	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; ATmega8535 (ARDUINO IDE)]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=301&amp;type=atom" />
	<updated>2021-05-04T08:34:37Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=301</id>
			<title type="html"><![CDATA[ATmega8535 (ARDUINO IDE)]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=3443#p3443" />
			<content type="html"><![CDATA[<p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2021/05/1e34dfb118821907c880ce77a034a4c7.png" alt="http://forum.rcl-radio.ru/uploads/images/2021/05/1e34dfb118821907c880ce77a034a4c7.png" /></span> </p><p><a href="https://mcudude.github.io/MightyCore/package_MCUdude_MightyCore_index.json">https://mcudude.github.io/MightyCore/pa … index.json</a></p><p>BLINK </p><div class="codebox"><pre><code>void setup(){
  DDRA |= (1 &lt;&lt; PA0);
  PORTA |= (1 &lt;&lt; PA0);
  delay(1000);
  PORTA &amp;= ~(1 &lt;&lt; PA0);
  delay(1000);
  } </code></pre></div><p>ЗАГРУЗЧИК</p><div class="codebox"><pre><code>avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is &quot;/root/.arduino15/packages/MightyCore/hardware/avr/2.0.0/avrdude.conf&quot;
         User configuration file is &quot;/home/liman/.avrduderc&quot;
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega8535
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    0      0  9000  9000 0xff 0xff
           flash         33     6    64    0 yes      8192   64    128  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           efuse          0     0     0    0 no          0    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9308 (probably m8535)
avrdude: erasing chip
avrdude: reading input file &quot;0x3f&quot;
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file &quot;{bootloader.extended_fuses}&quot;
avrdude: writing efuse (0 bytes):
avrdude: 0 bytes of efuse written
avrdude: verifying efuse memory against {bootloader.extended_fuses}:
avrdude: load data efuse data from input file {bootloader.extended_fuses}:
avrdude: input file {bootloader.extended_fuses} contains 0 bytes
avrdude: reading on-chip efuse data:
avrdude: 0 bytes of efuse verified
avrdude: reading input file &quot;0xd4&quot;
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd4:
avrdude: load data hfuse data from input file 0xd4:
avrdude: input file 0xd4 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file &quot;0b10111111&quot;
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0b10111111:
avrdude: load data lfuse data from input file 0b10111111:
avrdude: input file 0b10111111 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done.  Thank you.</code></pre></div>]]></content>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=3443#p3443</id>
