	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; TDA7419]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=461&amp;type=atom" />
	<updated>2022-03-03T05:32:54Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=461</id>
			<title type="html"><![CDATA[TDA7419]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=5498#p5498" />
			<content type="html"><![CDATA[<p><span class="attention-yellow"></span> </p><p>TDA7419.h<br /></p><div class="codebox"><pre><code>// Александр Лиман
// liman324@yandex.ru
// Пример использования - http://rcl-radio.ru/?p=57658
#ifndef TDA7419_H
#define TDA7419_H
// address 7 bit
#define TDA7419_address 0x44 // адрес HEX 88 &gt; 0b10001000 &gt; 7 bit = 0b1000100 = 0x44
//Sub addresses
#define TDA7419_INPUT        0b01000000 // Main Source Selector
#define TDA7419_LOUDNESS     0b01000001 // Main Loudness
#define TDA7419_SOFT         0b01000010 // Soft Mute / Clock Generator
#define TDA7419_VOLUME       0b01000011 // Volume
#define TDA7419_TREBLE       0b01000100 // Treble
#define TDA7419_MIDDLE       0b01000101 // Middle
#define TDA7419_BASS         0b01000110 // Bass
#define TDA7419_INPUT2       0b01000111 // Second Source Selector
#define TDA7419_SUB_M_B      0b01001000 // Subwoofer / Middle / Bass
#define TDA7419_MIX_G_EFF    0b01001001 // Mixing / Gain / Effect
#define TDA7419_ATT_LF       0b01001010 // Speaker Attenuator Left Front
#define TDA7419_ATT_RF       0b01001011 // Speaker Attenuator Right Front
#define TDA7419_ATT_LT       0b01001100 // Speaker Attenuator Left Rear
#define TDA7419_ATT_RT       0b01001101 // Speaker Attenuator Right Rear
#define TDA7419_MIX_LEV      0b01001110 // Mixing Level Control
#define TDA7419_ATT_SUB      0b01001111 // Subwoofer Attenuator
#define TDA7419_SPECTRUM     0b01010000 // Spectrum Analyzer / Clock Source / AC Mode
#include &lt;Arduino.h&gt;
class TDA7419
  public:
    TDA7419();
     /// Main Source Selector ///
        void setInput(int input, int gain, int auto_z); // int (Source Selector, Input Gain, Auto Zero)
        //Source Selector:      0...5 (QD/SE: QD, SE1, SE2, SE3, QD/SE: SE, mute)
        //Input Gain:           0...15 (0...+15 dB)
        //Auto Zero:            0...1 (on, off)
     /// Main Loudness ///
	void setAtt_loudness(int loud_att, int center_f, int h_boost, int loud_step);  // (Attenuation, Center Frequency, High Boost, Loudness Soft Step)
        //Attenuation:          0...15 (0...-15 dB)
        //Center Frequency:     0...3 (Flat, 400 Hz, 800 Hz, 2400 Hz)
        //High Boost:           0...1 (on, off)
        //Loudness Soft Step:   0...1 (on, off)
     ///  Soft Mute / Clock Generator ///
        void setSoft(int s_mute, int pin, int s_m_time, int s_time, int clock); // (Soft Mute, Pin Influence for Mute, Soft Mute Time, Soft Step Time, Clock Fast Mode)
        //Soft Mute:              0...1 (on, off)
        //Pin Influence for Mute: 0...1 (Pin and IIC, IIC)
        //Soft Mute Time:         0...2 (0.48ms, 0.96ms, 123ms)
        //Soft Step Time:         0...7 (0.160ms, 0.321ms, 0.642ms, 1.28ms, 2.26ms, 5.12ms, 10.24ms, 20.48ms)
        //Clock Fast Mode:        0...1 (on, off)
     /// Volume (Gain/Attenuation, Soft Step) ///
        void setVolume(int volume, int soft0);     // Volume
        void setAtt_LF(int left_f, int soft1);     // Volume   LF
        void setAtt_RF(int right_f, int soft2);    // Volume   RF
        void setAtt_LT(int left_t, int soft3);     // Volume   LT
        void setAtt_RT(int right_t, int soft4);    // Volume   RT
        void setAtt_SUB(int subwoofer, int soft5); // Volume   SUBWOOFER
