	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Заменить SAMPLES на  j]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=271&amp;type=atom" />
	<updated>2021-02-07T08:01:28Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=271</id>
			<title type="html"><![CDATA[Заменить SAMPLES на  j]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=3047#p3047" />
			<content type="html"><![CDATA[<p>Частоту генератора можно менять меняя число 88, нада заменить&nbsp; 88 на j которое меняется кнопками.</p><div class="codebox"><pre><code>#include &quot;LiquidCrystal.h&quot;
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
int j;
#define SAMPLES 88
#include &lt;libmaple/dma.h&gt;
dma_tube_config dma_cfg;
int flag1 = 0;
int out1 = PB7;
int val1[SAMPLES];
int amp = 50;
int cnt = 0;
int time_track = 0;
float stp = 6.2831 / SAMPLES;
//float stp = 7.8539/SAMPLES;
int ret = 17;
timer_dev *dev1 = PIN_MAP[out1].timer_device;
uint8 cc_channel1 = PIN_MAP[out1].timer_channel;
void fun()
  flag1++;
void timer_conf()
  timer_dma_set_base_addr(dev1, TIMER_DMA_BASE_CCR2);
  timer_dma_set_burst_len(dev1, 1);
  timer_dma_enable_req(dev1, cc_channel1);
  timer_set_reload(dev1, 102);
  timer_set_prescaler(dev1, 0);
void dma_conf()
  dma_init(DMA1);
  /* T4C2 DMA C4 */
  dma_cfg.tube_dst = &amp;(dev1-&gt;regs.gen-&gt;DMAR);
  dma_cfg.tube_dst_size = DMA_SIZE_32BITS;
  dma_cfg.tube_src = val1;
  dma_cfg.tube_src_size = DMA_SIZE_32BITS;
  dma_cfg.tube_nr_xfers = SAMPLES;
  dma_cfg.tube_flags = DMA_CFG_SRC_INC | DMA_CFG_CIRC | DMA_CFG_CMPLT_IE;
  dma_cfg.tube_req_src = DMA_REQ_SRC_TIM4_CH2;
  dma_cfg.target_data = 0;
  ret = dma_tube_cfg(DMA1, DMA_CH4, &amp;dma_cfg);
void dma_start()
  dma_attach_interrupt(DMA1, DMA_CH4, fun);
  dma_enable(DMA1, DMA_CH4);
  timer_resume(dev1);
  dma_enable(DMA1, DMA_CH2);//
  //  timer_resume(dev2);
void init_wave()
  int i;
  for (i = 0; i &lt; SAMPLES; i++)
    val1[i] = 50 + amp * sin(stp * i);
  lcd.begin(16, 2);
  int i;
  int j;
  pinMode(out1, PWM);
  pinMode(PB13, INPUT_PULLDOWN);
  pinMode(PB12, INPUT_PULLDOWN);
  timer_conf();
  dma_conf();
  dma_start();
  init_wave();
void loop()
  if (digitalRead(PB12) == HIGH)
    // if (digitalRead(PB6) == HIGH) // UP
    if (j &lt; 200)
      // if (i &lt; 25)
      j++;
  if (digitalRead(PB13) == HIGH)
    if (j &gt; 0)
      j--;
  lcd.setCursor(0, 1);
  lcd.print(&quot;j = &quot;);
  lcd.setCursor(4, 1);
  lcd.print(j);
  delay(100);
				<name><![CDATA[galina]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=1049</uri>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=3047#p3047</id>
