		<title><![CDATA[forum.rcl-radio.ru &mdash; M61531FP]]></title>
		<link>http://forum.rcl-radio.ru/viewtopic.php?id=507</link>
		<atom:link href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=507&amp;type=rss" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «M61531FP».]]></description>
		<lastBuildDate>Tue, 23 Aug 2022 14:14:23 +0000</lastBuildDate>
			<title><![CDATA[M61531FP]]></title>
			<link>http://forum.rcl-radio.ru/viewtopic.php?pid=6568#p6568</link>
			<description><![CDATA[<p><span class="attention-yellow"></span> </p><div class="codebox"><pre><code>// M61531FP
#define DATA     2
#define CLOCK    3
#define LATCH    4
  pinMode(DATA,OUTPUT);pinMode(CLOCK,OUTPUT);pinMode(LATCH,OUTPUT);
  digitalWrite(DATA,LOW);digitalWrite(CLOCK,LOW);digitalWrite(LATCH,LOW);
     //   input_sel, input_att, rec_out1, rec_out2, rec_out3, rec_out4, multi_input, lr_vol_in1, input_gain, ins10, all_ch_out_mute, multi_in_mute, lr_vol_in2
  slot0(  0,         0,         0,        0,        0,        0,        0,           0,          0,          0,     0,               0,             0);
     //   l_vol, r_vol, c_vol
  slot1(  0,     0,     0);
     //   sl_vol, sr_vol, sw_vol
  slot2(  0,      0,      0);
     //   bass, treb, tone_in_att, bypass_tone, tone_block, loud, loud_balance, lr_bupass
  slot3(  0,    0,    0,           0,           0,          0,    0,            0);
void slot0(int input_sel, int input_att, int rec_out1, int rec_out2, int rec_out3, int rec_out4, int multi_input, int lr_vol_in1, int input_gain, int ins10, int all_ch_out_mute, int multi_in_mute, int lr_vol_in2){
  for(int i=3;i&gt;=0; i--){
     digitalWrite(DATA, (input_sel &gt;&gt; i) &amp; 1);
     digitalWrite(CLOCK,HIGH);
  for(int i=1;i&gt;=0; i--){
     digitalWrite(DATA, (input_att &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, rec_out1);
     digitalWrite(DATA, rec_out2);
     digitalWrite(DATA, rec_out3);
     digitalWrite(DATA, rec_out4);
     digitalWrite(DATA, multi_input);
     digitalWrite(DATA, lr_vol_in1);
     digitalWrite(DATA, (input_gain &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, ins10);
     digitalWrite(DATA, all_ch_out_mute);
     digitalWrite(DATA, multi_in_mute);
     digitalWrite(DATA, lr_vol_in2);
     int stot_add0 = 0b0010;
     digitalWrite(DATA, (stot_add0 &gt;&gt; i) &amp; 1);
     digitalWrite(LATCH,HIGH);
 void slot1(int l_vol, int r_vol, int c_vol){
  for(int i=6;i&gt;=0; i--){
     digitalWrite(DATA, (l_vol &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (r_vol &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (c_vol &gt;&gt; i) &amp; 1);
     int stot_add1 = 0b000;
  for(int i=2;i&gt;=0; i--){
     digitalWrite(DATA, (stot_add1 &gt;&gt; i) &amp; 1);
 void slot2(int sl_vol, int sr_vol, int sw_vol){
     digitalWrite(DATA, (sl_vol &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (sr_vol &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (sw_vol &gt;&gt; i) &amp; 1);
     int stot_add2 = 0b001;
     digitalWrite(DATA, (stot_add2 &gt;&gt; i) &amp; 1);
void slot3(int bass, int treb, int tone_in_att, int bypass_tone, int tone_block, int loud, int loud_balance, int lr_bupass){
  for(int i=4;i&gt;=0; i--){
     digitalWrite(DATA, (bass &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (treb &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, (tone_in_att &gt;&gt; i) &amp; 1);
     digitalWrite(DATA, bypass_tone);
     digitalWrite(DATA, tone_block);
     digitalWrite(DATA, loud);
     digitalWrite(DATA, loud_balance);
     digitalWrite(DATA, lr_bupass);
     int stot_add3 = 0b00000011;
  for(int i=7;i&gt;=0; i--){
     digitalWrite(DATA, (stot_add3 &gt;&gt; i) &amp; 1);
     }          </code></pre></div>]]></description>
			<pubDate>Tue, 23 Aug 2022 14:14:23 +0000</pubDate>
			<guid>http://forum.rcl-radio.ru/viewtopic.php?pid=6568#p6568</guid>
