	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; PCM1792]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=253&amp;type=atom" />
	<updated>2020-12-31T10:22:01Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=253</id>
			<title type="html"><![CDATA[PCM1792]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=2757#p2757" />
			<content type="html"><![CDATA[<p>24-Bit Resolution<br /> Analog Performance:<br />− Dynamic Range:<br />− 132 dB (9 V rms, Mono)<br />− 129 dB (4.5 V rms, Stereo)<br />− 127 dB (2 V rms, Stereo)<br />− THD+N: 0.0004%<br /> Differential Current Output: 7.8 mA p-p<br /> 8× Oversampling Digital Filter:<br />− Stop-Band Attenuation: –130 dB<br />− Pass-Band Ripple: ±0.00001 dB<br /> Sampling Frequency: 10 kHz to 200 kHz<br /> System Clock: 128, 192, 256, 384, 512, or 768 fS With Autodetect<br /> Accepts 16-, 20-, and 24-Bit Audio Data<br /> PCM Data Formats: Standard, I2S, and Left-Justified</p><p>User-Programmable Mode Controls:<br />− Digital Attenuation: 0 dB to –120 dB, 0.5 dB/Step<br />− Digital De-Emphasis<br />− Digital Filter Rolloff: Sharp or Slow<br />− Soft Mute<br />− Zero Flag for Each Output</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/65f7b298f8c99b6b497a2231e234fa31.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/65f7b298f8c99b6b497a2231e234fa31.png" /></span> </p><p>SPI Interface<br />The SPI interface is a 4-wire synchronous serial port which operates asynchronously to the serial audio interface and<br />the system clock (SCK). The serial control interface is used to program and read the on-chip mode registers. The<br />control interface includes MDO (pin 13), MDI (pin 11), MC (pin 12), and MS (pin 10). MDO is the serial data output,<br />used to read back the values of the mode registers; MDI is the serial data input, used to program the mode registers;<br />MC is the serial bit clock, used to shift data in and out of the control port, and MS is the mode control enable, used<br />to enable the internal mode register access.</p><p>Интерфейс SPI<br />Интерфейс SPI представляет собой 4-проводный синхронный последовательный порт, который работает асинхронно с последовательным аудиоинтерфейсом и системными часами (SCK). Последовательный интерфейс управления используется для программирования и считывания регистров режима на кристалле. Интерфейс управления включает в себя MDO (вывод 13), MDI (вывод 11), MC (вывод 12) и MS (вывод 10). <br />MDO-это последовательный вывод данных, используемый для считывания значений регистров режима; <br />MDI - это последовательный ввод данных, используемый для программирования регистров режима; <br />MC-это последовательные битовые часы, используемые для перемещения данных в порт управления и из него;<br />MS-это включение режима управления, используемое чтобы включить внутренний режим доступа к регистру.</p><p>Register Read/Write Operation<br />All read/write operations for the serial control port use 16-bit data words. Figure 29 shows the control data word<br />format. The most significant bit is the read/write (R/W) bit. For write operations, the R/W bit must be set to 0. For<br />read operations, the R/W bit must be set to 1. There are seven bits, labeled IDX[6:0], that hold the register index (or<br />address) for the read and write operations. The least significant eight bits, D[7:0], contain the data to be written to,<br />or the data that was read from, the register specified by IDX[6:0].<br />Figure 30 shows the functional timing diagram for writing or reading the serial control port. MS is held at a logic 1<br />state until a register needs to be written or read. To start the register write or read cycle, MS is set to logic 0. Sixteen<br />clocks are then provided on MC, corresponding to the 16 bits of the control data word on MDI and readback data<br />on MDO. After the eighth clock cycle has completed, the data from the indexed-mode control register appears on<br />MDO during the read operation. After the sixteenth clock cycle has completed, the data is latched into the<br />indexed-mode control register during the write operation. To write or read subsequent data, MS must be set to 1 once.</p><p>Операция Чтения/Записи Регистра<br />Все операции чтения/записи для последовательного порта управления используют 16-битные слова данных. На рис. 29 показан формат управляющих данных word. Наиболее значимым битом является бит чтения/записи (R/W). Для операций записи бит R/W должен быть установлен в 0. Для операций чтения бит R/W должен быть установлен в 1. Существует семь битов, помеченных IDX[6: 0], которые содержат индекс регистра (или адрес) для операций чтения и записи. Наименее значимые восемь битов, D[7: 0], содержат данные, которые должны быть записаны, или данные, которые были считаны из регистра, указанного IDX[6:0]. На рис. 30 показана функциональная временная схема записи или считывания последовательного порта управления. MS удерживается в состоянии логики 1 до тех пор, пока регистр не будет записан или прочитан. Чтобы запустить цикл записи или чтения регистра, MS устанавливается в логическое значение 0. Затем на MC предоставляется шестнадцать часов, соответствующих 16 битам слова управляющих данных на MDI и данным обратного считывания на MDO. После завершения восьмого такта данные из регистра управления индексированным режимом появляются на MDO во время операции считывания. После завершения шестнадцатого такта данные фиксируются в регистр управления индексированным режимом во время операции записи. Для записи или чтения последующих данных MS необходимо установить значение 1 один раз.</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/67725244e2b6cdc774f58735ece88272.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/67725244e2b6cdc774f58735ece88272.png" /></span> </p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/84d9fc6b272984c6259f44d30a8639a6.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/84d9fc6b272984c6259f44d30a8639a6.png" /></span> </p><p>даташит - <span class="attention-yellow"></span> </p><p>Ресивер CS8416 + I2C</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/f815babf1d9f2ea2516a2d79add0b717.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/f815babf1d9f2ea2516a2d79add0b717.png" /></span> </p><p>ЦАП </p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/ac31e95939953246eaf283d966eb2f0e.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/ac31e95939953246eaf283d966eb2f0e.png" /></span> </p><p>ФНЧ</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/aecbd26d5b07c2486ed66f6e59f25618.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/aecbd26d5b07c2486ed66f6e59f25618.png" /></span> </p><p>Стабилизаторы</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/a50d5e68079aa5725f71a4928af116b0.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/a50d5e68079aa5725f71a4928af116b0.png" /></span> </p><p>Упрощенная схема стабилизаторов</p><p><span class="postimg"><img src="http://forum.rcl-radio.ru/uploads/images/2020/12/5c48a98bf4ba387b19e3ba1e035f005e.png" alt="http://forum.rcl-radio.ru/uploads/images/2020/12/5c48a98bf4ba387b19e3ba1e035f005e.png" /></span></p>]]></content>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=2757#p2757</id>
