	<title type="html"><![CDATA[forum.rcl-radio.ru &mdash; Тестовый запуск PT2322 PT2323]]></title>
	<link rel="self" href="http://forum.rcl-radio.ru/extern.php?action=feed&amp;tid=151&amp;type=atom" />
	<updated>2023-04-18T14:35:26Z</updated>
	<id>http://forum.rcl-radio.ru/viewtopic.php?id=151</id>
			<title type="html"><![CDATA[Re: Тестовый запуск PT2322 PT2323]]></title>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7757#p7757" />
			<content type="html"><![CDATA[<p>Im talking about the whole sketch for this project .<br /></p><div class="codebox"><pre><code>Is it possible to Add Standby option with a bottom</code></pre></div><p>when the whole system start it will be on Standby then after switching a push bottom the program will start. <br /></p><div class="codebox"><pre><code>And making every front little bold and big</code></pre></div><p>I mean increasing font size eg- Volume, 3D on/off and all.</p>]]></content>
				<name><![CDATA[stevenxscott0]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=1844</uri>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7757#p7757</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7756#p7756" />
			<content type="html"><![CDATA[<div class="quotebox"><blockquote><p>Good Day Liman. Is it possible to Add Standby option with a bottom And making every front little bold and big?</p></blockquote></div><p>Я ни чего не понял.</p>]]></content>
			<updated>2023-04-18T07:00:13Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7756#p7756</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7755#p7755" />
			<content type="html"><![CDATA[<p>Good Day Liman. Is it possible to Add Standby option with a bottom And making every front little bold and big?</p>]]></content>
			<updated>2023-04-17T21:15:36Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7755#p7755</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7156#p7156" />
			<content type="html"><![CDATA[<p>Так и укажите А0-А3, если не заработает то:<br />А0 = 14<br />А1 = 15<br />А2 = 16<br />А3 = 17</p><p>Пример<br />LiquidCrystal lcd(17, 16, 15, 14, 4, 5);</p><p>Кнопка энкодера может работать на любом входе</p>]]></content>
			<updated>2022-12-30T05:06:35Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7156#p7156</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7155#p7155" />
			<content type="html"><![CDATA[<p>Подскажите как мне задействовать пины А0-А3 как цифровые чтоб перекинуть 4 контакта дисплея&nbsp; 4-5-6-7. могу я потом перенести кнопку энкодера на контакт D7, Ну а уже D6 использую для подсветки. Я если правильно понял надо как-то использовать digitalWrite а вот как правильно не понимаю.</p>]]></content>
				<name><![CDATA[serega_72m]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=1887</uri>
			<updated>2022-12-30T05:03:14Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7155#p7155</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7154#p7154" />
			<content type="html"><![CDATA[<p>Ограничьте ток подсветки при максимальной яркости до 20 мА.</p>]]></content>
			<updated>2022-12-29T10:10:19Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7154#p7154</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7153#p7153" />
			<content type="html"><![CDATA[<p>У Вас на пинах D5 D6 экран, перенесите экран на другие пины.</p>]]></content>
			<updated>2022-12-29T10:05:39Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7153#p7153</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7152#p7152" />
			<content type="html"><![CDATA[<p>В контроллере 3 таймера, каждый работает отдельно, под каждый таймер выделены пины для ШИМ, но таймеры это не только ШИМ, это прерывания для исполнения кода по времени. Таймер 1 занять под IRremote, отслеживая работу ИК датчика, поэтому ШИМ на нем сделать нельзя. D10 используется для ШИМ таймера 1, но он занять и работать как ШИМ не будет. Остается таймер 0, он свободен, его пины для ШИМ D5 D6, освободите (перенесите) эти пины если они заняты для ШИМ.</p>]]></content>
			<updated>2022-12-29T10:05:03Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7152#p7152</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7151#p7151" />
