	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; PT2323]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=470&amp;type=atom" />
	<updated>2022-03-04T13:44:01Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=470</id>
			<title type="html"><![CDATA[PT2323]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=5507#p5507" />
			<content type="html"><![CDATA[<p><span class="attention-yellow"></span> </p><p>PT2323.h<br /></p><div class="codebox"><pre><code>//  PT2323
#ifndef  PT2323_H
#define  PT2323_H
#define  PT2323_address 0b1001010 // адрес
#include &lt;Arduino.h&gt;
class  PT2323
  public:
     PT2323();
        void setInput(int in); // входы 1...4 (in = 0...3), 6 моно входов (in = 4)
        void setMute(int fl, int fr, int ct, int sub, int sl, int sr, int mute);
        // MUTE OFF для выходов (0,0,0,0,0,0,0);
        // MUTE ON  для выходов (1,1,1,1,1,1,1);
        // fl,  fr,  ct,  sub,  sl,  sr, все  выходы mute
        void setFeature(int surr, int mix); // дополнительные функции 0...1, 0...1
  private:
	void writeWire(char a);
#endif // PT2323_H</code></pre></div><p>PT2323.cpp<br /></p><div class="codebox"><pre><code>#include &lt;Arduino.h&gt;
#include &lt;Wire.h&gt;
#include &quot;PT2323.h&quot;
PT2323::PT2323(){
void PT2323::setInput(int in){
        case 0: in = 0b11001011;break;
	case 1: in = 0b11001010;break;
	case 2: in = 0b11001001;break;
	case 3: in = 0b11001000;break;
        case 4: in = 0b11000111;break;
        writeWire(in);}
void PT2323::setMute(int fl, int fr, int ct, int sub, int sl, int sr, int mute){
      if(fl==1){fl = 0b11110001;}else{fl = 0b11110000;}
      if(fr==1){fr = 0b11110011;}else{fr = 0b11110010;}
      if(ct==1){ct = 0b11110101;}else{ct = 0b11110100;}
    if(sub==1){sub = 0b11110111;}else{sub= 0b11110110;}
      if(sl==1){sl = 0b11111001;}else{sl = 0b11111000;}
      if(sr==1){sr = 0b11111011;}else{sr = 0b11111010;} ///
  if(mute==1){mute = 0b11111111;}else{mute=0b11111110;}
  writeWire(fl);
  writeWire(fr);
  writeWire(ct);
  writeWire(sub);
  writeWire(sl);
  writeWire(sr);
  writeWire(mute);
void PT2323::setFeature(int surr, int mix){
     switch(surr){
        case 0: surr = 0b11010000;break;
	case 1: surr = 0b11010001;break;
     switch(mix){
        case 0: mix = 0b10010000;break;
	case 1: mix = 0b10010001;break;
        writeWire(surr);
        writeWire(mix);
void PT2323::writeWire(char a){
  Wire.beginTransmission(PT2323_address);
  Wire.write (a);
  Wire.endTransmission();
}</code></pre></div><p>PT2323.ino<br /></p><div class="codebox"><pre><code>// rcl-radio.ru / liman324@yandex.ru
#include &lt;PT2323.h&gt;
PT2323 rt0;
  rt0.setInput(0); // входы 1...4 (0...3) или 6 моно (4)
  rt0.setMute(0,0,0,0,0,0,0); // MUTE OFF для выходов (0,0,0,0,0,0,0);
  rt0.setFeature(0,0); // дополнительные функции 0...3
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=5507#p5507</id>
