=1;}// menu CH remote button (menu===0)
   if(ir.value==0xFFC23D){inn=1;g1=0;g2=0;time=millis();w=1;audio();}//  IN remote button
 //////////////////////////////////////// Volume -79...0 dB //////////////////////////////////////
     if(ir.value==0x4DB5DAAA){vol++;g1=1;g2=0;cl();time=millis();w=1;audio();}// VOL+ remote button 0xFFA857
     if(ir.value==0xFFFFFFFF and g1==1){vol++;g2=0;cl();time=millis();w=1;audio();}// button &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){vol--;g1=0;g2=1;cl();time=millis();w=1;audio();}// remote button VOL-
     if(ir.value==0xFFFFFFFF and g2==1){vol--;g1=0;cl();time=millis();w=1;audio();}// button &lt;&lt;&lt;&lt;&lt;&lt;
     if(vol&gt;79){vol=79;}if(vol&lt;0){vol=0;}
    oldPosition = newPosition;
    vol=vol+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(vol&gt;79){vol=79;}if(vol&lt;0){vol=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;Volume  &quot;);
  lcd.print(&quot; &quot;);lcd.print(-79+vol);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);vol_d=vol-32;
   if(z1==1){lcd.setCursor(z0,1);lcd.write((uint8_t)0);lcd.setCursor(z0+1,1);lcd.print(&quot;    &quot;);}}
 //////////////////////////////////////// Bass tone + -14 dB//////////////////////////////////////
     if(ir.value==0x4DB5DAAA){bass++;g1=1;g2=0;cl();time=millis();w=1;audio();}// VOL+ remote button
     if(ir.value==0xFFFFFFFF and g1==1){bass++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){bass--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){bass--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(bass&lt;-7){bass=-7;}if(bass&gt;7){bass=7;}
    bass=bass+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(bass&lt;-7){bass=-7;}if(bass&gt;7){bass=7;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;Bass    &quot;);
  lcd.print(&quot; &quot;);lcd.print(bass*2);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);bass_d=(bass+7)*2;
   if(z1==1){lcd.setCursor(z0+3,1);lcd.write((uint8_t)0);lcd.setCursor(z0+1+3,1);lcd.print(&quot;    &quot;);}}
   if(z1==2){lcd.setCursor(z0+3,1);lcd.write((uint8_t)2);}}
 //////////////////////////////////////// Tone middle + -14 dB //////////////////////////////////////
     if(ir.value==0x4DB5DAAA){mid++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){mid++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){mid--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){mid--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(mid&lt;-7){mid=-7;}if(mid&gt;7){mid=7;}
    mid=mid+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(mid&lt;-7){mid=-7;}if(mid&gt;7){mid=7;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;Middle  &quot;);
  lcd.print(&quot; &quot;);lcd.print(mid*2);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);mid_d=(mid+7)*2;
   for(z=0,z0=0,z1=0;z&lt;=mid_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
 //////////////////////////////////////// Treble tone +-14 dB //////////////////////////////////////
     if(ir.value==0x4DB5DAAA){treb++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){treb++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){treb--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){treb--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(treb&lt;-7){treb=-7;}if(treb&gt;7){treb=7;}
    treb=treb+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(treb&lt;-7){treb=-7;}if(treb&gt;7){treb=7;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;Treble  &quot;);
  lcd.print(&quot; &quot;);lcd.print(treb*2);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);treb_d=(treb+7)*2;
     if(ir.value==0x4DB5DAAA){tembro++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){tembro++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){tembro--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){tembro--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
      if(tembro&gt;4){tembro=0;}if(tembro&lt;0){tembro=4;}
    tembro=tembro+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(tembro&gt;4){tembro=0;}if(tembro&lt;0){tembro=4;}}
    lcd.setCursor(0,0);lcd.print(&quot; Preset timbre  &quot;);
    if(tembro==0){lcd.setCursor(0,1);lcd.print(&quot;  Manual Mode  &quot;);}
    if(tembro==1){lcd.setCursor(0,1);lcd.print(&quot;      ROCK     &quot;);bass=4,mid=-2;treb=5;x=1;}
    if(tembro==2){lcd.setCursor(0,1);lcd.print(&quot;      POP      &quot;);bass=-3,mid=3;treb=-2;x=1;}
    if(tembro==3){lcd.setCursor(0,1);lcd.print(&quot;    CLASSIC    &quot;);bass=0,mid=0;treb=-2;x=1;}
    if(tembro==4){lcd.setCursor(0,1);lcd.print(&quot;    default    &quot;);bass=0,mid=0;treb=0;x=1;}
    if(x==1){audio();x=0;}
   if(menu==5){
     if(ir.value==0x4DB5DAAA){attfl++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){attfl++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){attfl--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){attfl--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(attfl&lt;-14){attfl=-14;}if(attfl&gt;0){attfl=0;}
    attfl=attfl+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attfl&lt;-14){attfl=-14;}if(attfl&gt;0){attfl=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT FL   &quot;);
  lcd.print(&quot; &quot;);lcd.print(attfl);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);attfl_d=(attfl+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=attfl_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