        void setAtt_Mix(int mixing, int soft6);    // Volume   MIXING
        //Gain/Attenuation:       0...80 (80...0) 0 - mute
        //Soft Step:              0...1 (on, off)
     /// Filter ///
        void setFilter_Treble(int treble_g, int treble_c, int treble_ref);
            //  (-15...15, 0...3, 0...1) (-15 dB....15 dB, 10kHz 12.5kHz 15 kHz 17.5 kHz , Vref = 4V Vref = 3.3V )
            //(Gain/Attenuation, Treble Center Frequency, Reference Output Select)
        void setFilter_Middle(int middle_g, int middle_q, int middle_s );
            // (-15...15, 0...3, 0...1) (-15 dB....15 dB, 0.5 0.75 1 1.25, on off)
            // (Gain/Attenuation, Middle Q Factor, Middle Soft Step)
        void setFilter_Bass(int bass_g, int bass_q, int bass_s);
        //Gain/Attenuation: -15...15 db (int -15...15)
        //Bass Q Factor: 1.0 1.25 1.5 2.0 (int 0...3)
        // Bass Soft Step: on/off (int 0...1)
      ///  Second Source Selector ///
        void setInput2(int input2, int gain2, int auto_z2); // int (Source Selector, Input Gain, Auto Zero)
      /// Subwoofer /Middle / Bass ///
        void setSub_M_B(int sub, int mid, int bas, int bas_d, int s_filter); // (0...3, 0...3, 0...1, 0...1)
        //  (int sub) Subwoofer Cut-off Frequency:  flat, 80Hz, 120Hz, 160Hz
        //  (int mid) Middle Center Frequency:  500Hz, 1000Hz, 1500Hz, 2500Hz
        //  (int bas) Bass Center Frequency:  60Hz, 80Hz, 100Hz, 200Hz
        //  (int bas_d)  Bass DC Mode: on, off
        //  (int s_filter)  Smoothing Filter:  on, off (bypass)
        void setMix_Gain_Eff(int mix_l, int mix_r, int mix_en, int sub_en, int gain_eff); //(on/off, on/off, on/off, on/off, 0...10 = 0...22 dB)
        void setSpektor(int spek_q, int spek_res, int spek_an_s, int spek_an_r, int spek_reset, int spek_cl, int spek_mode);
        // on/off, on/off, on/off, on/off, on/off, on/off, 0...3
  private:
#endif //TDA7419_H</code></pre></div><p>TDA7419.cpp<br /></p><div class="codebox"><pre><code>#include &lt;Arduino.h&gt;
#include &lt;Wire.h&gt;
#include &quot;TDA7419.h&quot;
TDA7419::TDA7419(){
void TDA7419::setInput(int input, int gain, int auto_z){
  switch (input) {
        case 0: input = 0b00000000;break;
	case 1: input = 0b00000001;break;
	case 2: input = 0b00000010;break;
	case 3: input = 0b00000011;break;
	case 4: input = 0b00000100;break;
	case 5: input = 0b00000101;break;
  switch (gain) {
        case  0: gain = 0b00000000;break;
        case  1: gain = 0b00001000;break;
        case  2: gain = 0b00010000;break;
        case  3: gain = 0b00011000;break;
        case  4: gain = 0b00100000;break;
        case  5: gain = 0b00101000;break;
        case  6: gain = 0b00110000;break;
        case  7: gain = 0b00111000;break;
        case  8: gain = 0b01000000;break;
        case  9: gain = 0b01001000;break;
        case 10: gain = 0b01010000;break;
        case 11: gain = 0b01011000;break;
        case 12: gain = 0b01100000;break;
        case 13: gain = 0b01101000;break;
        case 14: gain = 0b01110000;break;
        case 15: gain = 0b01111000;break;
	switch (auto_z) {
        case 0: auto_z = 0b00000000;break;
	case 1: auto_z = 0b10000000;break;
	int selector = input + gain + auto_z;
  writeWire(TDA7419_INPUT, selector);
void TDA7419::setAtt_loudness(int loud_att, int center_f, int h_boost, int loud_step){
  switch (loud_att) {
        case  0: loud_att = 0b00000000;break;
        case  1: loud_att = 0b00000001;break;
        case  2: loud_att = 0b00000010;break;
        case  3: loud_att = 0b00000011;break;
        case  4: loud_att = 0b00000100;break;