			<content type="html"><![CDATA[<div class="quotebox"><cite>liman324 пишет:</cite><blockquote><p>Дело не в пине, а в таймере, он занят.</p></blockquote></div><p>Я новичок, не совсем понял как это работает. Я указал в коде что использую пин 10 для выхода подсветки, и указал что для ИК приемника вход А2. Но ИК все равно занимает таймер 10 го пина ? Кнопки можно подключить к А пинам? по тому как все D пины выходят заняты. Хотел реализовать функцию регулировки подсветки.</p>]]></content>
			<updated>2022-12-29T10:00:00Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7151#p7151</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7150#p7150" />
			<content type="html"><![CDATA[<p>Дело не в пине, а в таймере, он занят.</p>]]></content>
			<updated>2022-12-29T09:49:39Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7150#p7150</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7149#p7149" />
			<content type="html"><![CDATA[<div class="quotebox"><cite>liman324 пишет:</cite><blockquote><p>Используйте D6 или D5 таймер 0, D10 таймер 1 занят под IRremote</p></blockquote></div><p>я перекинул IRremote на А2. Хотябы просто для того чтоб освободить 10. Но все равно нет реакции.все остальные входы D заняты подключением 2х кнопок, энкодера и экрана.</p>]]></content>
			<updated>2022-12-29T09:48:23Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7149#p7149</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7148#p7148" />
			<content type="html"><![CDATA[<p>Используйте D6 или D5 таймер 0, D10 таймер 1 занят под IRremote</p>]]></content>
			<updated>2022-12-29T09:00:08Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7148#p7148</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=7147#p7147" />
			<content type="html"><![CDATA[<p>Привет! подскажите как добавить функцию изменения яркости. Если можно то в пункт меню после 3D. Проверил подцепил на 10 выход подсветку экрана, работает. добавляю код в скетч с сайта&nbsp; подсветка не загорается вообще.#include &lt;LiquidCrystal.h&gt;<br />int led = 10;&nbsp; &nbsp;</p><p>LiquidCrystal lcd(7, 6, 2, 3, 4, 5);<br />void setup() {<br />&nbsp; lcd.begin(16, 2);<br />&nbsp; lcd.print(&quot;iarduino.ru&quot;);<br />&nbsp; lcd.setCursor(8, 1);<br />&nbsp; lcd.print(&quot;LCD 1602&quot;);<br />&nbsp; pinMode(led, OUTPUT); // Порт 10 (led) будет работать как Выход.<br />}<br />void loop() {<br />&nbsp; analogWrite(led, 50);&nbsp; <br /> delay(10);</p>]]></content>
			<updated>2022-12-29T08:56:42Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=7147#p7147</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=5370#p5370" />
			<content type="html"><![CDATA[<p>Спасибо огромное, действительно помогло, немного подкорректировал код и все получилось.</p>]]></content>
				<name><![CDATA[aleksey20024]]></name>
				<uri>http://forum.rcl-radio.ru/profile.php?id=1658</uri>
			<updated>2022-02-03T12:49:08Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=5370#p5370</id>
			<link rel="alternate" href="http://forum.rcl-radio.ru/viewtopic.php?pid=5360#p5360" />
			<content type="html"><![CDATA[<p>Работать будет</p><div class="codebox"><pre><code>#include &lt;Wire.h&gt;
#include &lt;PT2322.h&gt;
 PT2322 pt1;
 int mute = 0;
 int in = 0; // 0...4
 int ddd = 1; // 0...1
 int bass = 0; // -7...7
 int mid = 0; // -7...7
 int treb = 0; // -7...7
 int vol = 50; // 0...79
  Wire.begin();delay(500);
  audio2();
void audio2(){
  pt1.setFront_lk_att(abs(0));// att front L
  pt1.setFront_rk_att(abs(0));// att front R
  pt1.setCenter_att(abs(0));  // att center
  pt1.setRear_lk_att(abs(0)); // att rear L
  pt1.setRear_rk_att(abs(0)); // att rear R
  pt1.setSub_att(abs(0));     // att sub
  pt1.setFunc(0,ddd,0); // mute,3d,тембр on/off
  pt1.setBass(bass);            // BASS    -14...0...14 dB (int -7...0...7)
  pt1.setMiddle(mid);          // MIDDLE  -14...0...14 dB (int -7...0...7)
  pt1.setTreble(treb);          // TREBLE  -14...0...14 dB (int -7...0...7)
  pt1.setVol(vol); // 0...79
			<updated>2022-02-03T00:19:01Z</updated>
			<id>http://forum.rcl-radio.ru/viewtopic.php?pid=5360#p5360</id>