   if(menu==6){
     if(ir.value==0x4DB5DAAA){attfr++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){attfr++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){attfr--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){attfr--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(attfr&lt;-14){attfr=-14;}if(attfr&gt;0){attfr=0;}
    attfr=attfr+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attfr&lt;-14){attfr=-14;}if(attfr&gt;0){attfr=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT FR   &quot;);
  lcd.print(&quot; &quot;);lcd.print(attfr);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);attfr_d=(attfr+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=attfr_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
  if(menu==7){
     if(ir.value==0x4DB5DAAA){atttl++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){atttl++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){atttl--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){atttl--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(atttl&lt;-14){atttl=-14;}if(atttl&gt;0){atttl=0;}
    atttl=atttl+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(atttl&lt;-14){atttl=-14;}if(atttl&gt;0){atttl=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT TL   &quot;);
  lcd.print(&quot; &quot;);lcd.print(atttl);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);atttl_d=(atttl+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=atttl_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
  if(menu==8){
     if(ir.value==0x4DB5DAAA){atttr++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){atttr++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){atttr--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){atttr--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(atttr&lt;-14){atttr=-14;}if(atttr&gt;0){atttr=0;}
    atttr=atttr+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(atttr&lt;-14){atttr=-14;}if(atttr&gt;0){atttr=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT TR   &quot;);
  lcd.print(&quot; &quot;);lcd.print(atttr);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);atttr_d=(atttr+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=atttr_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
    if(menu==9){
     if(ir.value==0x4DB5DAAA){attcn++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){attcn++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){attcn--;g1=0;g2=1;cl();time=millis();w=1;audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){attcn--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
      if(attcn&lt;-14){attcn=-14;}if(attcn&gt;0){attcn=0;}
    attcn=attcn+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attcn&lt;-14){attcn=-14;}if(attcn&gt;0){attcn=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT CN   &quot;);
  lcd.print(&quot; &quot;);lcd.print(attcn);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);attcn_d=(attcn+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=attcn_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
     if(menu==10){
     if(ir.value==0x4DB5DAAA){attsub++;g1=1;g2=0;cl();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){attsub++;g2=0;cl();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){attsub--;g1=0;g2=1;cl();audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){attsub--;g1=0;cl();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
       if(attsub&lt;-14){attsub=-14;}if(attsub&gt;0){attsub=0;time=millis();}
    attsub=attsub+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(attsub&lt;-14){attsub=-14;}if(attsub&gt;0){attsub=0;}audio();}
  lcd.setCursor(0,0);lcd.print(&quot;ATT SUB  &quot;);
  lcd.print(&quot; &quot;);lcd.print(attsub);lcd.print(&quot; &quot;);lcd.setCursor(13,0);lcd.print(&quot;dB&quot;);attsub_d=(attsub+14)*2;
   for(z=0,z0=0,z1=0;z&lt;=attsub_d;z++,z1++){if(z1&gt;2){z1=0;z0++;}
 if(menu==11){
     if(ir.value==0x4DB5DAAA){ddd++;g1=1;g2=0;cl1();time=millis();w=1;audio();}// кнопка VOL+
     if(ir.value==0xFFFFFFFF and g1==1){ddd++;g2=0;cl1();time=millis();w=1;audio();}// кнопка &gt;&gt;&gt;&gt;&gt;&gt;
     if(ir.value==0xFF18E7){ddd--;g1=0;g2=1;cl1();audio();}// кнопка VOL-
     if(ir.value==0xFFFFFFFF and g2==1){ddd--;g1=0;cl1();time=millis();w=1;audio();}// кнопка &lt;&lt;&lt;&lt;&lt;&lt;
   if(ddd&lt;0){ddd=1;}if(ddd&gt;1){ddd=0;}
    ddd=ddd+newPosition;myEnc.write(0);newPosition=0;time=millis();w=1;if(ddd&lt;0){ddd=1;}if(ddd&gt;1){ddd=0;}audio();}
   lcd.setCursor(0,0); if(ddd==0){lcd.print(&quot;     3D  ON  &quot;);}else{lcd.print(&quot;     3D  OFF  &quot;);} }
  if(mute==1&amp;&amp;(digitalRead(12)==HIGH)){mute=0;menu=0;audio();cl1();}
  if(digitalRead(12)==HIGH){mute=1;menu=100;audio();cl1();}
  if(mute==1){lcd.setCursor(0,0);lcd.print(&quot;      MUTE      &quot;);delay(300);}
  if(digitalRead(11)==HIGH||inn==1){in++;if(in&gt;4){in=0;}audio_in();cl1();lcd.setCursor(0,0);lcd.print(&quot;    INPUT  &quot;);lcd.print(in+1);delay(2000);time=millis();w=1;inn=0;}// in
   if(millis()-time&gt;10000&amp;&amp; w==1&amp;&amp;mute==0){
     menu=0;w=0;cl();}
 }//loop
 void audio_in(){
  pt0.setInput(in);
  pt0.setMute(0,0,0,0,0,0,0);
  pt0.setFeature(1,1);
			<author><![CDATA[null@example.com (stevenxscott0)]]></author>
			<pubDate>Sat, 22 Apr 2023 03:46:55 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=7763#p7763</guid>