        case  5: loud_att = 0b00000101;break;
        case  6: loud_att = 0b00000110;break;
        case  7: loud_att = 0b00000111;break;
        case  8: loud_att = 0b00001000;break;
        case  9: loud_att = 0b00001001;break;
        case 10: loud_att = 0b00001010;break;
        case 11: loud_att = 0b00001011;break;
        case 12: loud_att = 0b00001100;break;
        case 13: loud_att = 0b00001101;break;
        case 14: loud_att = 0b00001110;break;
        case 15: loud_att = 0b00001111;break;
  switch (center_f) {
        case  0: center_f = 0b00000000;break;
        case  1: center_f = 0b00010000;break;
        case  2: center_f = 0b00100000;break;
        case  3: center_f = 0b00110000;break;
  switch (h_boost) {
        case  0: h_boost = 0b00000000;break;
        case  1: h_boost = 0b01000000;break;
  switch (loud_step) {
        case  0: loud_step = 0b00000000;break;
        case  1: loud_step = 0b10000000;break;
        int main_loudness = loud_att + center_f + h_boost + loud_step;
  writeWire(TDA7419_LOUDNESS, main_loudness);
void TDA7419::setSoft(int s_mute, int pin, int s_m_time, int s_time, int clock){
  switch (s_mute) {
        case  0:  s_mute = 0b00000000;break;
        case  1:  s_mute = 0b00000001;break;
  switch (pin) {
        case  0:  pin = 0b00000000;break;
        case  1:  pin = 0b00000010;break;
  switch (s_m_time) {
        case  0:  s_m_time = 0b00000000;break;
        case  1:  s_m_time = 0b00000100;break;
        case  2:  s_m_time = 0b00001000;break;
  switch (s_time) {
        case  0:  s_time = 0b00000000;break;
        case  1:  s_time = 0b00010000;break;
        case  2:  s_time = 0b00100000;break;
        case  3:  s_time = 0b00110000;break;
        case  4:  s_time = 0b01000000;break;
        case  5:  s_time = 0b01010000;break;
        case  6:  s_time = 0b01100000;break;
        case  7:  s_time = 0b01110000;break;
  switch (clock) {
        case  0:  clock = 0b00000000;break;
        case  1:  clock = 0b10000000;break;
        int soft_mute_gen = s_mute + pin + s_m_time + s_time + clock;
        writeWire(TDA7419_SOFT, soft_mute_gen);
void TDA7419::setVolume(int volume, int soft0){
   if(volume &gt;= 0){} // 0 ... +15 dB
  if(volume &lt; 0){volume = abs(volume) + 16;} //-79 ... 0 dB
  switch (soft0) {
  case  0:  soft0 = 0b00000000;break;
  case  1:  soft0 = 0b10000000;break;
  writeWire(TDA7419_VOLUME, volume + soft0);
void TDA7419::setAtt_LF(int left_f, int soft1){
  left_f = 95 - left_f;
  switch (soft1) {
  case  0:  soft1 = 0b00000000;break;
  case  1:  soft1 = 0b10000000;break;
  writeWire(TDA7419_ATT_LF, left_f + soft1);
void TDA7419::setAtt_RF(int right_f, int soft2){
  right_f = 95 - right_f;
  switch (soft2) {
  case  0:  soft2 = 0b00000000;break;
  case  1:  soft2 = 0b10000000;break;
  writeWire(TDA7419_ATT_RF, right_f + soft2);
void TDA7419::setAtt_LT(int left_t, int soft3){
  left_t = 95 - left_t;
  switch (soft3) {
  case  0:  soft3 = 0b00000000;break;
  case  1:  soft3 = 0b10000000;break;
  writeWire(TDA7419_ATT_LT, left_t + soft3);
void TDA7419::setAtt_RT(int right_t, int soft4){
  right_t = 95 - right_t;
  switch (soft4) {
  case  0:  soft4 = 0b00000000;break;
  case  1:  soft4 = 0b10000000;break;
  writeWire(TDA7419_ATT_RT, right_t + soft4);
void TDA7419::setAtt_SUB(int subwoofer, int soft5){
  subwoofer = 95 - subwoofer;
  switch (soft5) {
  case  0:  soft5 = 0b00000000;break;
  case  1:  soft5 = 0b10000000;break;
  writeWire(TDA7419_ATT_SUB, subwoofer + soft5);
void TDA7419::setAtt_Mix(int mixing, int soft6){
  mixing = 95 - mixing;
  switch (soft6) {
