	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; STM32_TM1637]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=485&amp;type=atom" />
	<updated>2022-03-20T16:09:26Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=485</id>
			<title type="html"><![CDATA[STM32_TM1637]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=5562#p5562" />
			<content type="html"><![CDATA[<p><span class="attention-yellow"></span> </p><br /><p>STM32_TM1637.h<br /></p><div class="codebox"><pre><code>//  STM32_TM1637 v2.0
//  Alexander Liman
//  liman324@yandex.ru
//  rcl-radio.ru
#ifndef  STM32_TM1637_H
#define  STM32_TM1637_H
#include &lt;Arduino.h&gt;
#define CODE0    0b10001000
#define CODE1    0x40
#define ADDR0    0xC0
class  STM32_TM1637
    public:
  STM32_TM1637(uint8_t, uint8_t);
  void print_float(float decimal, byte pd,      byte h0, byte h1, byte h2, byte h3);
  void print_time(int t, byte pd_t);
  void brig(byte br);
    private:
  void dec(byte dig);
  void stop();
  void start();
  void del();
  byte qwer;
  uint8_t DIO;
  uint8_t CLK;
#endif</code></pre></div><p>STM32_TM1637.cpp<br /></p><div class="codebox"><pre><code>#include &lt;STM32_TM1637.h&gt;
STM32_TM1637::STM32_TM1637(uint8_t clk, uint8_t dio){
         CLK = clk;
         DIO = dio;
void STM32_TM1637::brig(byte br){
     qwer = br + CODE0;
void STM32_TM1637::del(){delayMicroseconds(100);}
void STM32_TM1637::dec(byte dig){
         for(int i = 0; i &lt; 8; i++) {
           pinMode(CLK, OUTPUT);del();
         if (dig &amp; 0x01)
           pinMode(DIO, INPUT);
         else
           pinMode(DIO, OUTPUT);del();
           pinMode(CLK, INPUT);del();
           dig = dig &gt;&gt; 1;
           pinMode(DIO, INPUT);del();
           uint8_t ack = digitalRead(DIO);
         if (ack == 0)
void STM32_TM1637::stop(){
void STM32_TM1637::start(){
void STM32_TM1637::print_float(float decimal, byte pd,    byte h0, byte h1, byte h2, byte h3){
        start();dec(qwer);stop();start();dec(CODE1);stop();start();
        byte minus;
        int mn;
        switch(pd){
          case 0: mn = 1;break;
          case 1: mn = 10;break;
          case 2: mn = 100;break;
          case 3: mn = 1000;break;
        if(decimal&lt;0){decimal = abs(decimal); minus = 1;}else{minus = 0;}
        //if(decimal/1000&gt;=1){pd = 0;}
        if(decimal/100&gt;=1&amp;&amp;decimal/100&lt;10){decimal = round(decimal*mn);}
        if(decimal/10&gt;=1&amp;&amp;decimal/10&lt;10){decimal = round(decimal*mn);}
        if(decimal&gt;=0&amp;&amp;decimal&lt;10){decimal = round(decimal*mn);}
        int data0 = (int)decimal/1000;
        int data1 = (int)decimal/100%10;
        int data2 = (int)decimal/10%10;
        int data3 = (int)decimal%10;
        for(int n=0;n&lt;4;n++){
        int data;
        if(n==0){data=data0;}
        if(n==1){data=data1;}
        if(n==2){data=data2;}
        if(n==3){data=data3;}
        switch(data){  // XGFEDCBA
        if(n==0){data0=data;}
        if(n==1){data1=data;}
        if(n==2){data2=data;}
        if(n==3){data3=data;}
        if(minus==0){
        if(pd==3&amp;&amp;decimal&lt;1000){data0 = 0b00111111;}
        if(pd==2&amp;&amp;decimal&lt;100){data0 = 0b00000000;data1 = 0b00111111;}