  case  0:  soft6 = 0b00000000;break;
  case  1:  soft6 = 0b10000000;break;
  writeWire(TDA7419_MIX_LEV, mixing + soft6);
void TDA7419::setFilter_Treble(int treble_g, int treble_c, int treble_ref) {
  switch (treble_g) {
        case  -1: treble_g  = 0b00000001;break;
        case  -2: treble_g  = 0b00000010;break;
        case  -3: treble_g  = 0b00000011;break;
        case  -4: treble_g  = 0b00000100;break;
        case  -5: treble_g  = 0b00000101;break;
        case  -6: treble_g  = 0b00000110;break;
        case  -7: treble_g  = 0b00000111;break;
        case  -8: treble_g  = 0b00001000;break;
        case  -9: treble_g  = 0b00001001;break;
        case  -10: treble_g = 0b00001010;break;
        case  -11: treble_g = 0b00001011;break;
        case  -12: treble_g = 0b00001100;break;
        case  -13: treble_g = 0b00001101;break;
        case  -14: treble_g = 0b00001110;break;
        case  -15: treble_g = 0b00001111;break;
        case  0: treble_g   = 0b00000000;break;
        case  1: treble_g   = 0b00010001;break;
        case  2: treble_g   = 0b00010010;break;
        case  3: treble_g   = 0b00010011;break;
        case  4: treble_g   = 0b00010100;break;
        case  5: treble_g   = 0b00010101;break;
        case  6: treble_g   = 0b00010110;break;
        case  7: treble_g   = 0b00010111;break;
        case  8: treble_g   = 0b00011000;break;
        case  9: treble_g   = 0b00011001;break;
        case  10: treble_g  = 0b00011010;break;
        case  11: treble_g  = 0b00011011;break;
        case  12: treble_g  = 0b00011100;break;
        case  13: treble_g  = 0b00011101;break;
        case  14: treble_g  = 0b00011110;break;
        case  15: treble_g  = 0b00011111;break;
  switch (treble_c) {
        case  0:  treble_c = 0b00000000;break;
        case  1:  treble_c = 0b00100000;break;
        case  2:  treble_c = 0b01000000;break;
        case  3:  treble_c = 0b01100000;break;
  switch (treble_ref) {
        case  0:  treble_ref = 0b00000000;break;
        case  1:  treble_ref = 0b10000000;break;
        int treble_sum = treble_g + treble_c + treble_ref;
  writeWire(TDA7419_TREBLE, treble_sum);
void TDA7419::setFilter_Middle(int middle_g, int middle_q, int middle_s) {
  switch (middle_g) {
        case  -1: middle_g = 0b00000001;break;
        case  -2: middle_g = 0b00000010;break;
        case  -3: middle_g = 0b00000011;break;
        case  -4: middle_g = 0b00000100;break;
        case  -5: middle_g = 0b00000101;break;
        case  -6: middle_g = 0b00000110;break;
        case  -7: middle_g = 0b00000111;break;
        case  -8: middle_g = 0b00001000;break;
        case  -9: middle_g = 0b00001001;break;
        case  -10: middle_g = 0b00001010;break;
        case  -11: middle_g = 0b00001011;break;
        case  -12: middle_g = 0b00001100;break;
        case  -13: middle_g = 0b00001101;break;
        case  -14: middle_g = 0b00001110;break;
        case  -15: middle_g = 0b00001111;break;
        case  0: middle_g = 0b00000000;break;
        case  1: middle_g = 0b00010001;break;
        case  2: middle_g = 0b00010010;break;
        case  3: middle_g = 0b00010011;break;
        case  4: middle_g = 0b00010100;break;
        case  5: middle_g = 0b00010101;break;
        case  6: middle_g = 0b00010110;break;
        case  7: middle_g = 0b00010111;break;
        case  8: middle_g = 0b00011000;break;
        case  9: middle_g = 0b00011001;break;
        case  10: middle_g = 0b00011010;break;
        case  11: middle_g = 0b00011011;break;
        case  12: middle_g  = 0b00011100;break;
        case  13: middle_g  = 0b00011101;break;
        case  14: middle_g  = 0b00011110;break;
        case  15: middle_g  = 0b00011111;break;
	switch (middle_q) {
        case  0: middle_q = 0b00000000;break;
        case  1: middle_q = 0b00100000;break;
        case  2: middle_q = 0b01000000;break;
        case  3: middle_q = 0b01100000;break;
        switch (middle_s) {
        case  0: middle_s = 0b00000000;break;
        case  1: middle_s = 0b10000000;break;
        int middle_sum = middle_g + middle_s + middle_s;
  writeWire(TDA7419_MIDDLE , middle_sum);
void TDA7419::setFilter_Bass(int bass_g, int bass_q, int bass_s) {
        switch (bass_g) {
        case  -1: bass_g = 0b00000001;break;
        case  -2: bass_g = 0b00000010;break;
        case  -3: bass_g = 0b00000011;break;
        case  -4: bass_g = 0b00000100;break;
        case  -5: bass_g = 0b00000101;break;
        case  -6: bass_g = 0b00000110;break;
        case  -7: bass_g = 0b00000111;break;
        case  -8: bass_g = 0b00001000;break;
        case  -9: bass_g = 0b00001001;break;
        case  -10: bass_g = 0b00001010;break;
        case  -11: bass_g = 0b00001011;break;
        case  -12: bass_g = 0b00001100;break;
        case  -13: bass_g = 0b00001101;break;
        case  -14: bass_g = 0b00001110;break;
        case  -15: bass_g = 0b00001111;break;
        case  0: bass_g = 0b00000000;break;
        case  1: bass_g = 0b00010001;break;
        case  2: bass_g = 0b00010010;break;
        case  3: bass_g = 0b00010011;break;
        case  4: bass_g = 0b00010100;break;
        case  5: bass_g = 0b00010101;break;
        case  6: bass_g = 0b00010110;break;
        case  7: bass_g = 0b00010111;break;
        case  8: bass_g = 0b00011000;break;
        case  9: bass_g = 0b00011001;break;
        case  10: bass_g = 0b00011010;break;
        case  11: bass_g = 0b00011011;break;
        case  12: bass_g = 0b00011100;break;
        case  13: bass_g = 0b00011101;break;
        case  14: bass_g = 0b00011110;break;
        case  15: bass_g = 0b00011111;break;
	switch (bass_q) {
        case  0: bass_q = 0b00000000;break;
        case  1: bass_q = 0b00100000;break;
        case  2: bass_q = 0b01000000;break;
        case  3: bass_q = 0b01100000;break;
        switch (bass_s) {
        case  0: bass_s = 0b00000000;break;
        case  1: bass_s = 0b10000000;break;
         int bass_sum = bass_g + bass_s + bass_s;
  writeWire(TDA7419_BASS , bass_sum);
void TDA7419::setInput2(int input2, int gain2, int auto_z2){
  switch (input2) {
        case 0: input2 = 0b00000000;break;
	case 1: input2 = 0b00000001;break;
	case 2: input2 = 0b00000010;break;
	case 3: input2 = 0b00000011;break;
	case 4: input2 = 0b00000100;break;
	case 5: input2 = 0b00000101;break;
  switch (gain2) {
        case  0: gain2 = 0b00000000;break;
        case  1: gain2 = 0b00001000;break;
        case  2: gain2 = 0b00010000;break;
        case  3: gain2 = 0b00011000;break;
        case  4: gain2 = 0b00100000;break;
        case  5: gain2 = 0b00101000;break;
        case  6: gain2 = 0b00110000;break;
        case  7: gain2 = 0b00111000;break;
        case  8: gain2 = 0b01000000;break;
        case  9: gain2 = 0b01001000;break;
        case 10: gain2 = 0b01010000;break;
        case 11: gain2 = 0b01011000;break;
        case 12: gain2 = 0b01100000;break;
        case 13: gain2 = 0b01101000;break;
        case 14: gain2 = 0b01110000;break;
        case 15: gain2 = 0b01111000;break;
	switch (auto_z2) {
        case 0: auto_z2 = 0b00000000;break;
	case 1: auto_z2 = 0b10000000;break;
	int selector2 = input2 + gain2 + auto_z2;