        if(pd==2&amp;&amp;decimal&lt;1000){data0 = 0b00000000;}
        if(pd==0&amp;&amp;decimal&lt;10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b00000000;}
        if(pd==0&amp;&amp;decimal&lt;100){data0 = 0b00000000;data1 = 0b00000000;}
        if(pd==0&amp;&amp;decimal&lt;1000){data0 = 0b00000000;}
        if(pd==1&amp;&amp;decimal&lt;1000){data0 = 0b00000000;}
        if(pd==1&amp;&amp;decimal&lt;100){data0 = 0b00000000;data1 = 0b00000000;}
        if(pd==1&amp;&amp;decimal&lt;10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b00111111;}
        if(decimal&gt;9999){data0 = 0b01000000;data1 = 0b01000000;data2 = 0b01000000;data3 = 0b01000000;}
        if(minus==1){
        if(pd==0&amp;&amp;decimal&lt;10){data0 = 0b00000000;data1 = 0b00000000;data2 = 0b01000000;}
        if(pd==0&amp;&amp;decimal&lt;100&amp;&amp;decimal&gt;9){data0 = 0b00000000;data1 = 0b01000000;}
        if(pd==0&amp;&amp;decimal&lt;1000&amp;&amp;decimal&gt;99){data0 = 0b01000000;}
        if(pd==1&amp;&amp;decimal&lt;100){data0 = 0b00000000;data1 = 0b01000000;}
        if(pd==1&amp;&amp;decimal&lt;1000&amp;&amp;decimal&gt;=100){data0 = 0b01000000;}
        if(pd==2&amp;&amp;decimal&lt;1000){data0 = 0b01000000;}
        if(decimal&gt;1000){data0 = 0b01000000;data1 = 0b01000000;data2 = 0b01000000;data3 = 0b01000000;}
        switch(pd){
        if(h0&gt;0){data0 = h0;}
        if(h1&gt;0){data1 = h1;}
        if(h2&gt;0){data2 = h2;}
        if(h3&gt;0){data3 = h3;}
        dec(ADDR0);dec(data0);dec(data1);dec(data2);dec(data3);stop();
void STM32_TM1637::print_time(int t, byte pd_t){
        int data0 = t/1000;
        int data1 = t/100%10;
        int data2 = t/10%10;
        int data3 = t%10;
        int data;
        if(pd_t==1){data1=data1+0b10000000;}
}</code></pre></div><p>test.ino<br /></p><div class="codebox"><pre><code>#include &lt;STM32_TM1637.h&gt;
STM32_TM1637 tm(PB0,PB1);// CLK, DIO
float h=0.1;
byte p=1;
  tm.brig(7); // ЯРКОСТЬ 0...7
   tm.print_float(h,p,  0,0,0,0);
   delay(500);
  tm.print_float(h,p,  h0,h1,h2,h3);
  float h = -999...9999 | 0.000...0.999 | -9.99...99.99 | -99.9...999.9
  byte p = 0...3 - число знаков после запятой
      A
  F |   | B
     -G-
  E |   | C
      D
 h0 h1 h2 h3
   XGFEDCBA (X - запятая)
 0b00000000
   */</code></pre></div><p>time.ino<br /></p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#include &lt;STM32_TM1637.h&gt; // http://forum.rcl-radio.ru/misc.php?action=pan_download&amp;item=403&amp;download=1
#include &lt;uRTCLib.h&gt;//https://github.com/Naguissa/uRTCLib.git
   uRTCLib rtc(0x68);
   // PB7 = SDA DS1307 (DS3231)
   // PB6 = SCL DS1307 (DS3231)
   // PB0 = CLK TM1637
   // PB1 = DIO TM1637
float h;
int i;
  // rtc.set(30, 37, 23, 2, 17, 12, 19);
  // RTCLib::set(byte second, byte minute, byte hour, byte dayOfWeek, byte dayOfMonth, byte month, byte year)
   rtc.refresh();// опрос времни
   h = rtc.hour()*100 + rtc.minute();
   tm.print_time(h, 0);
   delay(500);
   tm.print_time(h, 1);
   delay(500);
i++;
if(i==10){i=0;tm.print_float(rtc.temp()/100,0 ,0b1111000,0,0,0);delay(2000);}// вывод температуры DS3231
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=5562#p5562</id>