  writeWire(TDA7419_INPUT2, selector2);
void TDA7419::setSub_M_B(int sub, int mid, int bas, int bas_d, int s_filter){
  switch (sub) {
        case  0: sub = 0b00000000;break;//flat
        case  1: sub = 0b00000001;break;//80 Hz
        case  2: sub = 0b00000010;break;//120 Hz
        case  3: sub = 0b00000011;break;//160 Hz
   switch (mid) {
        case  0: mid = 0b00000000;break;//500 Hz
        case  1: mid = 0b00000100;break;//1000 Hz
        case  2: mid = 0b00001000;break;//1500 Hz
        case  3: mid = 0b00001100;break;//2500 Hz
   switch (bas) {
        case  0: bas = 0b00000000;break;//60 Hz
        case  1: bas = 0b00010000;break;//80 Hz
        case  2: bas = 0b00100000;break;//100 Hz
        case  3: bas = 0b01100000;break;//200 Hz
   switch (bas_d) {
        case  0: bas_d = 0b00000000;break;//bass dc on
        case  1: bas_d = 0b01000000;break;//bass dc off
   switch (s_filter) {
	int smb = sub + mid + bas + bas_d + s_filter;
  writeWire(TDA7419_SUB_M_B, smb);
void TDA7419::setMix_Gain_Eff(int mix_l, int mix_r, int mix_en, int sub_en, int gain_eff){
        switch (mix_l) {
        case  0: mix_l = 0b00000000;break;
        case  1: mix_l = 0b00000001;break;
        switch (mix_r) {
        case  0: mix_r = 0b00000000;break;
        case  1: mix_r = 0b00000010;break;
        switch (mix_en) {
        case  0: mix_en = 0b00000000;break;
        case  1: mix_en = 0b00000100;break;
        switch (sub_en) {
        case  0: sub_en = 0b00000000;break;
        case  1: sub_en = 0b00001000;break;
        switch (gain_eff) {
        case  0: gain_eff = 0b11000000;break;
        case  1: gain_eff = 0b00000000;break;
        case  2: gain_eff = 0b00010000;break;
        case  3: gain_eff = 0b00100000;break;
        case  4: gain_eff = 0b00110000;break;
        case  5: gain_eff = 0b01000000;break;
        case  6: gain_eff = 0b01010000;break;
        case  7: gain_eff = 0b01100000;break;
        case  8: gain_eff = 0b01110000;break;
        case  9: gain_eff = 0b10000000;break;
        case  10: gain_eff = 0b10010000;break;
        int mix_sum = mix_l + mix_r + mix_en + sub_en + gain_eff;
  writeWire(TDA7419_MIX_G_EFF, mix_sum);
void TDA7419::setSpektor(int spek_q, int spek_res, int spek_an_s, int spek_an_r, int spek_reset, int spek_cl, int spek_mode){
        switch (spek_q) {
        case  0: spek_q = 0b00000000;break;
        case  1: spek_q = 0b00000001;break;
        switch (spek_res) {
        case  0: spek_res = 0b00000000;break;
        case  1: spek_res = 0b00000010;break;
        switch (spek_an_s) {
        case  0: spek_an_s = 0b00000000;break;
        case  1: spek_an_s = 0b00000100;break;
        switch (spek_an_r) {
        case  0: spek_an_r = 0b00000000;break;
        case  1: spek_an_r = 0b00001000;break;
        switch (spek_reset) {
        case  0: spek_reset = 0b00000000;break;
        case  1: spek_reset = 0b00010000;break;
        switch (spek_cl) {
        case  0: spek_cl = 0b00000000;break;
        case  1: spek_cl = 0b00100000;break;
        switch (spek_mode) {
        case  0: spek_mode = 0b00000000;break;
        case  1: spek_mode = 0b01000000;break;
        case  2: spek_mode = 0b10000000;break;
        case  3: spek_mode = 0b11000000;break;
        int spek_sum = spek_q + spek_res + spek_an_s + spek_an_r + spek_reset + spek_cl + spek_mode;
  writeWire(TDA7419_SPECTRUM, spek_sum);
void TDA7419::writeWire(char a, char b){
  Wire.beginTransmission(TDA7419_address);
  Wire.write (a);
  Wire.write (b);
  Wire.endTransmission();
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=5498#p5498</id>
